Author Topic: Shade Tree Guzzi Mechanic  (Read 8809 times)
Offline Kevin M
« on: May 03, 2026, 10:19:53 PM »
I’m looking for someone that can adjust the clutch cable on a California II from the bottom. The clutch doesn’t slip, it just engages farther out than I like.
I’m in central IL, I can ride most anyplace.
Offline Missionguzzi
Re: Shade Tree Guzzi Mechanic
« Reply #1 on: May 04, 2026, 08:44:07 AM »
Well, if you decide to ride to New Mexico, I can adjust it for you.   Nice riding weather at this time of year.
Online Ncdan
« Reply #2 on: May 04, 2026, 09:29:25 AM »
Maybe see if one of the guys here can walk you through the procedure by phone with face time.
You can arrange something by PM??
« Reply #3 on: May 04, 2026, 11:19:36 AM »
Go over here----------------in 2 weeks & one of these guys will help you get it done.
https://wildguzzi.com/forum/index.php?topic=125056.0
Otherwise loosen adj on LH bar for clutch, crawl under bike & loosen 13mm locknut on lever, then w/pliers turn in(to the right) center pin 1/8 turn at a time till you take up slack on top bar adj. Tighten 13mm locknut.
Offline johnwesley
« Reply #4 on: May 04, 2026, 05:33:30 PM »
You could swing down south to my place but I bet ACE is closer.
Arkansas MGNOC rep
2003 cal ev custom build/ adv scrambler thing
2000 Quota
1989 cal III FF
1985 cal II
1977 T3 California
« Reply #5 on: May 07, 2026, 09:28:00 AM »
Anyone here have a copy of the  Tune-up Guide for a Shade Tree Mechanic that Frank W printed up years ago. To help out Eldo, Ambo, loop frame guy's?   I have a copy, not for sale.
