Author Topic: Caps and wires v7i/v7ii in 2026  (Read 8126 times)
Offline Error
« on: May 05, 2026, 06:43:38 PM »
Alright everyone, it’s 2026 and I want to replace my caps and wires.
NGK XD05F is discontinued. I don’t see any superseded number from NGK.
I’ve been reading as much as I can, but I haven’t found any “this part from this brand” for the V7i/v7ii.
Is OEM the only option, or does anyone have part numbers from major brands that work?
Offline DoubleGuzzi
Re: Caps and wires v7i/v7ii in 2026
« Reply #1 on: May 05, 2026, 07:29:44 PM »
£4.56 VAT EX (£5.47 VAT INC)
In Stock
Try searching for NGK 8072?
Ahh..
NGK 8072 XD05F Spark Plug Cap
NGK.com
https://www.ngk.com › Products › Plug Caps
This item has been discontinued.
Hmm.
 :popcorn:
« Last Edit: May 05, 2026, 07:34:17 PM by DoubleGuzzi »
Nearly natural progression..
Offline Error
« Reply #2 on: May 05, 2026, 07:33:55 PM »
Canada, but North America, yes.
So that part number is still for sale in Europe?
Offline DoubleGuzzi
« Reply #3 on: May 05, 2026, 07:37:11 PM »
Sorry, I spotted Canada AFTER I posted.
Yep, a few outlets show stock.
https://www.amazon.com/s?k=NGK%20XD05F  - low stocks, it seems.
Be aware that I have come across fake NGK caps.
[Addendum] I see Bosch F00099C903 is suggested as an alternative, if that helps.
« Last Edit: May 05, 2026, 07:41:53 PM by DoubleGuzzi »
Offline DoubleGuzzi
« Reply #4 on: May 05, 2026, 07:55:14 PM »
Offline Error
« Reply #5 on: May 05, 2026, 11:38:30 PM »
I’ll check out the Bosch. I avoid Amazon when I can, and as you said, too many fakes rolling around. I really want to buy from a store front or the manufacturer if I can.
Offline Error
« Reply #6 on: May 06, 2026, 09:53:40 AM »
Bosch Seems to be a bust as well. I sent a note to NGK to see if they have a superseded number somewhere.
« Last Edit: May 06, 2026, 09:59:39 AM by Error »
Offline 73 sport
« Reply #7 on: May 06, 2026, 12:45:56 PM »
   Buy the components and make your own. Two sources are Summit Racing, Pertronics.
Offline 73 sport
« Reply #8 on: May 06, 2026, 01:43:24 PM »
     PS. I made my own using Magecore Blue and their fittings.
Offline Error
« Reply #9 on: May 06, 2026, 04:55:55 PM »
This is the goal. If you have part numbers that work, sharing those would be super helpful.
Generally the issue is getting a correct angle on the spark plug cap to be able to fit under the cover and still meet the plug.
Offline 73 sport
« Reply #10 on: May 06, 2026, 05:46:27 PM »
     Go to" Magnecor" web site. You should find everything you need. They will also make up  wire sets   to your specs.
Offline Error
« Reply #11 on: May 07, 2026, 10:49:37 AM »
I was actually there yesterday after you mentioned it.
The SP115 and SP1617 looked promising, but without measurements it’s pretty hard to tell.
Offline 73 sport
« Reply #12 on: May 07, 2026, 11:00:45 AM »
   Give Magnecor a call, ask for the dimensions. Their phone # is at the bottom of their web site.
Offline Ed / AF1 Racing
Offline 73 sport
« Reply #14 on: May 08, 2026, 02:48:58 PM »
       It would be interesting to hear a realistic  justification  for that price.
Offline Error
« Reply #15 on: May 08, 2026, 04:50:32 PM »
factory updated kit in stock, https://www.af1racing.com/af1-2d000247-oem-moto-guzzi-spark-plug-wire-kit-v7-i-v7-ii
Ed! I've dealt with you before. I can honestly say you are one of the most helpful people I have ever done business with. Thank you.
I knew AF1 had them available, I was actually hoping to find an NGK alternative. It it comes right down to it, you may still get an order from me. But I want to see if an aftermarket alternative can be put together first.
Offline mr_pacman
« Reply #16 on: May 09, 2026, 01:04:16 PM »
Do the factory plug caps have NGK branding on them?  I just looked at my 2014 V7, which I bought used from the first owner. Pulled the cap off the spark plug and it's got an NGK logo on it.  Now I'm wondering if those had already been swapped out from the stock ones or, perhaps the factory was using NGK parts?
Offline 73 sport
for sale site
« Reply #17 on: May 09, 2026, 04:51:52 PM »
      Does WG have a for sale site?
Offline 73 sport
« Reply #18 on: May 09, 2026, 04:54:41 PM »
   Found it. Swap Meet.
Offline Error
« Reply #19 on: May 20, 2026, 04:43:42 PM »
On my 2016 V7ii they do not say NGK, and I believe they are original.
