Author Topic: Battery REview  (Read 933 times)
Re: Battery REview
« Reply #1 on: May 18, 2026, 02:21:08 PM »
Definitely don't agree. I've seen too many Yuasa batteries develop internal open circuits shortly after installation. Never heard of "Expertpower" or "Zipp". Chrome Batterys are good, but in the size I buy (YTX30L) they're an SLA not AGM. Odysseys are good but a bit expensive, but you sometimes (not always) get long service out of them.
Deka (Big Crank, Marathon, whatever the label reads) are still the best in my experience.
Re: Battery REview
« Reply #2 on: May 18, 2026, 02:37:34 PM »
Agreed on your feedback.  Yuasa has slipped in quality.  I replaced the Chrome battery under warranty.  No hassles and quick.  Have not bought Odyssey because of the cost too. :tongue:
Offline BMCMOTO
Re: Battery REview
« Reply #3 on: May 18, 2026, 03:26:57 PM »
I have 2 Odyssey batteries over ten year old and one Yuasa about a year old. I think one of the Odyssey batteries may be dying. I'll look at Chrome batteries when failure occurs. I've had exceptional service from the Odyssey batteries but their prices keep rising. The Odyssey's are available locally Yuasa's are not, don't know about others. I've not heard of the others they tested
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline johnwesley
Re: Battery REview
« Reply #4 on: May 18, 2026, 03:36:41 PM »
I’ve always had exceptional life out of odyssey. Double that of other batteries so the extra cost was worth it. He last on I had went out in 3 years, so I don’t take a risk on them anymore. I just purchase a good atm such as deka and know the life will be about 4 years or so.
Arkansas MGNOC rep
2003 cal ev custom build/ adv scrambler thing
2000 Quota
1989 cal III FF
1985 cal II
1977 T3 California
Re: Battery REview
« Reply #5 on: May 18, 2026, 03:43:51 PM »
The Deka/Big Crank AGM in my Convert is 10 years old and still going. They are usually are good for at least 7 years.
Offline TN Mark
Re: Battery REview
« Reply #6 on: May 18, 2026, 05:13:06 PM »
In many decades of motorcycle ownership Yuasa lead acid and then AGM batteries have been 100% reliable 100% of the time.
I know some sing the virtues of lithium etc. Sorry, have at it. I’ve not seen the need. Not one bit.
Online michaell32
Re: Battery REview
« Reply #7 on: May 18, 2026, 06:30:01 PM »
The odyssey in my California gave up this year and it was marked March of 2016. I replaced it with a U1 from Walmart since it was only 35 dollars vs almost 200 for a pc680.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline ridingron
Re: Battery REview
« Reply #8 on: May 18, 2026, 08:50:07 PM »
Thanks for putting that long ass link in your post. You could have cut it off at the question mark.
https://bestreviews.com/automotive/batteries/best-motorcycle-batteries?
Offline DoubleGuzzi
Re: Battery REview
« Reply #9 on: May 19, 2026, 03:56:20 AM »
Don't need the question mark unless followed by a specific product ID etc.
Nearly natural progression..
Online Perazzimx14
Re: Battery REview
« Reply #10 on: May 19, 2026, 07:36:13 AM »
I have come to like the Duracell AGM batteries from Batteries Plus. They are cost effective, have a 2 year non-prorated warranty, there is usually a 15 or 20% digital coupon and since its a nation wide chain if I have an issue there is a fair chance I'll have a bricks and motor store to go to if I have an issue.
I have had LION batteries and while they are light when they go tits up I replace with AGM because of cost and when I'm putting a battery in a 500+ lb bike having a 5lb lighter battery is like throwing a deck chair off the Titanic hoping it would sink slower.
As a reminder when buying a battery not only do you need to consider the CCA's you also have to consider the Amp Hour rating.  I found out the hard way on my Buell that a 400CCA LION batter (180 more CCA than factory) but only had 4 AH rating. When you touched the starter the voltage would drop to below the BMS limit because the low AH rating and the battery would trip out on safety. I ended up going back to a 220 CCA SLA battery with a 10 AH rating and while the starter did spin slower it started reliably.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline DoubleGuzzi
Re: Battery REview
« Reply #11 on: May 19, 2026, 07:53:52 AM »
..when I'm putting a battery in a 500+ lb bike having a 5lb lighter battery is like throwing a deck chair off the Titanic hoping it would sink slower.
LOL :grin:
Offline Moparnut72
Re: Battery REview
« Reply #12 on: May 19, 2026, 08:28:56 AM »
I used to race kneel down outboard boats. It always amazed me the number of guys who would do everything to get down to minimum weight. They were the ones that would get DQ'ed for being underweight. Most races were won by the racer who was in the lead coming out of the first turn. It is a running start against the clock so strategy in getting the inside lane and hitting the starting line as the clock hits zero at full speed is the secret to winning. It took me years to perfect my starts and in one light weight class I ran I was seriously overweight, like 30 lbs.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Battery REview
« Reply #13 on: May 19, 2026, 08:37:02 AM »
My Li-Iron batteries that I’ve owned were actually 10 lb lighter than a standard lead-acid. Cut 10 lb there, 10 lb by going with stainless exhaust, removing a few other bits, and I think weight savings can be felt. Also, I stay away from Li-Ion and do Li-Iron instead. Less chance of fireworks under your bum.
Offline DoubleGuzzi
Re: Battery REview
« Reply #14 on: May 19, 2026, 09:41:18 AM »
Trying to get to page 2, just so that stupid URL goes away.  :rolleyes:
I go for AGM or LiFePO4 and only when I see a great deal on the lithium ones i.e. comparable or cheaper than Motobatt AGM.
Money no object, I'd fork out for the hybrid ones (Motobatt do one)
Odyssey PC680 used to be the choice but times move on.
I'm beginning to see 8Ah LiFePO4 coming into the market, with the same physical size as the 4Ah ones, at a premium of course.
Offline 73 sport
Re: Battery REview
« Reply #15 on: May 19, 2026, 10:05:29 AM »
  Go to Google type in 'Yuasa batteries becoming less reliable". There is an explanation.
Re: Battery REview
« Reply #16 on: May 20, 2026, 08:21:03 AM »
Some of the worse batteries I have had were Yuasa.
Some of the best were Odyssey.
Just saying, YMMV.
Offline Moparnut72
Re: Battery REview
« Reply #17 on: May 20, 2026, 09:43:02 AM »
I have had excellent results with no-name inexpensive batteries purchased on the net. The best result was with a 110" Harley I had which would not start, turn over, when the temp was below 40*. The stock battery was 325 CCA if I remember correctly. I got a 500 CCA battery online that fit, no more problems.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
