Author Topic: 1970 Ambassador Project  (Read 213646 times)
Re: 1970 Ambassador Project
« Reply #30 on: June 07, 2026, 07:16:32 PM »
All of the grunge was scrubbed off the main housing using only nylon bristle brushes.  The housing still retains the look of age, which is a great look.  There is still some pesky gasket material to remove.
It may be a "patina bike", but it will be a clean one.   :grin:
« Last Edit: June 07, 2026, 07:25:33 PM by Dave Swanson »
« Reply #31 on: June 08, 2026, 08:44:51 AM »
Welch plug sealed with JB.
« Reply #32 on: June 11, 2026, 08:03:35 PM »
Curtis Harper helped me out in a big way with the rear fender and a few other essential parts.
NOS baby!
« Reply #33 on: June 12, 2026, 03:59:18 PM »
The Gilardonis are finally where they belong.
« Reply #34 on: June 14, 2026, 08:33:15 AM »
This was all that was left of the clutch throwout bearing ball cage.  Damage was done to the bore from the shards.  I will be sending this to Patrick for re-sleeving.
« Reply #35 on: June 14, 2026, 12:51:07 PM »
The transmission was a grimy beast.
Secrets of the 4 speed revealed.  Good news all the dogs look in great shape.
« Reply #36 on: June 14, 2026, 03:28:28 PM »
And now clean.
« Reply #37 on: June 17, 2026, 04:37:24 PM »
I have decided to tackle improving the seat.
Although the underlying foam is still quite resilient, the cover was slack and has some missing stitches in the passenger area.   The pan was rusty also.
I gave the cover multiple cleaning cycles with Goop hand cleaner, the non-abrasive kind and it turned out great.  More than I could have hoped for.
My son in law's mother is an expert seamstress, so I have enlisted her help with the sewing repairs.
I have watched a few YT videos and have come up with a plan to re-attach everything.  I hope it all works out.
The final step will be making an accurate stencil of the MOTO GUZZI for the rear seat and paint it on.
« Reply #38 on: June 20, 2026, 01:41:29 PM »
I carefully removed the cover and had the stitching repaired at a local upholstery shop.  They did a great job.
The foam was surgically removed from the pan and found to still be in very good shape over all.  The pan was sandblasted and painted.  After gently cleaning the foam it was reattached to the pan with spray adhesive.
I purchased some thin batting material that was more than big enough to cover the entire seat.  After spraying the foam and pan edges with spray adhesive the batting was applied and pulled taught all around.  I was afraid of wrinkles, but the batting material qualities let it conform to the seat with gentle pulling in all directions.
Gluing the cover back on came next.  Guzzi Paul recommended using 3M Windo Weld adhesive.  It sets up quickly.  With nervous apprehension I dove into it, gluing down sections held with multiple spring clamps from HF.
I am very happy with the end result.  It still has the aged look, but it is so much better than before.
« Last Edit: June 20, 2026, 01:43:35 PM by Dave Swanson »
Offline DoubleGuzzi
« Reply #39 on: June 20, 2026, 07:46:00 PM »
That's impressive stuff that you're doing there, especially the engine casings. I take it that you use something along with the nylon brushes, to get such a clean finish?
This bike is gonna look excellent at this rate.  :cool:
Nearly natural progression..
« Reply #40 on: June 20, 2026, 08:28:24 PM »
For the very hard to clean areas of baked on crud I used a combination of tools such as; a plastic razor blade, picks for the caked on crevices.  I used bronze bristle brushes on the very stubborn deposits.  Always with the goal of keeping the original finish under the grunge as undisturbed as possible.
« Last Edit: June 20, 2026, 09:01:38 PM by Dave Swanson »
« Reply #41 on: June 20, 2026, 09:14:58 PM »
Yesterday I drove out to the Guzzi Doctor to pick up my heads that Joe had went through for me.   He found them in good overall shape except for some fairly heavy pitting on both exhaust valve/seats.   He said that this led him to believe the bike had at least 2 extended layups with the exhaust valve open.  This info coincides with the theory for the crud found in the left cylinder.
After touch lapping the head gasket sealing areas on my granite surface plate I thoroughly washed them a few times followed with copious compressed air sessions.
This evening the heads were torqued in steps to 29 lbs.  I will let them sit overnight and retorque them tomorrow before finishing the top end assembly.
« Reply #42 on: June 21, 2026, 01:07:49 PM »
The old clutch plates showed little wear, but were completely oil soaked and stuck to the metal plates.   I assume the oil intrusion was from the pushrod seal leaking.
A new set of Newfren plates are in.
« Reply #43 on: June 21, 2026, 05:06:53 PM »
The timer had the typical divot at the bolt hold down area.  It was quite minor and shallow, which is another indicator this is a low mile bike.
I figured I might as well make it right for the next owner so I skin cut the divot out.
« Reply #44 on: June 22, 2026, 04:07:53 PM »
The mighty Ambo!
Offline Ratso88
« Reply #45 on: June 23, 2026, 11:56:52 AM »
Dave, you always seem to be doing such an awesome job on these projects.
I am envious. Keep it up, it’s very inspirational.
« Reply #46 on: June 24, 2026, 10:22:14 AM »
Rusty pan - no more.
Online cliffrod
« Reply #47 on: June 24, 2026, 09:02:00 PM »
Just a suggestion.  If you haven’t done a stencil yet, my wife has been doing some screen printing lately.  Instead of the typical emulsion process, she’s been using a Cricut machine and program ( via makers space at local library) to cut vinyl stencils to install on screens for t-shirts.  It’s a lot easier than cutting perfectly by hand like I do with some stone-related lettering stencils.
For a single use project, using adhesive vinyl typically used for decals to stick right to the seat should be no problem.
« Reply #48 on: June 24, 2026, 09:24:41 PM »
I hit it hard today.
New fork seals and I sprung for a set of Wirth progressive springs.  Its a bit like putting lipstick on a pig as these forks are very basic, but I figured every little bit will help.
« Reply #49 on: June 24, 2026, 09:34:29 PM »
That is a good way to do it.  I came to that same conclusion while trying to cut the stencil out with an Xacto knife.  HA.
I contacted a graphics maker that has made vinyl decals for my model airplane hobby in the past.  She is going to set me up with the stencils.
« Reply #50 on: June 27, 2026, 06:45:15 PM »
The heavy layer of grunge protected the VHB29s pretty well.  I was pleased to see a hint of yellow anodize still intact.  I spent most of the day cleaning them, but the result was worth it.
« Reply #51 on: June 28, 2026, 06:02:02 PM »
About 250 labor hours so far.
« Reply #52 on: June 30, 2026, 05:06:34 PM »
I decided it made all the sense in the world to inspect the transmission more thoroughly.
Since the caged ball throwout bearing disintegrated itself I knew the debris had to go somewhere.
This is what the cage is supposed to look like.
And this is what was left of it. It was ground to bits.
This is the result of those bits churning in the gear oil.  You are looking at where the 4th gear bushing rides.
A call to Harpers has a new layshaft and all 4 gear bushings on the way.
« Last Edit: June 30, 2026, 05:07:49 PM by Dave Swanson »
« Reply #53 on: July 05, 2026, 03:39:36 PM »
The transmission housings were turned in record time by Patrick Hayes, which is what he always does.   Beautiful work as usual.
You can see the stainless steel sleeve here.  A great repair of the scored areas.
This is the preselector housing mod for the oring. Super nice
« Reply #54 on: July 05, 2026, 03:45:12 PM »
USPS has been a little slow getting the 4 speed parts up here from Harpers.  While waiting I have been finishing up some of the dirty jobs that needed to be done.
The generator and starter were disassembled, cleaned up and lubed.
english font style keyboard
« Reply #55 on: July 10, 2026, 01:49:12 PM »
The transmission is back together with the new parts and is shifting like it should.
This transmission just didn't seem to want to go in without a fight.  Charlie came to the rescue and gave me a couple pointers that worked like a charm.
It is always a red letter day when the support box can come out.
Offline Pescatore
« Reply #56 on: July 11, 2026, 11:40:53 AM »
Fascinating job. When I grow up, I want to do the same.
Besides the bike,  I scrutinize your pictures to see what is hanging on the walls of your workshop.
Just nosey.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #57 on: July 11, 2026, 12:12:48 PM »
Grime before and after.
« Reply #58 on: July 11, 2026, 04:32:46 PM »
A productive day at the office.
« Reply #59 on: July 12, 2026, 08:58:24 PM »
Another productive day.
