Author Topic: V7 Stone loss of power  (Read 4918 times)
Offline Buddy Shagmore
« on: May 24, 2026, 05:52:30 PM »
Went for a ride today on my '24 V7 Stone Ten. About 5 minutes in, while in the fast lane on the freeway, I briefly lost power going about 70 in 6th gear. I immediately started to merge over to the right, and while doing so, the power returned. I exited the freeway at the next off ramp, and took the local boulevard back home.
In my garage, I took off the battery cover and tightened up the terminal cables. The + was tight. The - was not quite tight.
This is the second time this has happened in the 17 months I've had the bike.
I also checked the sidestand...it was fine. I also changed the traction control from level 2 to level 1.
Going forward, I'm gonna check those terminals more often.
The beloved pulsations only "con" I suppose.
Offline davethewelder
Re: V7 Stone loss of power
« Reply #1 on: May 24, 2026, 07:45:00 PM »
That sucks, I have the same bike.  But never had that problem.  I'd take it to a dealer and see if it shows any codes. Good luck.
« Reply #2 on: May 24, 2026, 08:59:01 PM »
Pretty sure it was the loose negative terminal cable again.
I'll take it out again tomorrow and find out. It sure is an unsettling feeling when you are riding and not sure if your bike will continue running. Check your battery cables fellas.
Offline Vagrant
« Reply #3 on: May 24, 2026, 10:47:09 PM »
I question the tank vent.
Online MikeP996
« Reply #4 on: May 25, 2026, 03:15:08 AM »
Seems unlikely that the battery connection could break, causing loss of power and then remake itself for the rest of the ride.  The first time it happened did you do the same battery terminal tightening?
2021 Moto Guzzi V7 850 Special (UK)
1976 Honda CB400F (UK)
2017 BMW R1200RS (TX)
'73 Norton Commando (Mexico
2015 BMW R9T (Mexico)
(Wife's bikes:
2015 Ducati Diavel (TX)
2019 Honda Africa Twin  (Mexico)
2021 Honda NC750  (UK)
Offline Vagrant
« Reply #5 on: May 25, 2026, 07:16:56 AM »
The more I think about it I did have the same thing happen on my 01 EV coming down Mt. Lemmon one day. Checked everything and when I got to the battery one terminal was a quite loose. I tightened it up and off I went. Same thing happened about a year later. It turned out a 20 year old original fuse had disintegrated from old age. I replaced them all with new Buss.
The first thing I would do today on any 10 year old bike is all grounds, new fuses and relays making sure to spray Deoxit in the receptacles.
« Last Edit: May 25, 2026, 07:18:28 AM by Vagrant »
« Reply #6 on: May 25, 2026, 07:47:52 AM »
My 2021 V7-850 had a pronounced hiccup (loss of power) at speed.  The cause of the hiccup resided in the Evap emissions system, and specifically the Evap control valve.
Many choose to go through the work to completely remove the Evap system, but I took the easy way out.
The Evap control valve is pictured below.  I removed the lower hose.  It is important to then cap off the Evap control valve.  It took me longer to figure out how to remove the side cover for the first time (instructions are under the seat  :wink: ) than performing the fix.
No more loss of power at highway speeds since.
I did buy a set of rubber caps, but if you have a good hardware store nearby you should be able to find a suitable cap.
« Reply #7 on: May 25, 2026, 08:52:38 AM »
Yes, the first time it happened, about a year ago, it was the negative terminal cable that was not tight enough.
The lovely pulsations from the engine eventually loosens it up. I'm going to keep a 10mm wrench in the tool kit.
Online DoubleGuzzi
« Reply #8 on: May 25, 2026, 09:40:28 AM »
A serrated washer anyone?
Nearly natural progression..
« Reply #9 on: May 25, 2026, 04:16:37 PM »
I had the same thing happen on a Bonneville 865.  Lost one of the squirrel condoms.  It was a $.99 fix.
Offline ridingron
« Reply #10 on: May 25, 2026, 10:11:07 PM »
Maybe try some thread locker, 242 or 222?
Blue (242) for 1/4" or larger.
Purple (222) for 1/4" or smaller.
Online MikeP996
« Reply #11 on: May 25, 2026, 11:16:35 PM »
Interesting - I've had several old bikes that are known "shakers" and never had a battery terminal loosen.  But I never owned a Moto Guzzi prior to this V7 850; guess I'll have to closely watch those terminals. :)
(Wife's bikes:
Offline malik
« Reply #12 on: May 27, 2026, 09:27:04 PM »
Talking battery terminals - while you are there make sure every now & again you clean the terminals & lugs AND smear on a thin film of vaseline/petroleum jelly - to ensure a better contact. The screws should be tight, by the way.
« Reply #13 on: May 31, 2026, 06:17:59 PM »
Good advice.
So today I took it out for a 20 minute ride and there was no further issue. It had to have been the slighly loose negative terminal. I did put a 10mm wrench in my tool bag, and my insurance roadside assistance card in my billfold, just in case.
« Last Edit: May 31, 2026, 08:11:29 PM by Buddy Shagmore »
