Author Topic: Breva sport clamps on standard Breva  (Read 4948 times)
Offline macaril@optusnet.com.au
« on: May 26, 2026, 01:58:18 AM »
Hi
Will the Sport clamps bolt straight onto a standard Breva, or do you need a new fork yoke also
Cheers
Rob
Offline Jon8V
Re: Breva sport clamps on standard Breva
« Reply #1 on: May 26, 2026, 06:35:55 AM »
Top triple is the same. The Sport clamps mount in place of the riser bars used on the Breva.
« Reply #2 on: May 27, 2026, 04:45:38 PM »
straight swap if you can find 'em
I did this on my Breva 1100
I run a ProTaper bar 'KX High'
« Reply #3 on: May 27, 2026, 06:04:39 PM »
Thanks Chad, appreciate that, I assume those bars don't have threads on the end for the bar end weights, or do they
Cheers
Rob
Offline Jon8V
« Reply #4 on: May 27, 2026, 06:11:36 PM »
Do the OEM wires and cables have enough slack or did you have to extend any?
« Reply #5 on: May 27, 2026, 08:47:00 PM »
One more question, did you have to drill the handlebars to fit the controls ? I have read elsewhere this is required
Cheers
