Author Topic: 850T-3 Not Charging  (Read 15870 times)
Offline Piston Broke
Re: 850T-3 Not Charging
« Reply #30 on: June 13, 2026, 09:34:03 AM »
New diode board is installed and still not charging. I noticed that one side of the three-prong spade connector had potting epoxy dried on it. I filed off enough to fit the plug but maybe I need to pull the board back off and clean that spade better. The bottom looked clean so I thought it would make a good connection. Otherwise it's time to find one bad wire throughout the bike, a daunting task for me to say the least. I'm open to any specific advise on what exactly to check and how to check it. I've had plenty of people say "you've got a bad ground" without any information as how to find a bad ground within the 1/2 mile of wires. Thanks a ton for everyone's help thus far, Cheers!
Online Tkelly
« Reply #31 on: June 13, 2026, 09:38:05 AM »
Probably not your issue but is it possible that you lnstalled the new board incorrectly?Dont ask how I know.
« Reply #32 on: June 13, 2026, 09:50:02 AM »
 I guess you can't read service manual, it TELLS you how to test each part. It is all there in black & white for the reading.
« Reply #33 on: June 13, 2026, 11:35:16 AM »
Ouch! My Haynes manual does not go into detail, just says "check". But I read zero volts at the alternator with the bike running. Again it says to take to a specialist for inspection. My service manual does not go into details that I could find either. Sorry, I'm lost and just need some help to diagnose the issue instead of just throwing more parts on it that I may or may not need. Thanks for any other advice.
Online n3303j
  • Ron Cichowski
« Reply #34 on: June 13, 2026, 11:50:45 AM »
Looked at your profile, no location.
Wondering where you are located.
Must be someone in your neighborhood who could pop over and lend a hand.
Lots of wires, but decent documentation. So time and a meter will provide an answer.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online n3303j
  • Ron Cichowski
« Reply #35 on: June 13, 2026, 12:13:43 PM »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #36 on: June 13, 2026, 01:27:02 PM »
factory manual
Offline Moparnut72
« Reply #37 on: June 13, 2026, 06:06:50 PM »
The Haynes manual I have is awful. It assumes too much and doesn't go into detail. I have a replacement diode board and regulator, I haven't gotten far enough along to run the motor so I can't report. I have done my own wiring and left a lot of the factory stuff out. The project is on the back burner at the moment, riding weather and yardwork etc is taking more of my time.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #38 on: June 15, 2026, 09:07:07 AM »
I'm in Grand Rapids, MI. I do have a friend to help but he is currently out of town.
Online Dukedesmo
« Reply #39 on: June 15, 2026, 10:16:40 AM »
Assuming your rotor/brushes are good, have you checked the voltage at the brushes? Asking because, as per my post a few up, mine was not charging and when I measured the voltage at the brushes, there was nothing.
The cable to the alternator on mine has 5 wires in it; 3 (phases) to the alternator output, a +12v to one brush and a feed to the centre winding of the stator with the second brush taking it's feed of 12v- from the ground through the casing (apparently some bikes have 6 wires, of which the extra is a 12v-/ground to the second brush).
The connection to ground on mine was 'dodgy' and adding a wire direct from battery to the brush appears to have fixed it, either way it can't hurt.
Above pic shows the alternator; red clip is on one brush, white to centre feed of stator, the second brush (inbetween) has a tab for a cable but no wire connected, it simply takes it's power through the body of the stator and that is where I added the new, direct from battery -ve to.
« Last Edit: June 16, 2026, 03:04:44 AM by Dukedesmo »
Le Mans II
Ducati 916
Ducati M900
« Reply #40 on: June 15, 2026, 11:31:56 AM »
Duke, minor issue but the brushes should be at 12 o'clock for gravity purposes.
« Reply #41 on: June 15, 2026, 12:36:42 PM »
There was a service bulletin to put them on the side because in the vertical plane they would bounce and loose contact on rough roads.
Online n3303j
  • Ron Cichowski
« Reply #42 on: June 15, 2026, 01:27:14 PM »
"Gravity Purposes" ??? First time I've ever heard that one! What are they, about 3 grams each. More disruption from bumps rather than gravity being misaligned.
But the spring pressure is supposed to exert about 250 - 350 gramd downward on the brush to guarantee intimate contact. The spring will install in two orientations 180° opposed from each other. One installation puts about 1/4 turn tension against the brush. This is wrong and will allow the brush to bounce and arc,  ultimately burning the contact rings. The other mounting location puts about 3/4 turn preload on the spring and about 250 - 350 grams thrust load on the brush. This is correct and the slip rings will last forever.
« Last Edit: June 17, 2026, 08:14:10 AM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Dukedesmo
« Reply #43 on: June 15, 2026, 05:48:27 PM »
OK, interesting but AFAIK they've been like that for nearly half a century, sure I've removed the alternator a couple of times but refitted it as it was.
Seems to work OK so I'm minded to leave it as is.
« Last Edit: June 15, 2026, 05:49:37 PM by Dukedesmo »
Le Mans II
Ducati 916
Ducati M900
Offline Moparnut72
« Reply #44 on: June 16, 2026, 07:17:10 AM »
I have a partially disassembled T3 which I just checked, the brushes are at 12 O'Clock.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online n3303j
  • Ron Cichowski
« Reply #45 on: June 16, 2026, 07:23:32 AM »
My 1966 850 T3. This orientation worked well with the stock length harness connections.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Frenchfrog
« Reply #46 on: June 16, 2026, 07:41:41 AM »
12 o'clock was the standard original position but it was superseded because it tended to aggravate brush bouncing.
I moved mine to the recommended position decades ago even though it seemed to work fine...zero issues in either case !
« Reply #47 on: June 16, 2026, 10:48:47 AM »
OK, I stand corrected.
« Reply #48 on: June 18, 2026, 05:23:27 PM »
Well F! I think I just let the smoke out of my new diode board. I was trying to check continuity beween the alternator ground and the battery, nothing, so I turned on the key, still nothing. No tools touching the bike, I switched the key off and heard a "foof" and saw a puff of smoke by the fuse box diode board area. All fuses are in tact. :shocked: :angry: I don't see anything burnt on the diode board but I don't know what just happened. @ guzzisteve, thank you for the service manual page. What part of the diode board is the anode and cathode? There are 7 prongs on this thing, I have it removed again. Is anyone near Grand Rapids, MI? Facetime call? I am so frustrated. Thank you for all the responses thus far!
« Reply #49 on: June 18, 2026, 07:03:26 PM »
I think anode's are on one side & cathodes are on the other. The whole body of that board is hot (+) If you burnt something it would be colored brown or black on the grey coating.
There IS a guy in Grand Rapids, Jamie Muller aka Grand Rapids Guzzi. Past Guzzi Dealer. I sold him his 1st Guzzi at a shop in Chi Hts, IL in 88
Online Frenchfrog
« Reply #50 on: June 19, 2026, 04:53:59 AM »
Honestly I don't think there is any right or wrong here BC.The brush bouncing idea is plausible but I can't see it being that much of a problem .I changed mine after reading the tip in Guzziology simply because I utterly respect Dave Richardson's advice.
The biggest improvement to thee systems is likely to be a solid state and adjustable  voltage regulator. The original mechanical ones work but fine tuning them to get optimal voltage is virtually impossible.
Offline Moparnut72
« Reply #51 on: June 19, 2026, 07:36:10 AM »
That is exactly what I am doing to mine. I am not even going to fool with the original equipment, new fuse block as well. None of it was very expensive.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
