Hey everyone. Yes a slow cranking issue. When it first happened I assumed another battery had gone down but apparently not. I now have a new battery and it's the same . Seems if I play around with everything , battery leads , terminals etc it usually comes back to working and I think I've fixed it . Then after a couple of journeys it'll go back to very slow cranking followed by clicking solenoid. The starter is a relatively new valeo . Looking at the bike this seems a simple circuit , battery , leads , solenoid , starter. I know smaller bits like a relay and the ignition switch are connected but I'm guessing none of those would cause this apparent lack of current at the starter ?
.. whilst checking the other end of it I found this..
That disnae look good! BTW, 14.8V is the full charge voltage for AGM batteries.
Back on track; this is why I like a mini-voltmeter on a bike, even more so when using LiFePO4 batteries. Wiring and electrical components can have a harsh life on motorcycles.
Simple enough to add. ..
