Author Topic: Attempted valve check  (Read 5567 times)
Offline Rons
« on: June 08, 2026, 06:36:25 PM »
I started the valve check/adjustment on my 2026 V7 Sport tonight.
Got as far as removing the spark plug cover. I could not get the spark plug boot off. Been working on cars and motorcycles since high school. I twisted and tried to pry up with a screwdriver. Also tried a pick to “break the seal”. Tried needle nose pliers and mini pliers.
Finally pulled straight up and ….. broke the cap right off. I swore so loudly that the WILDguzzi members in Connecticut probably heard me.
What is the “trick” to removing these spark plug caps? And why is it so difficult?  If this bike wasn’t so charismatic, I might sell it and stick with my Triumph. I had a Ducati 900ss carby and out 33k miles on it. Changed plugs many times with no issues.
Ugh, I’m so frustrated.  So now I have to replace that plug wire nd figure out how to get the other plug wire off.
Any suggestions? I’ve seen some videos on the 4V and 1400 motors using zip ties and special tools. The vids I watched with the V7 models all showed the guy twisting and pulling the plug wire right off. 😡
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Attempted valve check
« Reply #1 on: June 08, 2026, 06:52:02 PM »
Are they different from the V7 III and early V9? If not, I haven’t had such problem. I wiggle and rotate, and eventually they’d pop off. But hey—aren’t these plugs and wires known to be subpar in quality anyway? If so, consider this an opportunity for the upgrade…just more immediate than anyone would prefer.
Offline Rons
« Reply #2 on: June 08, 2026, 07:14:58 PM »
Not sure if they changed for 26 with the different injectors and other upgrades. There appears to be a hard tube in the rubber, and that broke off as well. Pretty piss poor design if you ask me.
« Reply #3 on: June 08, 2026, 07:32:39 PM »
I THINK…. The go to method is to get some strong cord or string and wrap it around the porcelain plug shank, then pull up on the string to effectively apply the force to the base of the plug cap.
I’m fairly sure this is the go with 8V big blocks…(Stelvio, Norge et al…)
Might be wrong, I’ve never owned either one…(Never will)
Offline Rons
« Reply #4 on: June 08, 2026, 07:58:35 PM »
Anyone know of a good aftermarket plug wire for an E5+ specifically 2026 V7 Sport?
Offline Vagrant
« Reply #5 on: June 08, 2026, 11:09:11 PM »
Mine were a bitch also and so were the new v85's. They did come off though. I made sure I had a coating of Vaseline in them when I reinstalled.
Online Dukedesmo
« Reply #6 on: June 09, 2026, 03:36:40 AM »
Agree with some kind of grease/vaseline when fitting is likely to help, on a similar theme I always put a light smear of copper grease on sparkplug threads to ensure they don't get stuck in the head.
I had similar happen on my Ducati Monster, front cylinder (more exposed to weather than the rear) where the internals of the plug lead/cap stayed on the plug due to corrosion whilst the silicone lead came away.
I suppose the positioning of Guzzi plugs makes them likely to corrode especially if left outside/ridden in rain.
Le Mans II
Ducati 916
Ducati M900
Offline Perazzimx14
« Reply #7 on: June 09, 2026, 05:02:06 AM »
It doesn't look like there is enough room for the string to pass between the valve cover and spark plug cap.
Online faffi
« Reply #8 on: June 09, 2026, 05:13:03 AM »
I do not remember if the hole in the cover is large enough to be lifted off the remainder of the cap or not, but if not it should give good leverage to wrestle the remains off. I do not recall any particular issues removing the ones on my V9, I just turned them back and forth a few times to break the seal.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline Rons
« Reply #9 on: June 09, 2026, 05:34:52 AM »
[/quote]
My V7 has 900 miles on it. The caps were not corroded. They just would not come off. I’ve never seen anything like it.
Offline Rons
« Reply #10 on: June 11, 2026, 08:02:39 PM »
I finally had some time to work on the V7 Sport. The other spark plug cap came right off with a bit of a back and forth twist.
So I went ahead and did the valve check. Both exhaust valves were right on at.006. Both intake valuables were a bit loose as a .005 would fit right in. Adjusted them to a .004 and put it back together.
Now I need to address the broken spark plug cap.
Does anyone know if I can purchase one and clamp it on, or will I need to buy a pre made wire and replace the whole thing?
Thanks for any suggestions.
« Last Edit: June 13, 2026, 02:36:49 PM by Rons »
Offline mechanicsavant
« Reply #11 on: June 12, 2026, 06:22:59 AM »
Vaseline is petrol based & bad for rubber , dielectric grease is silicone based , much better for any electrical connection !
Offline Rons
« Reply #12 on: June 13, 2026, 02:38:42 PM »
Ok, went to the dealer and bought a new spark plug wire cap.
It just screws onto the wire. Very easy fix. Dabbed some dielectric grease on each plug cap so this should be easier in 6,000 miles.
Alls well that ends well!
« Last Edit: June 13, 2026, 02:39:33 PM by Rons »
Offline moto-uno
« Reply #13 on: June 17, 2026, 12:59:17 PM »
  As it is "dielectric grease" is made to prevent electrical transmission ! It works fine if it's applied to the rubber plug boot , but not
to get on the metal cap that contacts the plug lead . People get away with it , but , just apply some to the porcelain of the plug and
then it's weather sealed and prevents moisture from creeping up under the plug cap .
Offline Moparnut72
« Reply #14 on: June 17, 2026, 04:55:30 PM »
Peter, I am glad someone else is saying this. I have in the past and was told I was wrong. If this is put on contacts conduction of energy is compromised. It is to keep moisture out, kind of like WD40 which is generally used as a lubricant. It does have some lubricity properties but that isn't its main function which is water displacement.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Dirk_S
« Reply #15 on: June 17, 2026, 05:08:11 PM »
Don’t worry—I’ve read that in time dielectric grease eventually becomes conductive. That said, I’ve also read that so long as there’s a strong connection (think battery terminals and other pressure-clamping-style connections), the electrons will still flow fine, but it would do well to see more experienced folks comment on that.
Offline buck
« Reply #16 on: June 18, 2026, 08:53:45 AM »
The ignition system produces many 10’s of thousands of volts. Air is a great insulator. Since the spark can jump through in excess of a quarter inch of air gap, Dielectric grease is not going to inhibit conductivity.
Vaseline is definitely the wrong product. Truthfully, I don’t like any substance getting on the porcelain of a spark plug because it can provide a path for the spark to travel down the outside of the plug and cause misfires.
Offline Rons
« Reply #17 on: June 18, 2026, 09:42:57 AM »
I added a dab of dielectric grease to each spark plug boot. Just enough to prevent ( I hope) the boot from sticking next time I have to remove it.
It was not as big a deal as I thought. I was having nightmares of past experiences with cutting and crimping spark plug wires. These simply screw on and off, easy-peasy. Center spike screws into the middle of the wire, no tools or skill needed.
However, as a MG owner, I would like to prevent the unneeded expense of $41 for a new boot, if possible. LOL….
Offline DoubleGuzzi
« Reply #18 on: June 18, 2026, 09:50:58 AM »
I disagree. You *may* get a capacitor from the grease though.
(Many moons ago, I was a Snr. Tech. in a high voltage lab. Just a bit of useless info.)
For giggles, I tried Google AI:
Dielectric grease is a significantly better electrical insulator than air. Because its silicone or synthetic base lacks free electrons, it actively prevents current flow, arcing, and short circuits. While air can break down and conduct high-voltage electricity (arcing), dielectric grease provides a dense, protective barrier against the elements..
 Use on spark plug boots, battery terminals, and multi-pin electrical connectors to prevent moisture buildup, fretting, and corrosion. It is also highly hydrophobic, making it ideal for weatherproofing exposed connections.
« Last Edit: June 18, 2026, 09:56:33 AM by DoubleGuzzi »
Nearly natural progression..
Offline buck
« Reply #19 on: June 18, 2026, 03:15:58 PM »
You’re welcome to disagree. I will stick with what I learned from manufacturers including Porsche, Mitsubishi, Ford, Harley-Davidson and others during 30 years as a certified master technician.
