Author Topic: Front Rotor Rattle  (Read 2710 times)
Offline mechanicsavant
Front Rotor Rattle
« on: June 15, 2026, 07:49:20 AM »
On my 21 V7/850 I’ve noticed a rattle after about 20 miles or so . If I put 1 finger on the front brake lever no rattle ! The brakes don’t seem to be dragging & checking the rotor with a heat gun no excessive heat is seen . Rear rotor & font rotor are within 10 deg. Of each other . Once bike has set about 30 Min. Or so rotor seems to be tight again ! Anyone else noticing this ?
Re: Front Rotor Rattle
« Reply #1 on: June 15, 2026, 07:57:26 AM »
Earplugs.
Offline DenverSteve
« Reply #2 on: June 15, 2026, 08:37:20 AM »
No. But if I did notice my front brake rotor rattling I would have it checked out immediately.
Steve
2023 MG V85TT Adventure
Offline DoubleGuzzi
« Reply #3 on: June 15, 2026, 10:31:39 AM »
Google for fixed, semi-floating and fully floating discs.  :wink:
You ain't heard rattling until ya hear Laverda Formula front Serie Oro discs!
« Last Edit: June 15, 2026, 11:01:53 AM by DoubleGuzzi »
Nearly natural progression..
Online Tkelly
« Reply #4 on: June 15, 2026, 12:13:01 PM »
Replaced those on a 14 Stelvio,let me know if you want them,no rattles.
Offline azccj
« Reply #5 on: June 15, 2026, 04:38:31 PM »
Both the front brake rotors on my 2022 V85TT rattled quite a bit. Not all that long ago you could buy OEM Aprillia rotors for a little over $100 a piece, part #856774, but they are now discontinued. Luckily, I bought a pair from AF1 over a year ago and just recently installed them on the V85TT.
2023 V100 Mandello S
2007 Norge
2003 V11 Le Mans
2000 Jackel
99 EV
« Reply #6 on: June 15, 2026, 05:25:44 PM »
The V7 floating rotors are known to be pretty loose/rattly.
Some have gotten them replaced under warranty for supposed excessive movement.
The one on my 2013 is downright noisy at times, but it doesn't adversely affect braking and I saw no need to replace it when I installed new pads this spring.
