Author Topic: New 1980 V1000 G5 Project  (Read 26066 times)
Offline Rineheitzgabot
« on: June 15, 2026, 12:24:22 PM »
Hi Gang,  I'm thankful to have found this great forum for my new project to document, and hopefully receive advice from you experts.  It's an'80 V1000 G5, and is in pretty good shape.  Been in a garage for years, and no rust or damage, with the exception of a few knicks and the obligatory missing reflector, ah-hem, etc.
I am hoping some of you can start me off as I don't know where to start.  I'm not a seasoned restorer, just tinker with a used bike or car and refurb, mostly.  Bought a new battery, plugged 'er in and a puff of white smoke from the fuse box was all needed to unhook, and begin studying and messing around.  Hooked the battery back up and cannot get any action from the start button.  Bridged the solenoid and heard the starter spin and whine, but no engagement with flywheel.  I understand this could be due to lack of a good amp flow, but would like anyone's thoughts on this.
Do I jump in to the "new harness" route?  Are there obvious things I should try first?
What I would like to do is hear it run, and become somewhat reliable, then tear it down for a good refurb.
Any and all thoughts welcome.
Re: New 1980 V1000 G5 Project
« Reply #1 on: June 15, 2026, 06:21:14 PM »
Welcome to the forum, and congrats on the project.
The G5 is a good machine, but is a low value bike even in great shape.  You will need to be careful on your spending, unless you are just doing for the fun, and expense be hanged.  An approach I have been known to take.
The bare wire next to the rectifier regulator is certainly not a good sign.  This leads me to believe that there may be a number of other bodges electrical and otherwise to sort.
Before giving the bike anymore opportunities for smoke events I would systematically check the wiring from tip to tail.  This will be a great way to familiarize yourself with the E system on this bike.
If you haven't found This Old Tractor yet, it will become your bible.
Study the wiring diagram in this manual.
https://www.thisoldtractor.com/mg_manuals/workshop_manual_g5_sp.pdf
Offline DC950
« Reply #2 on: June 15, 2026, 06:29:20 PM »
I'm in a similar situation on a 79 V1000 that, let us just say, was in far worse shape than was disclosed (or possibly understood by the elderly owner if I'm being charitable).  It was an electrical mess and I've spent around 40 hours straightening it out.  This includes 2 garages, the side of the road, next to a dumpster in an apartment complex, and a hotel parking lot.
That 2nd picture is the rectifier.  Is that where the magic smoke was let out?
Unless the existing harness is completely disconnected, you will not need to replace the entire thing to get the bike running.  But you will spend a lot of time on it.
I'd recommend you get it running to see what you have before spending money on a harness.  Considering mine is now blowing gear oil all over the shaft and back off the gearbox and has an engine oil leak that shows up from the clutch bell housing, I'd been even more upset if I'd jumped to a new harness and spent even more money on this shitheap.
I intend to replace the harness connected to the front side of the Molex connector this winter.  After I fix the leaks.
If I don't set it on fire to burn out some stumps in my yard...
« Last Edit: June 15, 2026, 06:30:32 PM by DC950 »
Motorcycles.
« Reply #3 on: June 15, 2026, 06:32:10 PM »
For something easy to start with.  Drop the engine oil and then drop the pan.  Don't forget about the 4 long bolts toward the center of the pan.  The pan will need a nudge or 2 or 3 with a good soft hammer.  Don't get too aggressive with the blows.  Have a look around in the sludge.  Hopefully you won't find any bits that are worrisome.   Then get the sump hospital clean.
Online Groover
    • Scooteropolis
« Reply #4 on: June 16, 2026, 08:18:56 AM »
Also, if you do get new wiring, get it from Greg Bender, but I would also start with studying the wiring diagrams - take note of the dash type on the G5 models.
https://www.thisoldtractor.com/moto_guzzi_tonti_wiring_diagrams_-very_large_and_easy_to_read-.html
(Edit: Noticed Dave Swanson had already pointed you in the right direction)
« Last Edit: June 16, 2026, 08:32:45 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #5 on: June 16, 2026, 11:06:24 AM »
Thank you gentlemen.  Much appreciated.  More pics.  Can anyone identify the circled cluster on the right grip side?
« Reply #6 on: June 16, 2026, 01:52:15 PM »
The switch is non Guzzi and quite old itself.  Since there isn't any auxiliary lighting on the bike it rules out being a switch for them.
It could be that the stock start/kill switch has failed and it was wired in as a substitute.
Again studying the wire paths against the schematic should tell the tale.
« Reply #7 on: June 16, 2026, 01:57:10 PM »
Besides having This Old Tractor becoming your best friend, search out a copy of Guzziolgy by Dave Richardson.  You will pat yourself on the back for it.
Online Groover
    • Scooteropolis
« Reply #8 on: June 16, 2026, 03:35:09 PM »
If you want to start with one wiring area, target the headlight interconnect - a lot goes through that and replacing it may help clean up a lot of the rest.
1980 Vespa SI Moped
« Reply #9 on: June 17, 2026, 08:31:36 PM »
That switch was for police accessories - siren, pursuit lights, etc.
« Reply #10 on: June 18, 2026, 05:38:53 AM »
Good to know!  I had never seen one.
« Reply #11 on: June 18, 2026, 07:59:43 AM »
All of a sudden I have seen 2 of these switchgears in as many days.
There is a Convert on FB marketplace reported to be a California police bike.  Looks like a nice rideable and functioning bike for $3600
https://www.facebook.com/marketplace/item/1317649490480506/?ref=browse_tab&referral_code=marketplace_top_picks&referral_story_type=top_picks
« Reply #12 on: June 19, 2026, 11:58:01 AM »
Thank you!  I suspected that.  Must have been OEM as well, since there is an actual indicator light on the dash cluster that is not shown in the standard owner's manual.
« Reply #13 on: June 23, 2026, 12:32:37 PM »
It didn't run when I got it.  Turns out it was not too far from running.  https://youtube.com/shorts/ad81FSTl8C4?feature=share
Offline Roman Hordan
« Reply #14 on: November 10, 2026, 02:30:29 AM »
Nice, great to see it running. Sounds like the original "bridged the solenoid and the starter spun but didn't engage" issue got sorted somewhere along the way. Did you end up finding what was behind it? That's useful to know for anyone else who hits the same thing on a G5.
Now that it's alive, I'd do the oil and filter change and have a look in the pan before you ride it much, like Dave suggested. Then I'd go through the charging side while you're in there, since that bare wire by the rectifier/regulator still bugs me. Check the battery voltage at the terminals with it running at around 3000 rpm. If you're seeing roughly 13.5 to 14.5V, you're in decent shape; if not, start with the regulator and its connections.
Keep us posted on the teardown plans.
Offline wirespokes
« Reply #15 on: November 11, 2026, 07:13:34 PM »
Well done getting her going. Sounds good!
Others might say T3s and they're variants are low end and not worth spending energy/time on, but I feel differently. They're easily transformed into what you want and great running machines. I've got a 79 G5 that's turning into my favorite bike - and I've got a LeMans 3 and 4. It also doesn't take much money to make one nice, but it will take time and energy and elbow grease.
