Author Topic: 98 V11 EV clutch cable gets hot, no spark  (Read 2210 times)
Offline bputney13
« on: June 15, 2026, 04:04:15 PM »
Hello,
I just acquired a 1998 V11 EV and it won't start.  When the key is in the On position, the clutch cable gets hot to the touch in a few seconds.  I also have no spark.  I think I am missing a grounding strap from the battery to the engine/transmission.  I do have one from the battery to the frame, and one from the battery to the ECU.  Do you think my hypothesis has merit?
Thanks,
Brett
Re: 98 V11 EV clutch cable gets hot, no spark
« Reply #1 on: June 15, 2026, 05:17:08 PM »
Should also be one that goes to 8mm stud on starter from batt, may have to put up sidestand for spark(switched on stand).
