Author Topic: 2024+ V85 Givi Tank Lock  (Read 1496 times)
Offline YellowDuck
« on: June 19, 2026, 03:01:29 PM »
Since I couldn't find this info anywhere (including on Givi's site), and had to find out myself through experimentation, let me report that the  the Givi Tank Lock flange #BF46 works just fine on the newer V85s.
The flange also comes with some milled pieces you are supposed to bolt under the steering stem to limit the steering lock.  I didn't even try to install those so I don't know for sure if they would have fit.
The bag in the photo is the CRM108 - pretty much the simplest Givi tank lock bag you can get.  There is no way it is really the advertised 8 L capacity, but anyway it is still pretty much what I was looking for - just big enough to hold gloves, phone, wallet, water bottle, ear plugs etc, but small enough not to interfere at all when I'm riding.   The phone pocket is too small for my Samsung S10, but anyway I don't use my phone when I ride.  I'll likely use to pocket just to hold pieces of paper that I have written directions onto.
The tank lock system works great, but the way the front of the bag hovers above the tank is a little weird.  I still think it is worth it for the convenience, compared to dealing with straps.
« Last Edit: June 20, 2026, 09:14:37 AM by YellowDuck »
Offline YellowDuck
Re: 2024+ V85 Givi Tank Lock
« Reply #1 on: June 19, 2026, 03:05:44 PM »
That magnetic tank bag on the V7 you can see in the background is the bomb.  I've had it for 25 years, used it on three different bikes.  It stays perfectly secure, is quite flat but also expandable with a 360-degree zipper, and has a HUGE map pocket.  It was made by Joe Rocket and I think I paid $65 for it.  Too bad the V85 tank is plastic.
Offline Kildareman
« Reply #2 on: June 20, 2026, 02:21:54 PM »
Take the tank off and remove the cover panels and stick either magnets of the opposing pole to your tank bag or steel plates in the appropriate positions to match your tank bag magnets. Should work then.
V85 Strada
Offline Bulldog9
« Reply #3 on: June 20, 2026, 09:53:33 PM »
I just installed mine, got it from Moto Machines. Not a fan of the angle of the bag on the downward side of the tank, but it is what it is. I have a smaller tank bag that I've had for the Griso for 10 years. Its great for small things, but when taking longer rides I use the monstrosity pictured. Found the extra size very useful when on a long trip and kept me from having to go in the topcase.
I did install the steering stops. When at full range the bag was hitting the handlebar switches.
MGNOC#23231
