Author Topic: 2026 V7 E5+ Evap bypass question...  (Read 4515 times)
Online Michael_A
    • Penguin Video Productions
« on: June 30, 2026, 05:52:04 AM »
Hi All,
This is NOT a question on how to bypass the evap system in the above referenced bike, but rather what are the expected improvements one could expect?
On mine, I've noticed irregular idle when hot in traffic; very low speed throttle response is at times "twitchy"; and hot starting seems to sometimes involve longer cranking.
I'm familiar with how the system is SUPPOSED to work, but at the end of the day it's really creating a vacuum leak with an opportunity for an over rich mixture. Sometimes. Never mind the issues of potentially creating a pressure differential (to atmosphere) within the fuel tank.
So I did the bypass (blocking the line between the valve and intake manifold) and inerted the tip over valve (tank basically venting to atmosphere via the carbon can), runs and idles fine in the shop, but won't get a chance to get it out for a few weeks (traveling).
Are these the expected symptoms one can expect to have cleared up?
Re: 2026 V7 E5+ Evap bypass question...
« Reply #1 on: June 30, 2026, 07:03:48 AM »
Obviously you think so right because that's why you tried it, no?
But you don't think the engineers considered the "potential vacuum leak" or "pressure differential" when they designed the bike?
Well, let's wait and see if any of your troubles return and, if they do, then you'll know.
And if they never do, then you'll know.
The one and only time I eliminated the system (Jackal) I later found my garage smelling like gas in warmer weather. I would also think you should be more careful not to overfill the tank now.
I'll be interested to see if it solves your problems.
Online YellowDuck
« Reply #2 on: June 30, 2026, 07:54:34 AM »
This is 100% why I did the mod on my V7 850 (2023).  At low throttle angles, the engine would not respond at all, then with a bit more throttle the bike would lurch forward.  It was basically impossible to ride smoothly at slow in-town traffic speeds.  Properly removing the EVAP system was a 100% instant fix, for $0.  Other people don't report any such problems with the stock system, so it could be that it varies bike to bike.
I think you are going to want to remove or at least disconnect the EVAP can, or it will get saturated with fuel.  Just let the tank vent line hang loose under the bike, like on every motorcycle ever made up until some time in the early 2000s.
Online Moparnut72
« Reply #3 on: June 30, 2026, 08:44:36 AM »
I deleted the whole system on my '26 Special. I it improved low speed running on mine substantially. It does like to be warmed up for a few minutes before riding off. I let it run while putting my gear on. The only jerking I get is from not holding the throttle steady, which I believe is from ride by wire throttle. Not enough resistance to keep from being steady with and the responsiveness of the engine. I have taken to holding either the bar end weight or the switch housing with the grip to steady my hand.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online MikeP996
« Reply #4 on: June 30, 2026, 09:25:26 AM »
I bypassed mine a couple of months ago hoping for improved low speed tractability; it made no difference so I un-bypassed it.  I then installed a "Rapid Bike Fueler" in hopes it would do what I wanted and it made a huge improvement.  I'd like to try an upMap just out of curiosity to see if it can be even better - you know, as good as carbureted motorcycles were! ;)
2021 Moto Guzzi V7 850 Special (UK)
1976 Honda CB400F (UK)
2017 BMW R1200RS (TX)
'73 Norton Commando (Mexico
2015 BMW R9T (Mexico)
(Wife's bikes:
2015 Ducati Diavel (TX)
2019 Honda Africa Twin  (Mexico)
2021 Honda NC750  (UK)
Offline jbhotchkiss
« Reply #5 on: June 30, 2026, 11:57:05 AM »
Bypass AND Upmap on my Stone Ten - HUGE improvement!
Online Michael_A
« Reply #6 on: July 11, 2026, 03:46:22 PM »
Update on my evap bypass; Low speed running is MUCH improved, as is hot starting and idle quality. Drive-ability in traffic (stop and go, very low speed) is dramatically different and improved. Just pulling away from stoplights feels much easier and low speed response and throttle modulation is definitely improved. Yeah, I may smell gas in the garage SOMETIMES, but no worse than any other old school bike with carbs. No downside that has revealed itself yet. I may pull the canister and "clean things up" under there in the near future, as things stand now they are fully reversible should this experiment not work, but so far it has yielded a marked improvement.
Offline davethewelder
« Reply #7 on: July 11, 2026, 07:26:59 PM »
On my 2024 Stone Ten, its stock and have removed nothing.   It runs so sweet im afraid to add a Up Map or delete any emissions.   Now my 2022 (traded off) V85TT had  flat spot around 4000 rpm's, nothing I did helped, deleted everything even tried a V Twin Boost and a Rapid Bike tuner, nothing.  Maybe the "TEN" has a tune for the Arrow pipes.
Online MikeP996
« Reply #8 on: July 11, 2026, 11:59:11 PM »
I'm tending to think that if bypassing/removing the Evap does anything it's because the system isn't working correctly - clogged, etc.  From reading it appears that FROM THE FACTORY the one way valve is occasionally installed backwards.  Also, filling the fuel tank to the point where most of us filled fuel tanks in the past can apparently cause raw fuel to enter the system and cause the problem.
However, the above is just from reading internet accounts NOT from any knowledge of how the system actually works...and the fact that on my '21 V7 special, bypassing the system had no effect at all - there was absolutely no difference in how the bike ran with/without the system.  Seems unlikely to me that the Evap system, if functioning as designed, would cause some bikes to run poorly at low RPM and others to run well.
(Wife's bikes:
Online YellowDuck
« Reply #9 on: July 13, 2026, 08:30:57 AM »
That would be bad - whenever the purge valve opened it would draw vacuum directly to the fuel tank.
