Author Topic: A Very Ambitious Ambassador Project  (Read 110601 times)
Re: A Very Ambitious Ambassador Project
« Reply #30 on: October 05, 2026, 06:49:06 PM »
I am all for patina, but the original front fender was a bit much.
The fender I got from Harper's is a perfect match for the original rear.
« Reply #31 on: October 07, 2026, 10:12:42 AM »
I bought this V700/early Ambo taillight a long time ago, just in case.
« Reply #32 on: October 09, 2026, 04:52:34 PM »
One of the big ticket items for this bike was the instruments, which were missing from the pile.
Harper's to the rescue.
Offline Roman Hordan
« Reply #33 on: October 13, 2026, 08:06:33 AM »
Nice, the new fender next to the original rear makes a good case for it. Original front was too far gone to leave as is, and now the ends of the bike will actually look like they belong together.
Good call grabbing that V700 style taillight ahead of time too. It's the kind of part that's a pain to find when you suddenly need it. And finding the instruments at Harper's takes care of the big missing piece. Is the speedo/tach set complete with the mounting hardware, or will you be hunting for brackets and cables as well?
Looking forward to seeing it come together.
« Reply #34 on: October 16, 2026, 07:17:34 AM »
The dash mounting hardware consists mainly of 3 rubber isolation bushings which are readily available.  Cables are in hand.
Work on the uber crusty wheels is ongoing.  Many of the spokes put up quite a fight before they came out.  Luckily I was able to salvage all of them.
« Reply #35 on: October 18, 2026, 12:49:21 PM »
The wheels are among the most gnarly I have seen.  The will never be restoration quality again, but I will make the heavy patina less so.
« Reply #36 on: October 18, 2026, 03:50:04 PM »
What an afternoon's worth of toil produced.  Not wanting to polish the center section corrosion until my fingers bled, I masked off the outer rim and bead blasted the center with a super fine media.
Offline faffi
« Reply #37 on: October 19, 2026, 01:13:14 AM »
Amazing improvement :bow:
Current bikes:
2002 BT1100
1982 XV750 / 1990 1100 mongrel
1990 XT600Z
2001 NT650V in bits
« Reply #38 on: October 24, 2026, 03:16:16 PM »
Many hours went into improving the gnarliest wheels I have ever worked on.  Not anywhere near show quality, but that's certainly not what this bike is about.
« Reply #39 on: October 24, 2026, 06:14:25 PM »
Massive improvement.
« Reply #40 on: October 25, 2026, 03:00:38 PM »
It will start flying together now!
« Reply #41 on: October 26, 2026, 06:49:57 PM »
Its been many moons since the engine and transmission have been in the frame.
« Reply #42 on: October 27, 2026, 05:26:21 PM »
Another productive day.
« Reply #43 on: October 28, 2026, 04:08:17 PM »
 :popcorn:
« Reply #44 on: October 29, 2026, 05:17:30 PM »
Offline faffi
« Reply #45 on: October 30, 2026, 02:41:51 AM »
Coming along nicely  :thumb:
Current bikes:
2002 BT1100
1990 XT600Z
2001 NT650V in bits
« Reply #46 on: October 31, 2026, 05:49:22 PM »
Cranking along.  It is always a red letter day when both wheels are back on the bike.
Online larrys
« Reply #47 on: November 01, 2026, 06:49:13 AM »
Nice work! It will make a perfect road dog. I used to always have one in the stable. A bike you can just ride without caring about how clean or dirty it is...
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
« Reply #48 on: November 01, 2026, 06:58:43 AM »
Larry
Dirty bikes, even those with tons of patina, are not in my lexicon.   :grin:
« Reply #49 on: November 11, 2026, 08:12:26 PM »
More progress.
« Reply #50 on: November 13, 2026, 03:05:01 AM »
Good to see it all back together again. Getting the wheels on and the engine and trans in the frame is when a pile of parts starts looking like a bike. Bead blasting the hubs and leaving the rims alone was a smart way to go, it kept the character without hours of polishing corrosion by hand.
Since it's been sitting so long, I'd pull the fuel tank and look inside before it sees any petrol. And on a bike this old, a fresh set of wheel bearings and brake cables is cheap insurance now that everything's apart.
Looking forward to the next update.
« Reply #51 on: November 13, 2026, 07:15:11 AM »
Tank has been cleaned.  Wheel bearing were cleaned and inspected.  The Timken bearings almost never wear out, and these were in good shape.  Just re-greased, preload checked, and new seals.  New cables throughout also.  I threw all the OG ones out.
« Reply #52 on: November 13, 2026, 08:31:58 AM »
The tapered roller bearings used on drum-brake Loopframe Guzzis are a peculiar size and not easily found, Yes, there are new ones available, but there are doubts of their origins (likely Chinese). Fortunately, the originals are super durable and if kept greased and not run too tight or too loose will last "forever".
There's only one brake cable - the front. New is not always better. The original cable had a 3 mm inner wire and the housing was wound of square section wire. Almost zero give to either. Many new cables have flimsy inner wire - smaller diameter and less strands, the housing wound of round section wire, and the result is a "stretchy" cable that barely activates the brake with enough force. Only Barnett makes a cable that I'd spend my $$ on, and that one has a minor flaw that needs to be corrected.
« Reply #53 on: November 14, 2026, 08:44:29 PM »
IIRC, Mark Etheridge (or maybe it was someone else?) uses Barkeeper's Friend to remove the rust/stains.
probably Bon Ami !! :boozing:
« Reply #54 on: November 15, 2026, 01:41:27 PM »
Jumped ahead to see how it looks.  This one is gettomg the Cycle Garden solo seat that has been hanging by the ceiling for years.
« Reply #55 on: November 15, 2026, 01:46:56 PM »
I wasn't sure how this sidecover would look, but a couple of days worth of work and here it is now.
« Reply #56 on: November 20, 2026, 04:24:23 PM »
In the back of my mind I suspected that the fork tubes were bent, but I assembled the front end anyway, relying on wishful thinking.
The tubes were bent enough to prevent anything close to normal fork action.  I bit the bullet and did what I should have done the first time.  Disassembling the tubes and checking them on my surface plate confirmed my suspicions.
Straight used tubes are being delivered tomorrow.
« Reply #57 on: November 20, 2026, 05:04:18 PM »
I was bitten by the bent tube bug once... now I chuck them all up in my lathe to check run-out.  :wink:
Offline faffi
« Reply #58 on: November 21, 2026, 07:37:38 AM »
If you have a hydraulic press, you can straighten bent legs if they are not otherwise damaged.
Current bikes:
2002 BT1100
1990 XT600Z
2001 NT650V in bits
