Author Topic: 1975 850T electric mistery  (Read 11448 times)
Offline Woodrow
« on: July 18, 2026, 05:23:42 PM »
So I have a 850 , great bike , starts great , stops great , does everything.   BUT the other week i turn the key,, nothing,.(no lights on dash)   So ok , roll out another bike and go to work,       Come back from town , check the battery , 12.5  volts .  WOW OK .  turn the key , push the button ,  fires right up.
     So I blamed myself ,  i thought I had turned the key too far and not turned it enouf to start .  so great ,  I rode it the rest of the week.   And it did it agan..    no matter what it wont crank ,  battery is 12v . .  Turn the key on and off and have a spark at plug.    so I start looking it over a day or so later .AND,, lights  oil light , netural light.  and cranks and starts.
 This bike has a 3 year old wire harnes from G Bender,  all the wires look great .    Today I wiggled and unpluged and repluged all the wires i could .
I put the tank on and ran it up and down my road ,  not as far as I would like to push this thing.
   Would be nice to have someone follow me around with a trailer.     Good running bike (when it runs )       Woodrow .
Re: 1975 850T electric mistery
« Reply #1 on: July 18, 2026, 05:41:15 PM »
Sounds like a good time to disassemble the ignition switch, clean, wire brush the contacts, apply fresh vaseline. Even if that isn't it, most likely it's due.
« Reply #2 on: July 18, 2026, 06:01:01 PM »
I second that motion. Good idea unless replaced with harness.
« Reply #3 on: July 18, 2026, 06:25:09 PM »
Have you checked the charging voltage? Battery resting voltage should be a bit higher than 12.5.
Offline cliffrod
« Reply #4 on: July 18, 2026, 07:13:05 PM »
I’ll jump in and ask if the fuse box was replaced along with the new wiring harness. Hidden corrosion in my V7 Sport’s original fuse box confounded us for quite a while after I replaced everything wiring harness-related except that because it looked fine.   Once fixed, all was good.
Offline Stretch
« Reply #5 on: July 18, 2026, 07:15:48 PM »
Good advice on the ignition switch and fuze block; don't forget the kill switch, too.
                                                           -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Online n3303j
  • Ron Cichowski
« Reply #6 on: July 19, 2026, 08:13:46 AM »
My T3 drove me nuts with a similar problem. .
Found out the battery NEGATIVE cable was making a poor connection at the chassis. Clean it up, tighten it up and it all was history.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Woodrow
« Reply #7 on: July 19, 2026, 08:36:54 AM »
OK   Thank you ,  I replaced the key switch in the last few years ( this is the only bike I havent kept a record book on and I regreat it ). I found the old switch .    Just how do I take that apart , I got nothing to loose.
  This morning ,  at rest cold battery is at 13.75 .  Key on , lights, oil.gen  Netural battery still at 12 .75 or so.    Start up , gen light goes out . Voltage  14 volts at 3500 rpm.
 Today Im going to start a record book . also email a print shop to have a wiring diagram printed.
 So Im going to test ride some more ,  taking a cell phone , credit card , fire extinguisher. confortable walking shoes. ect.
  I do rember having the fuse box off the bike .  I can do that agan just for a look ..    Woodrow
Offline Woodrow
« Reply #8 on: July 19, 2026, 08:54:23 AM »
Im going to take another closer look at the battery connections.   Why not ?
Online n3303j
  • Ron Cichowski
« Reply #9 on: July 19, 2026, 09:04:43 AM »
Pull them apart. Clean them thoroughly. Grease them up. Reassemble.
Had recent problem with headlight shell ground on the T3 (after installing excellent Bender harness). There is a ground tab riveted to the shell. Turns out 50 years of corrosion in that area insulated the tab from the shell. Drill out rivet, clean all metal parts thoroughly, pack assembly with grease then re-rivet and all problems went away.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline cliffrod
« Reply #10 on: July 19, 2026, 09:54:18 AM »
This^^^^ is what can happen with any and potentially all of the riveted connections on these old bikes.  My original fuse panel looked great with no undue or obvious corrosion issues.  After checking continuity and drilling out rivets, the hidden corrosion on every connection was impressive.  Lots of small losses created the larger cumulative problem.
Offline cappisj1
« Reply #11 on: July 19, 2026, 10:49:53 PM »
I had a pin break inside one of the headlight pugs. Took a summer and a half to find it. That caused my T to immediately lose power to the engine. From rumbling down the road to instant dead silence coasting down the road. I don’t envy your future of tracing wires.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Online chuck peterson
« Reply #12 on: July 20, 2026, 05:26:25 AM »
Moto Guzzi, making electricians out of motorcycle riders  since 1921…
Similar situation…dead everything with the key on
Opened the fuse block, spun the fuses in their settings, started right up
Corrosion
Also…
Check both ends of the battery neg ground cable, and up inside behind the sheathing, then scrape, sand and smear the frame. It only happens because it’s a 50 year old bike. Do the same for all your grounds…add a second ground off the diode board to the engine bolt holding the transmission on…
« Last Edit: July 21, 2026, 05:15:14 AM by chuck peterson »
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline Stretch
« Reply #13 on: July 20, 2026, 05:37:50 AM »
There is nothing - but nothing -  harder to troubleshoot than in intermittent
electrical fault!
                                                     -Stretch
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2015 Triumph Trophy
Offline wirespokes
« Reply #14 on: July 20, 2026, 04:45:54 PM »
That's why I solder connections, like those riveted, or wire ends.
Offline Woodrow
« Reply #15 on: July 20, 2026, 05:19:01 PM »
Any tips on taking apart the Zadi switch?
Woodrow
« Reply #16 on: July 20, 2026, 06:18:43 PM »
Woodrow
If it's a plastic bodied Zadi switch, then it's pretty much disposable. If it's a metal body Zadi, then some of this may apply even though it's a Marelli switch. https://www.thisoldtractor.com/moto_guzzi_loopframe_ignition_switch_rebuild.html
« Reply #17 on: July 20, 2026, 07:04:28 PM »
Woodrow
From memory.. dangerous at my age.. all that holds it together are bent over tabs. As mentioned above..the *back* of the fuse block can be problematic, too. I think. It sucks getting old..  :laugh:
Online n3303j
  • Ron Cichowski
« Reply #18 on: July 20, 2026, 07:59:15 PM »
I pulled one apart to clean it. Went to put it back together and discovered the back could go on in multiple locations (most of them wrong). Mark everything as you disassemble or just buy a new one. I'm on third in 135,000 miles.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #19 on: July 20, 2026, 11:53:56 PM »
^^^^^ do this and it’ll be a lot easier. They used to sell just the contact base with a pigtail you could swap out and plug in but I lost the part numbers. Joe Eish used to get them because he tried to have any part that could stop you on a trip if it failed.
Online n3303j
  • Ron Cichowski
« Reply #20 on: July 21, 2026, 07:47:19 AM »
^^^^^  Joe Eish used to get them because he tried to have any part that could stop you on a trip if it failed.
Only way possible...
« Last Edit: July 21, 2026, 07:55:51 AM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #21 on: July 21, 2026, 07:59:32 AM »
Oh yeah.. I forgot to mention that little problem.  :smiley: Buying a new one requires a new key, though, a PITA.
Offline Moparnut72
« Reply #22 on: July 21, 2026, 08:39:18 AM »
The switch that came with my T3 wouldn't turn. It was the plastic bodied one, I took it apart and after several attempts to get it back together I finally got it correct but the functions were intermittent. It went in the trash, I fitted an aftermarket switch with some modification to the housing. A whole afternoon or more I won't get back. This whole semi basket case project has gone like this. I have put this project on the back burner due to being semi burned out and other priorities due to summer. I found a running 'T' two days ago for not too much money. So my plans are to take the best of each and come up with a good looking running bike.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #23 on: July 21, 2026, 11:34:54 AM »
That’s why it was so nice to be able to get just the contact plate. Plug and play, comes with the wires and plug in, if you can find one. It’s probly “ next higher assembly “ by now unless a dealer has some stashed.
