Author Topic: Norge airbox enquiry.  (Read 2836 times)
« on: July 19, 2026, 08:31:45 PM »
Can anyone tell me what the foam cushioning stuff inside the lid is for ? After 19 years, mine has started to disintegrate so I’ve removed it.
I replaced the plugs at the 20,000 k interval and noticed an unusual sooty deposit on them that coincides with the destruction of the foam.
I wonder if it’s been ingested and burnt onto the plugs ?
Anyway, the foam has gone and she has new plugs…!  :bike-037:
Online John A
Re: Norge airbox enquiry.
« Reply #1 on: July 19, 2026, 09:54:01 PM »
I believe it’s for noise reduction. That’s also why they put snorkels on the air box. Open intakes can be almost as loud as the exhaust sometimes.
« Reply #2 on: July 19, 2026, 10:57:42 PM »
Oh, ok.
Thanks John.
Offline Vagrant
« Reply #3 on: July 20, 2026, 09:21:00 AM »
Just for noise for sure.
« Reply #4 on: July 20, 2026, 09:40:28 AM »
There is no foam on the inside of airbox. It is on the underside of tank & the outside of the air filter lid. I have cleaned out more than a few from sucking in the foam. If it is inside it got sucked in when dry rot happens. It crumbles & falls off. If you don't check your airbox at all, I would start.
Aprillia uses a different item, use it to replace it under tank. The foam will cover your air filter BUT NOT GO THROUGH iT unless you have a crappy seal. You could use a GTM lid rim to hold filter so you can see in airbox anytime tank is lifted.
I don't think you are burning foam unless you run no air filter.
« Reply #5 on: July 20, 2026, 01:18:01 PM »
Yeah that makes sense, I have been in there dozens of times, but I mis described it.
Thank you.
Anyway, I have removed the foam.
« Reply #6 on: July 20, 2026, 02:49:33 PM »
Most of the foam is gone on them now, some went in where the snorkel was. If you have never looked in your airbox on a Breva, Norge, Sport chances are it's full of dry crumbly foam. Especially if you have run-ability issues. Aprillia uses a foil type of material. An engineers bright idea, for sure.
« Reply #7 on: July 20, 2026, 03:48:16 PM »
Ah yes I have, I clean inside it at each service to remove oil mist condensation.
Online PJPR01
« Reply #8 on: July 20, 2026, 05:11:36 PM »
My foam crumbled and dried up years ago in the Texas heat.  I replaced the tank foam with a nice gold liner all under the tank for heat shield purposes as in extremely hot summer rides (north of 105F with heat indices above 115F), sometimes I'd get a bit of vapor lock, and have to vent the tank cap.
The gold shield even though invisible to others looks beautiful to me and far better than the crumbly foam, which could be ingested into the airbox.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline brider
« Reply #9 on: July 22, 2026, 07:48:23 AM »
The plastic liner under my tank separated and somehow got sucked onto the nose of the snorkel inlet, eliminating the engine's ability to rev past 4k, I knew immediately what happened and limped it home, took the tank off, and cursed the Lead Engineer who approved of that plastic liner and foam under the airbox lid as somehow a good Production solution (to whatever potential problem they were addressing).
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
