€67 ! Glad I didn't lose it.
There shouldn't be a hole in it. It needs to be replaced.
I have seen some of them made with the hole. Not sure why.
Hell, I thought they all had holes in them, all I have seen. Thought it was to lube detent better.
I think that bit only came out because I dislodged the drum trying to remove the rear casing .Are there any other gearbox options for the sporti ? I would like to increase my final ratio a bit , say go up to the equivalent of dropping two teeth off a rear sprocket .
