Author Topic: V100 Service Reset method available yet?  (Read 622 times)
Offline Rad1o
« on: September 09, 2026, 06:40:39 AM »
Hello,
I have gone through some sites looking for a service method for the V100 / Stelvio E5.
Some suggest a kex combination which I cannot find or follow on my bike.
I have seen links to OBDstar readers for a V85.
Does anyone have any links to the V100s?
Online PeteS
Re: V100 Service Reset method available yet?
« Reply #1 on: September 09, 2026, 07:21:16 AM »
OBDstar works for the V100 too. It needs an internet connection to do it though. If you have a smart phone you are all set, otherwise you have be within range of wifi.  I expected it to read like a independent OBDII reader. Not too handy in my book.
Offline SirIzak
« Reply #2 on: September 09, 2026, 07:41:15 AM »
Supposedly the iCarsoft MT V6 Plus will reset it as well, I have an E5 V85tt and it will reset the light, read codes, give some real time data, etc. And they have been very responsive for the few people I have seen need help with it, someone on here I think tried it with the newest V7 and it would not work, they asked for some info and a day or two later had it working for him. I have no personal experience with the V100 and this scanner, but I currently have no reason not to believe it would work, and their website says it should. You can email them to make sure per their listing https://icarsoft.com/products/mt-v6-plus
Offline Rad1o
« Reply #3 on: September 09, 2026, 01:07:43 PM »
Hi Pete,
Is the OBDstar able to code / change settings too. I downloaded a exel file which listed functions like de / activate TPMS, Quickshifter and more.
Online PeteS
« Reply #4 on: September 09, 2026, 02:03:00 PM »
Hi Pete,
I can’t tell you that. While I believe it can read the settings, I m not sure that it can change them. Its not particularly intuitive. Certainly not like a Power Commander where you could easily change values. Maybe someone with more patience than I have can help.
Offline JHBettsSr
« Reply #5 on: September 09, 2026, 02:03:56 PM »
+1 on the OBSStar iScanGuzzi. Their website shows it to work on V100's, E5 and E5+.
Look under the tab "Function Manual" & "Guzzi Coverage":
https://www.obdstar.com/Products_376.html
'17 Triumph Bonneville T120
'13 BMW K1600GT
'25 Moto Guzzi V85TT
Offline MG_rider
« Reply #6 on: September 10, 2026, 02:41:58 PM »
OBD star works for me.  Just used it at 15K miles service to turn off service wrench.  ABS block open for brake bleed next time I hook it up.
Connect to net with Hotspot wifi on phone.  Pays for itself 2nd time I use it.  Not very intuitive, but works as advertised, I've had worse, just needs some comprehension patience.
Adjusting intake valve shims way more hassle than OBD device!
« Last Edit: September 10, 2026, 02:44:15 PM by MG_rider »
'23 Moto Guzzi V100 Mandello S
The bike is just a blank page, the rider is the writer, the road is the ink....
Everyone should have something in their life that requires a helmet.
« Reply #7 on: September 10, 2026, 09:29:08 PM »
I believe that it was asked if the listed devices will up load a new map. AFAIK..No they will not, unless there has be an update or mod to them that I don't know about.
Offline buck
« Reply #8 on: September 11, 2026, 10:31:51 AM »
I have the Icarsoft mt v6 and reset the service light on a friend’s ‘23 V100, so yes, it works. I did have to get updated software from their support after I bought it.
