Author Topic: Stelvio engine oil  (Read 307 times)
Offline speedyg
Stelvio engine oil
« on: October 16, 2026, 04:55:26 PM »
2024 Moto Guzzi Stelvio.
What engine oil can be used instead of the engine oil from the factory.
Just curious.
Offline Perazzimx14
Re: Stelvio engine oil
« Reply #1 on: October 16, 2026, 05:15:12 PM »
Any oil that meets or exceeds the manufacturers specifications/ratings in the proper weight range for you climate.
Brand names or buzz words on the label are not as important as most would have you believe.
« Last Edit: October 17, 2026, 04:45:52 AM by Perazzimx14 »
« Reply #2 on: October 17, 2026, 08:47:41 AM »
Prezz, I know you know your stuff, but I'll add:
Group Three oils are not really full synthetic.  I'll only use Group Four.  Both bottles will say they meet the specs but they are different.
https://takeuroil.com/group-3-vs-group-4-oil/
There is way more.  Lake Speed, Jr. has made some very informative vids on this topic.
Offline paulbricey
« Reply #3 on: October 17, 2026, 03:00:14 PM »
........and Group V !.  For me Ester based synthetics are even better than PAOs
Riding to live
Offline Bulldog9
« Reply #4 on: October 17, 2026, 07:10:43 PM »
I buy the 3 5 quart bottles of Castrol Edge from Amazon. Currently $95. A chunk of change but works out to about $6.30 per quart. Was $80 when I bought it last time.
FWIW,  I've bounced between the Liqimoly and Motul until the last 2 years when I started with the castrol edge 10w60 full synthetic oil. It seemed like I always used a little bit of oil between changes until I switched to the Castrol. On my last trip on the stornello, I ordered the full change kit from af1 and they sent the Castrol edge . I flogged the living daylights out of it for over 3,000 MI and didn't burn a drop. I've switched all to it at this point.
I do a 3k oil change and 6k oil with filter on my small blocks, and stick with 6K on the big blocks so this one purchase sets me up for the year.
« Last Edit: October 18, 2026, 11:08:38 AM by Bulldog9 »
MGNOC#23231
Offline Perazzimx14
« Reply #5 on: October 18, 2026, 04:17:49 AM »
Any modern motor oil is light years ahead of the motor oils of yore no matter the base being conventional, semi/full-synthetic or true synthetic. The average motorcycle will never see enough run time for the oil base or even quality to ever be a problem.
