Author Topic: Norge windshield up/down relays  (Read 209 times)
Offline NH2SC
« on: October 21, 2026, 12:01:43 PM »
Any help on the availability of Norge windshield up/down relays? I need the UP relay, although AI claims they are both the same. I powered the motor in both up and down using a 12-volt supply, and it works fine. I removed the UP switch from the left handlebar, and it is also working. I think that leaves only the relay?
Offline Bulldog9
Re: Norge windshield up/down relays
« Reply #1 on: October 21, 2026, 12:34:59 PM »
Get on the Parts Fiche and find the part number and search for it. AF1 makes it easy to do.
MGNOC#23231
Online SemperVee
  • USMC Retired
« Reply #2 on: October 22, 2026, 12:03:21 PM »
 The 2007 Moto Guzzi Norge 1200, the windscreen relay is not exclusive to the windscreen. It is the “auxiliary services” relay, which also powers the horn, turn-signal circuit, and the instrument-panel/dash supply after the ignition is switched on. The factory electrical diagram treats the windshield as part of the switched auxiliary-load circuit, rather than supplying it from a dedicated windshield-only relay. SO, if  everything else is working. It's not the relay.
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
