PS: The only way I found it was that the weak coil eventually failed completely and that one side stopped sparking altogether. I was always testing spark by pulling the plugs and looking for visual spark. Turns out that it takes far less amperage to create a spark in standard atmosphere than to try and create the very same spark under increased air pressure (think combustion chamber).
Is it worse when hot? Or cold? -Stretch
Does it have a good idle on both cylinders?
