Author Topic: 38 mm Marzocchi upgrade to adjustable cartridges?  (Read 469 times)
Offline Allflatblack
« on: November 13, 2026, 09:16:41 AM »
I have picked up a set of 38mm forks for a vintage race project and assumed that I would have found someone who has successfully modified a set of adjustable modern cartridges to drop in and give my front end a full but hidden modern setup. So far not much has come up in my searches. Per Guzziology this set is probably from a SP2 or T5 3. Does anyone know of someone who has worked this project out already or have advice on where to start?
Offline wirespokes
Re: 38 mm Marzocchi upgrade to adjustable cartridges?
« Reply #1 on: November 13, 2026, 11:11:48 AM »
Showa cartridges from a newer Honda are supposed to be the way to go. The tops need some machining to fit the Guzzi forks, but that's it. There's someone here that's done it, but don't recall who that is.
« Reply #2 on: November 13, 2026, 11:18:34 AM »
Are you sure those are Marzocchis? They don't look like the sets I've had. They look more like the 38 mm Guzzi forks as used on the T5 and SP2.
« Reply #3 on: November 13, 2026, 11:50:45 AM »
They are guzzi forks but as far as I know they were made by Marzocchi for guzzi and Ducati.
Research says that Honda 600rr with the last set of old style forks used dampers that will do the trick. i am trying to find a used set that I can research on.
Thanks!
Offline Tony F
« Reply #4 on: November 13, 2026, 03:59:03 PM »
I dont know where you live but I recall reading that (I think) Maxton Engineering in the UK did updates to old forks with modern internals. Might be worth a chat. HTH
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Offline Stevex
« Reply #5 on: November 14, 2026, 10:55:13 AM »
I read on this forum about someone (Huub?) fitting Showa cartridges to oem LM2 forks. I decided to upgrade my LM2 forks in the same way. The donor parts came from a set of VFR750 forks. My forks now have adjustable pre load and decent damping,  fine tuned via oil viscocity and air gap.
« Reply #6 on: November 16, 2026, 06:43:55 AM »
I just picked up a nice set of 2004 Honda 600RR forks, they have the internal carts that NYC Norton used for the Norton forks so I am guessing that they will work. Will report back! If I can make them fit I can then find a newer model replacement that should perform better but will see.
Offline huub
« Reply #7 on: November 16, 2026, 07:48:08 AM »
those are not marzocchi forks, but normal 38 mm guzzi forks with cartridges.
i had no luck getting the oem guzzi cartridges to work properly.
i did a few swaps with honda RC36 ( VFR750) cartridges.
but a whole generation of motorcycles had those cartridges , including the CBR 600 and ducati upside down ( 900SS) forks
you need to machine the fork tops ( from the top of my head: 37x1 mm threads for the honda , and M29x1 mm for the 35 mm guzzi forks.
have not upgraded 38 mm forks yet.
« Reply #8 on: November 16, 2026, 08:00:22 AM »
Thanks, will reach out to both you and steve for advice. Do you have to source special springs to make it work?
Offline huub
« Reply #9 on: November 16, 2026, 02:24:06 PM »
on my le mans 2 the stock springs ( 2 per stanchion, a long and a short one ) were fine after adjusting preload
better than the progressive ones i briefly tried
« Reply #10 on: November 18, 2026, 09:33:48 PM »
I decided to "go down this rabbit hole" with my CX1100 project. Bought a cheap pair of VFR750 forks on ebay today.
What viscosity oil are you using and what air gap?
Offline huub
« Reply #11 on: November 19, 2026, 02:49:51 AM »
i think i ended up with 7,5 viscosity,  no idea about the air gap , i did the conversion a 8 years ago
« Reply #12 on: November 19, 2026, 04:02:08 AM »
Hamlin knows how to do it.
