Author Topic: fuel injection sync  (Read 357 times)
Offline kolorado kooler
fuel injection sync
« on: November 13, 2026, 05:07:50 PM »
 I have a 1998 EV that I have to synchronize the fuel injectors. I`ve done it before many years ago but of course I need a refresher. There must be a post the goes into detail but where is it ? thanks for the help.
Offline pressureangle
Re: fuel injection sync
« Reply #2 on: November 15, 2026, 07:41:06 AM »
https://www.v11lemans.com/forums/topic/19610-decent-tune-up/
Those instructions are for a spine frame with a 15M ECU. Not a 98 EV with a P8 ECU.
« Last Edit: November 15, 2026, 07:46:12 AM by Wayne Orwig »
« Reply #3 on: November 15, 2026, 10:49:16 AM »
Aside from the technical difference in reading the TPS, the mechanical rules all apply.
Personally, I don't use a vacuum gauge at all anymore; I set the throttle blades to about .002 clearance to the bores, set the TPS, and trim the airscrews for +/- 100rpm.
The valve seats and adjustment is critical, if they are out then setting TB balance by vacuum is blowing smoke.
Checking exhaust pipe temperature at idle also confirms equal mixture. If it's balanced at idle and unbalanced at 2500, you have a vacuum problem not a balance problem.
