Author Topic: Proper slide for a t3  (Read 341 times)
Offline benebob
« on: November 17, 2026, 08:21:26 AM »
So after 6000 miles or so of sorting my new to me this spring 78 t3 no matter how many times i adjust the carbs or clean them or swap needle height or jets or sync Plugs tend to be pretty black and she doesn’t like to drop quickly to an idle after longer runs between coming to a stop. Bought another set of vhb30s to play with as
They were cleaner than mine. Well went to
Clean and rebuild em yesterday and noticed that the slides we different number one is a 40 and the other a
60
As best i have found is the stock slide for a t3 would have been a 7454-60. Is that correct. Pulled the slides on the bike this today and they are both 40s.   Never really experimented with slides on a carb as  never needed to but from my limited thought process having a bit more air and access to it a bit sooner sounds like what my bike may need????
78 850 T3
Re: Proper slide for a t3
« Reply #1 on: November 17, 2026, 08:42:30 AM »
T3s use #40 slides. The 40 slide has 4 mm of cutaway, 60 has 6 mm.
Online n3303j
  • Ron Cichowski
« Reply #2 on: November 17, 2026, 11:24:33 AM »
After 100K miles I had a lot of problems getting my T3 to reliably come back to idle. Slide faces showed obvious and uneven wear. I bought new reproduction slides and that problem went away.
https://www.eurojamb.com/collections/dellorto/products/new-7454-dellorto-vhb-throttle-slide-size-40-moto-guzzi-ducati
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline benebob
« Reply #3 on: November 17, 2026, 05:59:48 PM »
Was it all the time or after riding at rpm for some time?    To me I feel I am running rich
78 850 T3
Online n3303j
  • Ron Cichowski
« Reply #4 on: November 17, 2026, 06:24:15 PM »
It was most apparent when the bike was warmed up for awhile. Was running light slide springs. Went back to heavy springs and it made no difference. Thought it was hanging advance but I went through that to no avail. The new slides made it all good for me.
Before installing them I bonded a bit of #600 wet/dry sandpaper to the face of an old slide (after lapping it flat) and used it to dress the inside of the carburetor body. Maybe just lapping slides flat would have solved the issue but it removed hardcoat which would have galled the mating surface of the carb.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline dblue
« Reply #5 on: November 18, 2026, 08:19:19 AM »
Do not overlook worn atomizer, needle jet.
David Blue
dfblue46@outlook.com
937-210-8721
Offline moto
  • Fear the deer!
« Reply #6 on: November 19, 2026, 02:44:54 PM »
The stock slides are number 40s. You should first make sure that all your jets are stock, especially the main jets. A common mistake that causes black plugs is to substitute a larger main jet. Here are the stock specs (directly from the Moto Guzzi workshop manual):
CARBURETTOR SETTING
Choke 30 mm dia.
Throttle valve 40
Atomizer 265
Main jet 142
Pilot jet 50
Easy starter atomizer 80
Taper needle V 9 (2nd. notch)
Floater 10 grams
If your mail jets are much larger than 142 that's probably your problem.
To really understand the carburetors you should get the Dellorto carburetor guide, usually available as a free PDF file online. It explains the effects of the cutaway like this:
A small cutaway creates a greater vacuum, and consequently causes a larger amount of fuel to be drawn up through the atomizer; on the other hand, a larger cutaway would lower the vacuum, and therefore reduce the fuel delivered. Because of this, fitting a lower slide cutaway results in enrichment and vice versa.
The very best bet for a problem like yours is to start with the Dellorto manual, and proceed stage by stage through the carburetor settings, systematically, as they recommend. Good luck.
850 T-3
Griso 1100 corretto
