Author Topic: *California 1400 Merged Threadfest*  (Read 853671 times)
Offline sbaker
  • Piaggio Stock Holder
Re: *California 1400 Merged Threadfest*
« Reply #2640 on: December 11, 2012, 09:58:18 AM »
Yes, boring riding there. It needs someone to push it a bit in the corners.
What I fear, a bike with a small fuel tank. They call it a 'touring' model, but the luggage is small and the range on a tank is barely going to be 100 miles I suspect. Hopefully there will be fixes in the future.
Wayne.. for the market this bike is after, 100 miles is all you can tolerate before you have to replenish your beer... It's perfect !
Sam
Dallas, TX
AGATT
Current
Norge Wing: White Squadron
Ducati 900ss
Previous
1975 Convert + Sidecar - Fun
2004 California EV Touring
« Reply #2641 on: December 11, 2012, 11:27:43 AM »
OK.
But will a six pack fit in the luggage?
 :BEER:
Moto
« Reply #2642 on: December 11, 2012, 11:34:26 AM »
Yes, good points. They do show two different topcase options available, 50 liters and 60 liters. That would help with the beer.
Offline youcanrunnaked
« Reply #2643 on: December 11, 2012, 12:21:15 PM »
How is the nuovo California's luggage capacity small?  The side bags are 35L; that's halfway between the Hepco-Becker juniors (40L and 30L).  That's 70 liters of storage.  Add the 60L top case, and that's 130 liters of storage.
The favored set-up for the prior California models is a pair of the 40L Juniors and the 45L top case.  That's 125 liters of storage.  So, the new model gives you an extra 5 liters of space.  You're welcome.   :P
IMO, 40 liter bags would look absurd on that bike, and if you travel by motorcycle with more than 130 liters of stuff, you're doing it wrong.
« Last Edit: December 11, 2012, 02:09:27 PM by youcanrunnaked »
« Reply #2644 on: December 11, 2012, 12:46:51 PM »
How is the nuovo California's luggage capacity small?  The side bags are 35L; that's halfway between the Hepco-Becker juniors (40L and 30L).  That's 70 liters of storage.  Add the 60L top case, and that's 130 liters of storage.  IMO, 40 liter bags would look absurd on that bike, and if you travel by motorcycle with more than 130 liters of stuff, you're doing it wrong.
There is another way...
About 207 liters right here:
Offline Mark West
« Reply #2645 on: December 11, 2012, 01:44:43 PM »
Looks like a reasonable lean angle is attainable.
The 4.5 Gallon tank is a big mistake. On a bike that big surely they could find room for another gallon or so to allow for a safe 200 mile range.
Then again, I am not the target market for this bike so what I think probably shouldn't account for much.
Mark West
Hollister, CA
MGNOC L-752
Offline Guzzi-Guy
    • Lavigne Tavern
« Reply #2646 on: December 11, 2012, 01:57:56 PM »
http://www.youtube.com/watch?v=Nk7lf-IoqAQ
Sorry it's in French.
Dean
Translated loosely they loved the handling, the power, everything about the bike.  Only negative if you want to call it that is at near the end of the video the guy mentions that they heading back Cannes slowly as the low fuel light came on with only a little over 100km on the tank!  From the tone I am assuming the rapid fuel consumption was due to very spirited riding on the twisty roads along the Cote D'Azur :-)
Guy Fortier
"Great spirits often meet violent opposition with mediocre minds" -Albert Einstein
http://Lavignetavern.com
Lavigne Ontario, Canada (a 4 hour ride from anywhere)
Home of the Ontario Guzzi Riders Rally
2001 Moto Guzzi California
Offline rtbickel
« Reply #2647 on: December 11, 2012, 02:14:13 PM »
First thing I am going to do is paint the exhaust end caps black
2020 V85TT
« Reply #2648 on: December 11, 2012, 02:17:59 PM »
In the picture you posted, if you draw a line along the shadow under the bike, that corresponds to the angle of the pavement in the photograph.  Set another line perpendicular to that one, at the base of the rear tire.  Then draw a line through the middle of the rear tire.  That line corresponds to the lean angle, and is at just about 45'.
The tank is 4.5 gal. to reserve, with a 1.0 gal reserve; total is 5.5 gal.  If the nuovo California follows Guzzi custom, the reserve light comes on way, way, way before you need to stop for fuel.  I'm interested to see what kind of gas mileage these bikes will get, once broken in.  Moto Guzzi is quoting around 45 mpg, but so far, it looks like the press bikes are not coming anywhere close to that kind of fuel consumption.  A bigger fuel tank might spoil the styling, but I wonder if there is room under the seat for an auxiliary gallon or so....
« Reply #2649 on: December 11, 2012, 02:47:48 PM »
« Reply #2650 on: December 11, 2012, 03:13:03 PM »
If it truely is 5.5 gallons, that would be tolerable. I thought is was 4.5 TOTAL, which is FAR too small for a 1400cc land barge.
Offline wheaties
« Reply #2651 on: December 11, 2012, 03:18:04 PM »
If I follow the shadow as a reference point as someone suggested, it works out to about 33deg.  If the shadow is generated by light from behind, then the ground line should be moved toward the eye which would make for less lean.  If the road margin line and barrier wall are to be believed, then the angle is much steeper.
Just adding fuel to the fire....
Matt
« Last Edit: December 11, 2012, 03:23:29 PM by wheaties »
2011 California Black Eagle
2014 Norge
« Reply #2652 on: December 11, 2012, 03:22:16 PM »
If not already posted here, go to www.cyclenews.com for a really good/thorough road test article.  ;)  Cali. 1400 on this week's front page CN issue !
« Last Edit: December 11, 2012, 03:24:21 PM by Arizona Wayne »
Online bad Chad
« Reply #2653 on: December 11, 2012, 05:02:15 PM »
Yet another poorly written review, why can't these guys get the facts right?
I did find the following interesting, assuming its correct.   The Cal has 5 degrees more lean on both sides than a Road King, and the author pulled 39 mpg for the day.
1988 YX600 Radian
Gary
« Reply #2654 on: December 11, 2012, 05:18:51 PM »
Well I think it is a great review. Makes me want to buy one. Facts not perfect, but glowing comments.
Chicago Mark
« Reply #2655 on: December 11, 2012, 05:27:20 PM »
Is the 39mpg from an Imperial gallon? If so, that's a bit more volume than the American gallon. Sure was a nice article though. All except the alarm system anyway.
Thank you for the link,
Mark
« Reply #2656 on: December 11, 2012, 05:32:06 PM »
Wheaties, I think you're base line is off.
Look at the white line on the edge if the road and the stone/mortar wall for a better reference to vertical and horizontal.
Those points of reference suggest more lean.
Chad, I wonder where they got that figure? If true, that's not bad. But heck, that last pic suggests it could even be more.
« Last Edit: December 11, 2012, 05:38:43 PM by Kev m »
« Reply #2657 on: December 11, 2012, 05:56:20 PM »
I thought it was a good article.  Most of the facts seem correct, to me.  I could quibble over the transmission history lesson, but, big deal.
Five degrees more lean than a Road King would be 38' each way.  (Not bad, but I had predicted 41.5'.  :P )  I still think it looks like more than 40' from some of the photographs.
The mpg figure (39) is at least reasonable in this article.  The author says the tank holds 5.4 gal, but I'm sure I've seen 5.55 gal reported.  Even at 5.4 gal and 39 mpg, though, range is 210.6 miles.  So, the effective range is around 200 miles, if you're brave.  I'd call that fair or barely adequate.  If the tank is actually 5.55 gals, range is 216.5 miles.  If after break-in the bike can get at least 42 mpg, that would be 233.1 miles from a 5.55 gal tank, at which point I would say the range is good, as I would feel comfortable planning fuel stops every 200 miles.
The heat comments are starting to worry me.  Riding in full gear, in Florida, in the summer, is bad enough.  A motorcycle that dumps heat on the rider is a problem for me.  My Norge was just bearable in the Florida summers  --  just.  (My EV runs significantly cooler than my Norge did.)
Offline Mark Dasher
« Reply #2658 on: December 11, 2012, 07:38:38 PM »
 ;-T
Cycle News/Alan Cathcart tested the new California.  Good favorable review.
He only got 39mpg in mixed riding.  I wonder if it'll improve after break in - sure hope so...
http://cyclenews.coverleaf.com/cyclenews/20121212#pg37
'75 850T
'78 Robin
'06 Breva 1100
Offline wheaties
« Reply #2659 on: December 11, 2012, 08:37:16 PM »
Kev,
I agree, and those lines definitely suggest more lean if the wall and road edge are actually perpendicular to the bike.  I don't see enough in the picture to confirm or deny whether that is true.  If the wall is significantly closer to the camera on the right hand side, that would account for the relative angle.  To be honest, there's very little to establish the plane of the road, but if you see something I don't, by all means, we can try that.
Measured from a base line parallel to the road stripe, I get 49 degrees,  measured from a line parallel to the top of the wall, I get 46.5 degrees.  To me that suggests that the wall and road are nearer to the right and farther to the left.   Either way, it's fun to try to establish that lean.
Matt
2014 Norge
« Reply #2660 on: December 11, 2012, 08:55:34 PM »
Ooooo, good point.
And I remain more optimistic.
« Reply #2661 on: December 11, 2012, 09:46:32 PM »
roadking can't do that.
« Reply #2662 on: December 11, 2012, 09:47:42 PM »
Most Roadking owners can't do that.
Fixt!
« Reply #2663 on: December 11, 2012, 09:56:30 PM »
the RKs simply don't have the lean angle.  You'd be sliding on the boards Big Mike.
« Reply #2664 on: December 11, 2012, 10:10:32 PM »
Yeah.  Just kidding around.  What I should've edited it to was:  "Roadking owners don't care", and there'd be a whole lotta truth to it...
Offline Adan
« Reply #2665 on: December 11, 2012, 10:10:41 PM »
Very good, in depth article.  The Cal1400 isn't on my radar, except as it relates to the future of the Moto Guzzi brand.  Lean angles, fuel range, whatever . . . it's hard to imagine anyone chipping away much at the empire HD has established here in the states.  The culture is too embedded.  I'd be happy to be wrong about that!  I think the best hope is that the basic R&D that Piaggio has invested in the Cal1400 manifests throughout it's range, ultimately raising MG's stock as a practical choice for the average road bike shopper.  It has that potential.
V9 Bobber
Zero S
Offline Mark West
« Reply #2666 on: December 12, 2012, 10:52:22 AM »
Keep in mind that Victory has built a pretty good business chipping away at the empire. When the empire is as big as it is and Guzzi is as small as it is, it's not a bad idea.
If they could get 1% of HD owners to buy one, what would that do to their sales volume overall? I suspect they would be pretty happy with that.
Mark West
Hollister, CA
MGNOC L-752
« Reply #2667 on: December 12, 2012, 10:57:58 AM »
Exactly.  1% of HD's production would be about 2500 machines.
2500 bikes is more than 25% of Guzzi's current production.
Keep in mind that Honda shares the street motorcycle market with Harley in the USA.  Together they own 50%.
If Guzzi can pull a few metric cruiser customers and a few aging sport-touring customers and a few HD customers, they'll have a (Guzzi-sized) home run!
« Reply #2668 on: December 12, 2012, 11:01:06 AM »
I don't get the smallish fuel tank.  They learned thier lesson with the Stelvio and came back with a correct-sized tank for the mission.
The Cal 14 is slated against motorcycles with 6-gallon tanks returning 45-50 mpg.
5.5 or smaller tank from a bike getting high 30s really sucks, IMNSHO...
« Reply #2669 on: December 12, 2012, 11:46:26 AM »
I agree on the fuel tank, but are the competitors really returning 45-50 mpg, or more like 35-40?
Or is this another case of rating vs real life?
Also, IIRC last I saw Harley alone was 50%   of the US street bike market, Honda being next closest, but less than 25%.
