Author Topic: My Calvin FARTED, and blew the hose and or filter !!!!!!!  (Read 7544 times)
Offline spridget
  • 2007 California Vintage 1962TR4 1967TR4A 1976TR6
« on: July 27, 2010, 05:58:10 PM »
Well I've finally been able to ride after 2 carpal tunnel surgeries, left and right. So I need to get inspection, as 07 Calvin I got new last June only had less than 1k, and I was told " we replaced that "..........I thought I was safe......I leave the inspection station go 1/8 of a mile, STOP sign, let out clutch..........FAR T. Won't start, gas swirling in tank......OH NO the dreaded Calvin glitch. Well at least I wasn't in DEATH VALLEY when it happened. Road America came; after 3 HOURS, holy crap, I was in a major metro area, and brought me and the Calvin home.......when I called the inspection station and they said "what do you mean it's in the tank?" OOPS a Yamaha, Suzuki place; home seemed like the best action. My stupidity......I had the parts, the crimping tool, SAW ALL THE WARNINGS; so now here I go on the fix. Lesson learned..........li sten and then DO IT !!!!! At least the flat bed was covered............ .
Plum Boro / Pittsburgh Pa. A few miles from the PA Pike, Monroeville exit.
Offline troyhamilton
  • Dr frankie
Re: My Calvin FARTED, and blew the hose and or filter !!!!!!!
« Reply #1 on: July 27, 2010, 06:26:29 PM »
theres alot of pride in fixing things yourself. plus look  at the savings!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Offline HDGoose
« Reply #2 on: July 27, 2010, 06:46:19 PM »
And you know it is done.
elvisboy77
« Reply #3 on: July 27, 2010, 07:41:56 PM »
crimp the living daylights out of those clamps.
hareynolds
« Reply #4 on: July 27, 2010, 07:57:33 PM »
I had a girl like that once.
Offline Californhihay
« Reply #5 on: January 30, 2015, 02:23:38 PM »
i pulled my pump out of the calvin today to check if the hose was ok, it looks like it has the crimp clips on the pump and filter.
should the hose between the filter and the pump be the spiral molded type to stop it straining and poping off?
Online Cam3512
« Reply #6 on: January 30, 2015, 03:33:45 PM »
That "appears"  to have  been fixed with the proper hose and clamps.  It's the smooth rubber hose that's the culprit.  Is that hose still solid and clamps tight?
Offline Sheepdog
« Reply #7 on: January 30, 2015, 03:42:11 PM »
Yes, and that is the preferred metal filter, too. Looking good...,now good luck snaking that rascal back in the tank!
« Reply #8 on: January 30, 2015, 06:34:03 PM »
Geeze does that bring back memories:
"The Matrix"... any of them.
"Star Trek" episodes with The Borg
The drug induced alien birth scene in "Alien Resurrection".
Oh yeah, and pulling my own within the first 1,200 miles. Fun, that. Reinstall is like trying to figure out the old "ship in a bottle" scenario. My guess, Moto Guzzi employs Oompa Loompas. ".... but it came out so easily..." Cried whiningly.
Todd.
Offline lazlokovacs
« Reply #9 on: January 30, 2015, 06:49:07 PM »
yep, been there done that, mine filed TWICE.
First time, it was 'fixed' by a professional. The second time, I fixed it myself. So far no problems.
And there is room for having the filter outside the tank on the frame.
« Reply #10 on: January 30, 2015, 08:14:23 PM »
In later years, they finally wised up. Yours looks like the good stuff to me.
« Reply #11 on: January 31, 2015, 04:09:58 AM »
Thats reassuring as the guzzi parts drawings show plain hose and convoluted hose for the same part number. (THANKS ALL)  ;-T
 I stuck the pump back in after taking the photo, (painted the bare metal around the seal too  ???).
I will pull it again in 15000 miles to see if it is fine. i will post some pictures of the wires and connectors for anyone thinking of taking a look at their pump. perhaps they will do it if they know what to expect under the tank. I did not drain the tank I just held it in the wood vise on the workbench in an upright position when the fuel light had come on.
« Reply #12 on: January 31, 2015, 04:17:38 AM »
pump bolts and connections: (brake caliper nipple cover borrowed to seal the connector as it is a perfect fit)
tank side hole:
fuel pipe connector, tricky to get it to release: ::(
electrical connections, it is impossible to mix them up (1 male & 1 female), the tank vent is the small diameter pipe not connected to anything.
« Last Edit: January 31, 2015, 04:21:05 AM by Californhihay »
