Author Topic: Moto Guzzi Stelvio NTX and Other 8-V Valve Adjustment Procedure  (Read 48146 times)
biking sailor
Re: Moto Guzzi Stelvio NTX Valve Adjustment Procedure
« Reply #30 on: November 25, 2014, 07:10:37 AM »
As for the first quote? It is over two and a half years old and like all observations is subject to revision and re-examination in the light of further events. Problem?
Pete, those of us that do failure analysis for a living (I run the Quality Department for a material handling manufacturer and have certifications hanging on the wall showing I have passed testing to show proficiency in such) understand fully what you are doing and why in trying to figure out what is the root cause of the failures.  We appreciate your efforts and time you spend detailing your findings.  I'm following your posts even though I have no flat tappet big block, if for nothing else the opportunity to learn and be entertained.  Thanks, and keep up the good work!
Darren
"Only a fool closes his mind after only a few facts"
Offline sib
« Reply #31 on: November 25, 2014, 07:28:23 AM »
Nice article.  Two brief comments:
1. You write:  "There are marks on the flywheel, as with all Guzzi models, to indicate when each piston is at TDC but they are not as obvious as on the older engines."  Not true for the newer V7 models.  None on my '13 V7 Stone, for example.
2.  You write:  "I like to dab a wee bit of anti-seize compound on the threads."  This is specifically discouraged by NGK for it's plugs, which have a zinc plating that acts as an anti seize.  Here's their quote:
Issue
Applying anti-seize to the threads of spark plugs that have a metal plating allows the installer to mistakenly over-tighten the spark plug in the cylinder head; this stretches and fatigues the threads of the spark plugs, causing a much higher probability that the plug will break during installation or in some cases upon removal.
Solution
For spark plugs with special metal plating simply do not use anti-seize on initial installation; all NGK Spark Plugs are manufactured with a special trivalent zinc-chromate shell plating that is designed to prevent both corrosion and seizure to the cylinder head; thus eliminating the need for any thread compounds or lubricants.
« Last Edit: November 25, 2014, 07:29:27 AM by sib »
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline leafman60
« Reply #32 on: November 25, 2014, 01:42:49 PM »
Issue
Solution
Thanks SIB.
1. The subject of the 2.5 year old posting is a 1200 8V Stelvio. If the V7 has no flywheel marks, that's fine.  Good to make the note. Just use your soda straw as shown.
2. The plugs onto which I used the anti-seize are not new.
However, I also use a little on new plugs but I also am careful about not using excessive torque when tightening. I've never ever had a problem except occasionally with plugs that have not been wiped with a little anti-seize.
H-D also recommends this in their manuals.
Do whatever makes you happy.
« Last Edit: July 31, 2016, 08:25:01 PM by leafman60 »
andrewdonald1
« Reply #33 on: November 25, 2014, 02:53:30 PM »
BTW:  I did not see any marks on the flywheel of my 13 NTX.
It appears that its a raised hump section of the flywheel and you align it horizontally dissecting the observation hole in half - if that makes sense.
« Reply #34 on: November 25, 2014, 03:07:49 PM »
The stamped "D" and "S" marks on my flywheels have always been sort of close, but not spot-on.
Easier for me to stick something down the spark plug hole as I'm rotating the engine.
Offline sib
« Reply #35 on: November 26, 2014, 06:59:50 AM »
Strangely, even though the newer small block engines do not have TDC markings on the flywheel, the bell housing nevertheless has the inspection hole, as well as the rubber plug for the hole.  I suppose this is because the bell housing is the same casting as was used on older engines that did have the TDC flywheel markings.  Or, perhaps, in Mandello del Lario, the flywheel department doesn't talk to the bell housing department.
biking sailor
« Reply #36 on: November 26, 2014, 07:22:13 AM »
My guess, based on my limited knowledge of MG and owning 3 of them, is that the factory just didn't put much attention to getting all the markings on them.   :BEER:
Such as no grease in bearing or splines, missing timing marks, half plastic fuel filters that split, engine mounting bolts not torqued/thread locked, ECUs not protected from rain, no fuses on aux lights, exhaust gaskets blowing out...
Just gotta get those little things sorted out from new, then ride the Guzzi's hard!   :bike
« Reply #37 on: November 26, 2014, 09:38:15 AM »
On the newer bikes there isn't really any need for marks on the flywheel. Why they still bother with the inspection bung beats me? Why do you need it? Finding close to TDC is easy enough and to set the valve lash you only have to ensure that the followers are on the base circle of the cams, a few degrees either side isn't going to make any difference. As for ignition points these are controlled by the ECU based on input from the phase sensor which is triggered by the 'Phonic Wheel' on the dummy-shaft or camshaft on the 2V models.
Any marks on the flywheel assembly and even the hole to look for them are nothing more than a quaint anachronism.
Offline sib
« Reply #38 on: November 26, 2014, 01:36:13 PM »
Now that we have an explanation for the peep hole and the bung, can anyone explain why the clutch housing on the '13 V7 Stone also has a drain plug, complete with gasket?
« Last Edit: November 26, 2014, 02:36:14 PM by sib »
« Reply #39 on: November 26, 2014, 02:05:59 PM »
What? On the Stelvio/8V? It doesn't.
Boulder Ed
« Reply #40 on: September 18, 2015, 06:46:29 AM »
Just a quick comment for any Guzzi noobs like me.  I used the above procedure  yesterday to adjust valves at 3,400 miles on a 2013 Stelvio I purchased 6 weeks ago with 1,890 miles on it.  I'm used to doing BMW valves so it was a pleasant surprise to not have to be on my knees bending over to get to the valves to start with.  After not ever seeing any flywheel marks, I defaulted to a chopstick with a felt pin line at TDC drawn on it, so I could see it approaching TDC in each cylinder.  I rotated the wheel carefully in 6th gear by hand with the plugs out, which saved the hassle of removing the front cover.  Start to finish took less than 2 hours, but could probably be done in one hour next time.
I found all valves loose, by quite a bit.  I set them one at a time without using the two matched feeler gage method.  It really would have made no difference from what I saw and they all held fine, when I rotated the motor before buttoning up.
Now the really good news:  my bike was suffering from a number of minor streetability issues that made me think I may have to do a throttle body sync.  These included being rougher and stumbling at starting, rougher when running with a bit more vibration up to around 4,000 rpm then smoothing out.  It also started dying at the first stop sign a block from home as it warmed up.  It was a bit more difficult to shift smoothy, and had a couple almost flat spots around 2,800 and 3,300 rpm to pull past.    Basically it needed to be fully warmed up and to run above 4200 rpm to be happy.
ALL OF THIS WENT AWAY after the valve adjustment.  Cold starts are smooth.  No dying at the first stop sign.  You can ride it around at 2500 rpm if you want without any stumbling even, and pull smoothly throughout the rpm range.  No real change in vibration levels between 3200rpm and 4500rpm as there had been previously.  Much smoother now at lower RPMs.
I was beginning to think I had a throttle body sync to check on but now it idles smoothly, starts smoothly when stone cold, runs smoothly.. so I'll wait a while on checking the throttle bodies.
So, I am learning how these bikes respond to proper tuning and just how sweet they are when tuned properly.  I love this bike.
Offline leafman60
Re: Moto Guzzi Stelvio NTX and Other 8-V Valve Adjustment Procedure
« Reply #41 on: February 16, 2025, 07:07:35 AM »
Okay, I made a small edit to the original post to clarify that this procedure also applies to models other than the Stelvio NTX.  Thanks for those who have asked about that.
I hope everybody is doing well ! I still have a cherry Griso SE.
DL
« Reply #42 on: February 16, 2025, 10:59:24 AM »
Glad all is well & the Griso is still honking, one of the best Guzzi has made.
Offline Stretch
« Reply #43 on: February 16, 2025, 11:39:24 AM »
Nice write-up!
On my big Cali Touring, I put a bamboo skewer down the spark plug hole,
put the bike in 6th on the stand and rotate the rear wheel to find TDC on each
cylinder. Spark Plug Boot grease is your friend!
I also have a set of go-nogo feeler gauges which make life easier. Each "feeler" is
graduated in .002" segments: The .008" feeler is ground to .006" on the end. If
.006" passes, but .008" doesn't, then you know you are between .006" and .008".
You can then fine tune things as you go. Great for lazy SOBs like me.  :smiley:
The plugs look fine to me at 5K - I change them at 10K. No major change in driveability
or fuel economy, so I can't be too far off. Plugs, valve adjustment, engine oil, filter, and trans oil change
is a leisurely afternoon's work. That's really it for most periodic maintenance on this machine.
I do the rear end fluid when I do the rear tire, but I'm thinking I'm going to extend that interval -
the fluid comes out very clean, and there's not that much on the drain plug.  YMMV.
        -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
« Reply #44 on: February 16, 2025, 04:12:56 PM »
All my Clearances (2009 Stelvio NTX) are set to 0.1mm.
Have been for just over 30,000 miles, and I've not had to adjust them since.
Runs a little quieter.
The Clearances on the 8V 1200s open up as the Engine temp increases.
This isn't an 'urban myth', or 'internet hearsay', it's been measured.
Not saying anyone has to do it, just my personal preference.
I'll also second the bit about not putting anything on the Spark Plug Threads.
Any lube on any threads, and you should reduce the quoted Torque Figure by around 20%.
I still wouldn't do it, it can also (theoretically) interfere with the Grounding/Earthing.
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
Online Bulldog9
« Reply #45 on: February 17, 2025, 11:20:08 AM »
FWIW, if you run a Beetle Map, Mark recommends .006" & .008" (.10mm & .15mm) if you are using his map rather than the .004" and .006" per the manual. I've run them at both, not a huge difference.
Great tutorial overall. A few other points to get your Guzzi Running at its best. Here is what I do.
1. Valve Adjust & New Plugs
2. TPS & Learning Parameters Reset
3. TB Balance
4. Final TPS & LP reset
« Last Edit: February 24, 2025, 05:06:59 PM by Bulldog9 »
MGNOC#23231
Offline John Warner
« Reply #46 on: February 17, 2025, 01:23:05 PM »
Autolearning Parameter Reset is only necessary after a Re-Map.
No harm in doing it at other times, but it's not needed.
Doc out . . .
Online Bulldog9
« Reply #47 on: February 17, 2025, 03:53:47 PM »
Yes and no. The ECU will track and adjust fuel trims. Over time, they may/will adjust based on all the variables (spark/mixture/air cleaner/valve adjust, etc. etc.). Resetting them to baseline with the TPS may not be 'necessary', but it will be beneficial.
MGNOC#23231
Offline jacksonracingcomau
« Reply #48 on: February 18, 2025, 09:09:01 PM »
FWIW, if you run a Beetle Map, Mark recommends .6" & .8" (.10mm & .15mm) if you are using his map rather than the .4 and .6 per the manual. I've run them at both, not a huge difference.
You might want to check those figures and look in the book again
Running 3/4 of an inch valve clearance has never been recommended (if even possible)
.1mm is usually called.004” or four thou (to 3 decimal places)
.15mm becomes .006” or six thou
.4”, .6” and ..8”  In French  become 10.16 mm, 15.24mm and 20.32mm respectively
Proper massive difference
Offline John Warner
« Reply #49 on: February 19, 2025, 04:31:19 AM »
Now that would make it REALLY noisy!!    :shocked:
Thanks for the explanation Bulldog, I'd misunderstood the full reasoning behind the ALP Reset.    :thumb:
Doc out . . .
Online Bulldog9
« Reply #50 on: February 24, 2025, 05:02:43 PM »
LOL.... Yes, laziness. I neglected the .00. Is self evident, but good catch. .006"=.10mm........ .008" = .15mm
I edited the original.
« Last Edit: February 24, 2025, 05:04:31 PM by Bulldog9 »
MGNOC#23231
« Reply #51 on: February 24, 2025, 11:51:02 PM »
Sadly not, that was my point of giving conversion, the decimal point bit just humour,
Unless merkan inches are smaller than ours ?
.004” is .1mm using world std inches ! .006” is .15mm, .008” is .22mm
« Last Edit: February 25, 2025, 01:50:26 AM by jacksonracingcomau »
Online Bulldog9
« Reply #52 on: February 25, 2025, 09:44:13 AM »
No, same standards, just poor memory. I'm tracking, just goobering it up with my fat fingers on my small screened cell phone and not stopping to check. .004 & .006in are .10 & .15mm, and  .006 & .008in = .15 & .22mm.
Regardless, rechecking my notes, a Beetle Mapped 8V roller's recommended Valve Clearance for roller tappet bikes: 0.10mm (4 thou) Inlet, 0.15mm (6 thou) Exhaust rather than the .006 & .008. I had them switch AND shuffled.... lol.  Thanks for keeping it straight.
This is why BTW, I decided to stick with .10 & .15mm (.006 & .008") on all my bikes: Breva 750/Griso/1200Sport/Norge/Stornello except for Convert which I use .009mm. I have a hot rod Type 4 Motor in my 912 that uses elephant foot adjusters (like most Guzzi's) and stainless steel pushrods. That is 0 clearance. Thankfully, I have all this on a laminated tag taped to the frame rail because I have a bad habit of reversing and getting mixed up. Lysdexia is a thing  :evil:
Gotta cut back on the Post Retirement winter Bourbon consumption :bow: :boozing:. It's a nice day today and over 50, so I think I'll take my .004 & .006mm valve clearance Beetle mapped Griso for a ride.
MGNOC#23231
Offline Moparnut72
« Reply #53 on: February 25, 2025, 10:56:50 AM »
I had Airheads for many years which used the .006 and .008 so not hard to remember. :thumb:
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
