Author Topic: Electronic Ignition replacement for 1978 T3 850 ??  (Read 39550 times)
Offline C5Performance
    • C5 Performance Inc
Re: Electronic Ignition replacement for 1978 T3 850 ??
« Reply #30 on: September 15, 2013, 11:37:01 AM »
I wanted to clarify a few things. We own C5 Performance Inc and develop ignition kits for all types of vehicles, even cars. PowerArc is the company who invented and manufactures the coils and ignition modules. It is a great relationship but we are seperate companies.
Because we feel this ignition is so far ahead of what has been available that C5 ignitions only use electronics from PowerArc. We are always working on new projects and older Guzzis are one of them.
Offline acogoff
« Reply #31 on: September 15, 2013, 12:44:34 PM »
      Be afraid, be very afraid, points are very unreliable, I am on my second set now in 36 years. And it is such a chore to dab a spot of grease of your choice behind the wear fibre every couple of years. And then there is the additional expense of having to purchase a toothpick to put the grease there. Never seen the need for a dyna at this point.
Marshall County Minnesota USA
Rough Edge racing
« Reply #32 on: September 15, 2013, 01:03:20 PM »
 C5,Power Arc offers multi spark ignitions for the older Triumphs ? I assume the system goes to single spark at higher RPM's?  What I'm interested in is an ignition that can drive a low resistance coil.I run a Pazon on my race Triumph and it's a good system but only allows a 3 ohm coil.Not enough energy to open up the plug gap wider than .025 without misfiring at high RPM's.I would really like to experiment with a wider plug gap..
reluctor
« Reply #33 on: September 15, 2013, 03:01:02 PM »
Some info here using an automotive set up
http://forum.guzzitech.com/forum/197/9625?p=72540&hilit=chrysler#p72540
Edit to add
The Chrysler powered Sport
http://www.youtube.com/watch?v=V8NuRFhO_ik
« Last Edit: September 15, 2013, 03:54:38 PM by reluctor »
Offline redrider90
« Reply #34 on: September 15, 2013, 04:26:35 PM »
There are a couple of new units on ebay right now.
As for the intermittent one cylinder dropping out I would have the black box checked. I had the same problem and sent the unit back to Dyna. They set it up on the bench and had to run the unit until hot to get to act up.
Red 90 Mille GT
« Reply #35 on: September 15, 2013, 09:02:32 PM »
NOOOOO...our ignitions never shut multi spark off. We are the only ones that I know of with technology that allows full rpm multiple sparking.
We have sold many ignitions for British bikes, and in two weeks I am going to the Bonneville Salt Flats to help with a supercharged Triumph.
PowerArc has sold thousands and thousands of ignitions over the past 15-20 years.
Our role is to provide new development for this technology, to provide technical assistance for customers, and to be PowerArcs new global distributor. We already have new dealers in Norway, UK, and many here in the USA. If you have specific questions about any project I encourage you to call or email me. I'd love to help out. 920-810-0946 paul@c5ignitions (dot) com
« Reply #36 on: September 15, 2013, 09:55:49 PM »
I noticed a hint of sarcasm  ;D
You will probably love what I am going to say: I LIKE POINTS.
They usually don't just fail, meaning you could limp home. They are cheap, require minimum labor to keep clean and adjusted, and I've never hated them.
So why did I start a company that develops and sells electronic ignitions?
The modern battery/coil/points system was brought main stream in 1910 on the Cadillac car. That's OLD technology at best.
Less and less mechanics and riders really know how to clean and adjust points for maximum performance and reliability.
Fuel has changed drastically...I do not believe stock coils with points can effectively burn these modern mixes.
I would argue that coils fail much more frequently than points do, but MOST mechanics do not properly troubleshoot this issue.
You don't run points in your car, you don't use a TV with a dial (although they never failed), and you don't use a rotary phone.
I have seen many Hall Effect style electronic ignitions fail, but I've got some great information as to why, and also why optical ignitions dont.
Here are a few BIG advantages the guys in Iowa (PowerArc) have given us for our new C5 Performance ignitions:
Optically triggered ignitions are not affected by heat, surrounding metal components, or the inherent inaccuracy that magnetic systems have.
Section Bobbin coils are the strongest, quickest refreshing coils made. We only use section bobbin designs.
Accurate coil saturation is critical, and they track rotation 90 times more than a standard ignition to keep coils from overheating.
Multiple Sparking is awesome. It helps starting, smooths out idle, increases performance and efficiency, and our kits continue multi sparking until redline.
IF....and this is a big IF....you choose to upgrade your points operated ignition to something newer that never needs adjustment, then take the time and learn about the key points of each design (Hall effect versus Optical) and understand how big of an advantage multi sparking is. I have many customers who are waiting for an invitation to share their story, if anyone wants to hear them?
Thank you for sharing your opinion in a funny way...i loved the way you stated that :)  Point taken sir!
Offline redrider90
« Reply #37 on: September 16, 2013, 11:11:36 AM »
Many years ago when I was replacing that god awful Motoplat electronic ignition for a Dyna Joe Eish said the same thing to me. I needed a used distributor to put the Dyna in as the Motoplat would not accept the Dyna. Joe said just drop the points distributor in, time it and let it go until it stops. He laughed and said he has not touched his points in 70,000 miles. I should have listen to him as Dyna has been VERY unreliable. 3 coils dead and one black box/ECU/CDI or whatever you call it also shot.  I had it set up to do a turn key drop the points in system but I have had the Dyna apart so  many times I think my wiring harness i made for the change over will need modifying to put the points in.
I would highly suggest staying away from Dyna. I have heard and had my share of horror stories.
Red 90 Mille GT
Bill Havins
« Reply #38 on: September 16, 2013, 11:51:52 AM »
Many of you are aware that I really appreciate "modern" electronics.  But, if I had a Guzzi that came from the factory with points that's exactly what I would leave in it.  As has been said above, points are as reliable as a stone axe.  Once set up, they survive the harshest of conditions for years with very little maintenance.
If the goal is a bike that starts and runs well time-after-time then a points setup is the ticket for an older Guzzi.  If you just want to tinker with "new stuff," then go electronic ignition.  But don't throw your old points set up away - you're likely to need it at some point.  And by all means keep your battery in good condition; if you need to charge the battery consider doing it off the bike.
IMHO.
Offline lrutt
« Reply #39 on: September 16, 2013, 01:56:04 PM »
How forgiving of low voltage is your system? As pointed out elsewhere, Dynas like full V. Points seem to be able to run on a glimmer. I assume your system is weighted a little more to full V?
Problem is these damn AGM batteries, when they fail, they really crap, points or not you're sunk.
« Reply #40 on: September 16, 2013, 09:52:10 PM »
With no modifications you can safely run a 12 volt down to around 6 volts. If you need a system for a 6 volt car or cycle we make changes that allow you to get lower. On the other end, its got spike protection for 25 volts.
The biggest killer of any electronic ignitions is not low voltage. It's a pulsing of voltage from faulty ignition and kill switches or poor wiring.
The best protection for that is a capacitor. Let me know if you have special issues or questions. We'll do the best we can to overcome them!
Let me ask you guys this...what usually causes issues on Guzzi's when using electronic ignitions?
Offline sparrowhawwk
« Reply #41 on: September 16, 2013, 11:04:51 PM »
  I find it interesting when one attempts to share an experience they have had with a product, good or bad, some people have to jump in and criticize or make some comments to try and show how what they do is better even though the person posting the original message was in no way saying anything bad about their choice or any other option.  Case in point.  My post in no way made any criticism of using points.  In fact, I said I had gone back to points after failures left me stranded too many times.  Others have made known how great Dyna was at helping them when a problem occurred, and I agree.  They do.  Problem is, I travel with my bikes and I don't mean those long 500 mile trips.  That is the first day!  I don't want to be left broken down on the side of the road in the middle of nowhere.  And yes, I can fix my own bikes usually on the side of the road like BJ used to do, well, not as quickly  ::), but that is not a part of my travel plans.  Again, that is why I went back to points!
  That said, (now I feel better ;D) there are many reliable ways to make ignitions work.  I have probably tried most of them and I can tell you this, none of them have given me the engine performance I have now.  Quicker starting, better idle and a real noticeable difference in power and throttle response and a grin on my face every time I ride it.  Only time will tell but with the multi sparking (at all RPM) I suspect mileage will also increase.  Engine vibration has also diminished to a much more pleasant level. I believe this may be due to the fact I am not trying to get two sets of points to work together on opposite cylinders.  Oh yeah, and no black box, advance weights/springs or points to set.   As for reliability this is not a "new" product.  With over 15,000 units sold to HD's over the years as well as other bikes, it is a proven product.  Just the application is new.  I just discovered a well know Norton specialist in my area has been installing these for some time.
  Well, tonights project is to start the quest to check/adjust my timing chain tension.  That's always fun!  I put a new chain and automatic tensioner in my other convert last year.  Don't think I'll use an endless chain next time.  I did it ok but I find as I get older my patience is not what it once was.  Does it show?LOL
« Reply #42 on: September 17, 2013, 12:17:31 AM »
I'll give you some information generic to all electronic ignitions. In fact, it is accurate for every ignition including ours:
Key points to avoiding failure is HEAT reduction (coil saturation control) and the quality of the trigger (points, magnets, or optical reader).
Points actually have good saturation control because the lobe determines dwell. The downside is BY DESIGN coil saturation is excessive at low rpm to avoid coil misfire at high rpm. Think of it as leaving the bathtub water on so long it overflows, just to avoid not having enough water to take a bath.
Most electronic ignitions have horrible dwell control. With one or two magnets, there is no way for the ignition to know where the crank position is. How does it know when to turn the coil on so it starts to fill? It is a total guess. As a result, the ignition companies using Hall Effect sensors leave the coil on for a very long time so there is no misfire at high rpm. The coils get too hot and short out, especially if you drive at low rpm alot. When you see a coil with the metal bar running through it, this is called an "I" core design. It mounts to the frame so heat is drawn away from the coil to help cool it.
Section Bobbin coils are the strongest and quickest filling coils, but they can't handle any heat. So if the "I" core style coils fail from overheating, why use a design that handles even LESS heat? PowerArc ignitions have unique ways to manage dwell control. You notice all the slots in our encoder? As the crank or cam rotates, this wheel continuously tracks crank position using dual optic beams. Now we can turn on the coil EXACTLY when we want. It's also easily adjusted with our programmer kit.
Remember: Heat kills coils, dwell control is key to reducing coil heat, and you cannot accurately control dwell using one or two magnets. You have to think outside the box.
« Reply #43 on: September 17, 2013, 08:29:36 AM »
What are you thoughts on CDI?
reluctor
« Reply #44 on: September 17, 2013, 09:47:48 AM »
On a Guzzi you have one coil for every two crankshaft revolutions. In an automotive vehicle you have one coil (to fire) for every 16 crankshaft revolutions. So you can see that the time for coil saturation in an automotive application is much more critical than in a two cylinder engine with two independent ignition systems. In other words the Guzzi coil at 10,000 RPM would fire 5000 times in 1 min. or 83 times each second.
In the automotive application it would be eight times as much or 664 firings per second. This means coil saturation or a full spark would be tougher to generate with eight cylinders as opposed to essentially one on the Guzzi. So a CDI with the much higher voltage is more applicable to an automotive application and high rpm to obtain more complete coil saturation. Drag racing would be a good application. CDI in a Guzzi would be superfluous and in fact problematic since you would need coil wires to contain the higher voltage. Any leak would result in misfires.
I had a CDI in an old Oldsmobile and the spark would jump about 4 inches. It was useless for street application since the spark would always eat through the core wires somewhere and short out.
I use automotive coils on my V7 sport and even at that I have to tame down the spark with a ballast resistor because otherwise the coil wires cannot contain the spark since coil saturation occurs easily and the bike redlines at only 7,000 RPM. Now my Yamaha with an 11,000 redline has CDI.
Offline redrider90
« Reply #45 on: September 17, 2013, 09:58:19 AM »
One of the first mods I did back in 73 on my Ducati 750 GT was put in a pair of massive Chevy coils+ large condensers.  I strapped them to the outside frame and they worked very well compared to the tinnie winnie stock Ducati coils.
Red 90 Mille GT
« Reply #46 on: September 17, 2013, 01:23:21 PM »
Interesting information. Has anyone had "personal" experience with waste sparking these? I have been asked if it works good, and have heard different opinions from Guzzi shops.
Am I to assume most electronic conversions use stock OEM coils?
Thanks for sharing information about these bikes. I have learned alot already!
Offline Matt Story
  • Flint, MI
« Reply #47 on: September 17, 2013, 02:46:40 PM »
Your probably aware already, the Dyna III is typically installed as a retrofit using the stock coils.
'75 850T - First & only owner
'77 Honda CB750 Supersport
'02 BMW R1150RT
Flint, MI
Rough Edge racing
« Reply #48 on: September 17, 2013, 03:27:39 PM »
 I have a few comments on what you say. CDI has a very short spark duration. That's why many of them use multiple sparks,especially at lower RPM's...I ran multi spark CDI boxes on high performance auto engines and never ate up wires. No matter what often unreal claims about high voltage coils, if you watch the spark of a running engine on a scope,the voltage to fire clean plugs in a non supercharged engine is less than 10k volts. The plug life can be shorter on a multispark system.
  A 12 volt coil ignition gives best point life at 3-4 ohm primary coil resistance. Using less resistance will burn up the points quickly due to the coil drawing excessive current. As far as too much the spark.... plug wires can't contain the spark? Must be very inferior wires. . In fact back before electronic ignitions many drag racers ran low resistance coils to give more spark because point life wasn't a concern.
reluctor
« Reply #49 on: September 17, 2013, 04:30:51 PM »
I have tried various combinations such as two pickup coils and one control box and vice versa one coil and two. The best combination used a Harley coil. The problem with the wasted spark at least on a V7 sport is that one wasted spark is on an intake stroke. I found that at the higher RPMs six or 7000 I could feel some breakup. At the lower RPMs it ran fine. This might be a quirk of the V7 sport because of the cam overlap so I don't know how the application would work on other models. Ultimately I went back to two independent ignition systems. This way if even a control box goes bad I still have half the engine to get home.
Offline Pancake
    • www.dominicsnow.com
« Reply #50 on: September 18, 2013, 04:03:01 PM »
How much is the set up for a tonti guzzi from C5?
May all beings be happy
« Reply #51 on: September 18, 2013, 07:55:58 PM »
  The C5 that I put in my Convert is $492.   This includes much higher quality replacement coils and plug wires.  The part I'm still having trouble describing to people is the way the bike works now.  With a high end ignition I expected it to run and idle better.  Was even expecting it to start a little quicker although that has never been a real problem with mine.  Sometimes a little squirt from the accelerator pumps and hit the button one more time and it was running.  I always had to leave the chokes on for a couple minutes to eliminate the sput and pop during warm up but overall I never thought of it as bad.   Now it is like I bought a new bike.  One touch of the starter and it is running.  On a cold day I can start it, pull out to the end of the driveway and shut the chokes off for a nice steady idle.  I can pull out into traffic confident it will not do anything wrong.
  Ever since I have owned the bike, about 76,000 miles worth, I have felt I needed to be gentle on the throttle for the first ten or twenty feet to give the torque converter time to tighten up.  Not any more.  Turn the throttle and go.  Where I used to occasionally glance at the speedometer to be sure my speed had not dropped off it is now the opposite.  Now I am constantly having to drop my speed slightly to be back at the speed limit.  This is one of the things that has put the fun back in riding my bike.  I am constantly finding myself grinning at the way it responds to the throttle.  Of course the old Convert with the big sidecar and dressed to tour will never be a sport bike but the difference in performance is something I was not expecting to be so great.  Actually I did not believe what the result would be until I installed the ignition and rode the bike.
   The other thing is the ease of installation and setting the timing.  Gone is the need to worry about aligning the distributor gears when installing it.  I installed my C5 in a spare distributor first.  I actually installed the new coils and plug wires first and used them with the original distributor and points so when it came time to install the C5 distributor I just unbolted and removed the old distributor complete with weights, springs and points plates.  Next I dropped the C5 distributor in and tightened it down and ran the wires to power, ground and the coils.  Then I put the left cylinder to TDC and turned the ignition on.  Next I rotated the encoder wheel until the small red LED on the unit lit up and locked the wheel down.  Timing done!  Install the distributor cap and start it.
   I had to play a little with the carb and idle adjustments and went riding.  No timing lights, no rotating the engine to find the right cylinder timing marks and more trying to get the two sides in sync.  And on top of that I have four different curves built in that can be accessed simply by various combinations of two ground wires.  Actually I now have it on a neat rotary switch that allows me to change curves at will on the go.  This thing is more fun than my video games. LOL
Offline Furbo
« Reply #52 on: September 19, 2013, 02:24:41 AM »
Indeed. I needed to replace the MotoSplatt in my 91 SP III, dropped in a points dizzy from a CAL II and never looked back. Adjusted it once a year (gap & lube, then set timing with lite at full advance) in the winter same time I did the valves and changed oil.
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Michael H
« Reply #53 on: September 19, 2013, 06:58:55 AM »
The Cali II points swap would work on any motoplat ignition bike then including small blocks?
Offline redrider90
« Reply #54 on: September 19, 2013, 08:37:24 AM »
Big block distributors do not fit in small block Guzzis. Am I correct guys??
Red 90 Mille GT
« Reply #55 on: September 19, 2013, 11:33:38 AM »
That would be correct. The small block normally benefits from installing the Dyna S, which is a different animal.. no black box.  Seems reliable enough. I use the Dyna S as a secondary ignition on a homebuilt aircraft. <shrug>
Offline Furbo
« Reply #56 on: September 20, 2013, 02:41:33 AM »
Good point! While the big block points set up is quite good - IME the small blocks benefit greatly from a Dyna S. It's just an electronic trigger, like a petronix you might stick in an air cooled VW.  I use a slightly modified Dyna S meant for a Honda 750 in my Laverda SF.
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline racasey
« Reply #57 on: October 18, 2013, 10:44:33 AM »
I love points and would like to buy a set for my V65SP
Not just the points, but the mounting plate as well.   My sad cafe racer project bike arrived with a Dyna S and I would love to replace it with ... the original mechanical points.
Might some one here have a the old points, condensers, and mounting plate laying around, and care to part with them?
I have the mechanical advance system, just need the bits above the bob weights.
Ciao,
Dick
Vashon Island, WA
USA
84 V65
1090RR MV Agusta
Paul Smart Ducati
'66 Velocette Thruxton VMT 334
'63 Aermacchi 250
Seeley MK-III AJS 500
Offline Pancake
« Reply #58 on: October 18, 2013, 03:36:28 PM »
The system you describe sounds very interesting but seems quite expensive compared to its rivals.
Offline redrider90
« Reply #59 on: October 18, 2013, 06:04:51 PM »
How many of us have been stranded by points. I have had 3 or 4  dyna coils go bad and one black box. I was real luck to get home. I was only 10 miles from home and the black box would die and then cool down and then restart. Now what happens if I am 200 miles from home. Yes sure Dyna was great about it but I have had way too much trouble on with this. Not as bad as the moto plat but still a piece of crap. Now that I have new coils and new black box I'll not change back to points for the moment.
Red 90 Mille GT
