Author Topic: V7 Stone Stock Seat is a Butt Buster  (Read 28366 times)
Offline Kev m
Re: Re: V7 Stone Stock Seat is a Butt Buster
« Reply #30 on: October 02, 2013, 10:04:42 AM »
I was the opposite. I bought the lowered gel seat for my Breva so Jenn could ride it, but it was so comfortable I left it on all the time and used it myself even though I didn't need the lower height.
Offline DaSwami
« Reply #31 on: October 27, 2013, 12:08:23 AM »
Corsa makes some 'modified' seats...they don't look too different from stock, but from the pics they 'seem' more padded.  Quite expensive, though. Imagine you could have an original modified for less:
http://www.corsaitaliana.com/index.php?f=data_v7_classic_&a=0
Those look very nice. Hmmmmm
« Reply #32 on: October 27, 2013, 09:24:59 AM »
Several people can redo the seat for you.
Mayer, Rich Maund, Sergeant, Russell to name a few.
You can even have a local shop do it if they have worked on bike seats before.
Or, you can do the foam yourself and have a custom shop do the cover.
http://www.diymotorcycleseat.com/
Offline DaSwami
« Reply #33 on: February 27, 2016, 12:25:02 AM »
And so here we are 2+ years later, I like my new V7 II Stone, the seat isn't bad...but it's not as comfy as my CB1100 or Scrambler seat.  Looking at them all side by side,  I notice the V7 seat is  3-4 inches more narrow than the others.  Maybe that is one key to the (lack) of comfort.
I also would like to be about an inch higher on the bike.
+1 on Sargent, I had a World Sport adventure on my DR650 and it was the bomb in quality and comfort.  Molded right to your bottom after awhile and never any pressure points.
Anyhoo, any "new" solutions out there?
« Reply #34 on: February 27, 2016, 02:12:46 AM »
The King of Fleece seat mods work very well.  You can see a picture at the FaceBook page of a V7 and Norge seat that we rebuilt.  It's not just cosmetic.  As for gel, I've found the marketing and performance of gel to sit on just under the surface to be at opposite ends of the spectrum. I'm not a fan of that at all.  Correct foam (and there's quite a few parameters that need to be addressed) and correct shape are the tried and true.  For instance, look at Russell or BMS.  No gel seating stuff, just correct shape and materials.  Where the correct type of gel does work is directly on top of the stripped seat pan followed by the layers of foam which are built up on that.  For those really interested, it's not the simple gels that were made for hospitals but rather an engineered product shaped a bit like a waffle that will deflect weight and rebound in a controlled manor.
That said, there's always those for whom pads and stuff works.  Just as there are those who are fine on a stock seat.  There is no "correct " way as everyone likes what they like.  However, being in that end of the motorcycle business, working with some of the best seat makers in North America, building my own seats, and talking to over 1000 different customers who use my seat covers, the overwhelming majority of what I hear can be summed up in "shape and materials".
The AirHawk, when correctly inflated, is another way to skin the cat that works great for plenty of riders.  In the end, no pun intended, it's all about pressure point management, and there's lots of ways to get there.
« Reply #35 on: February 27, 2016, 02:24:05 AM »
Guess I should add:
Just trying to share a bit of what I've learned along the way-like most here.  That's the fun part.
There's a ton of things that go into making a comfortable seat, and what's always interesting is that we're all different in what's considered "good".   One thing I learned long ago from Iron Butt Rally guys is that one of the major factors in long distance comfort is the ability to vary the pressure points.  More to the point, being able to shift up and back to a small degree every 15-20 minutes or so prior to discomfort setting in is huge.  Any seat that locks the body into one position was considered a poor choice for the guys who bang out 1000 mile days one after another.  Pelvis tilt is another factor not to be overlooked.  Rocky at BMS knows quite a bit about that and his seats reflect his skill in seat making for LD comfort.
Offline pikipiki
« Reply #36 on: February 27, 2016, 04:08:39 AM »
Guess I should add:
Good point.
I have a lowered gel seat. As I understand it the idea with gel is that you sink into it enough to distribute your weight more evenly across your butt - so the theory is no pressure points. but move to adjust your position (especially on a very flat seat) and the gel adjusts to be the same as before.
I modified my seat to add extra foam padding I find the extra foam is more comfortable - it may be what I achieved is being able to vary pressure points, or it may be psychogical although Im sure I achieved a little more springyness.
for what ever reason for me 3/4" of foam down the middle and less to the sides which is almost invisible difference makes a comfort improvement - I wont be buying a new seat now.
« Reply #37 on: February 27, 2016, 08:15:28 AM »
Yep.  Another thing with gel pads just under the surface is that they act as a heat sink in summer.
One of the things we do at the shop is leave different seating surfaces (installed on seats) and take reading with a laser thermometer.
We also measure what our covers do or do not add/subtract to any heat sinking.
Here is an example.  As we know, air is a good insulator.  When we install a seat cover on a dished seat the temperature of the seat surface will drop by a considerable amount.  It can be as much as 18-20 degrees F lower.  Our material is stretchable as well as waterproof.  When installed, it will "span" the dish portion by being suspended above it.  As the rider sits on the bike the cover will stretch under their weight and will be undetectable to the riders backside.  This is important-remember the pea and the princess.
Anyway, the air gap under the cover has acted as insulation and the result is a much cooler surface for the rider.  Our AZ, LA, FL, and such customers are quite fond of that feature.
Offline fossil
« Reply #38 on: February 27, 2016, 01:17:18 PM »
For a year now I have the Comfort Gel - seat in normal size. It is a bit shorter of the stock seat and looks better in my opinion. But it is hard. It is a bit more comfortable than the stock seat for me as it is narrower at the edges directly behind the tank. This is the region my stock seat causes me pain after an hour or so.
At my dealer I sat on a V7 II equipped with the full program from the "Dapper" line of Guzzi Garage. The bike had a single seat that according the dealer stems from the Cafe Classic seat. It was good. I will be able to put it onto my Stone soon and test drive it for several hours. I will report the outcome.
« Last Edit: February 27, 2016, 01:18:28 PM by fossil »
Greetings from Germany!
Thorsten
Offline DaSwami
« Reply #39 on: February 27, 2016, 11:55:02 PM »
OK, I'll bite, what did you do to that seat?  And is that something you do for customers seats that are shipped to you?
« Reply #40 on: February 28, 2016, 01:52:53 AM »
We use a column buckling polymer gel with 1/4" columns.  This allows the product to deflect and rebound as well as absorb vibrations.
It's placed directly on top of the seat pan and then the foam is built up from there. All foam is open cell which allows air to move in and out of the foam.
Foam can be open or closed cell, for starters.  Both have advantages.  I like different density and weights of open cell foam.  Closed cell, the kind that needs to "break in", is very firm (which is ok for some) but the riders weight is going to have to break down the foam over time for that custom fit as air will not move thru it.
Open cell lets the air move thru the foam and when done correct will be plenty firm, which is key in my mind for support.  It won't require a break in period.  Mind, it's NOT soft as that is one of the reasons plenty of stock seats are lacking for the majority of riders.  As an aside, "blowing thru" the foam and getting your butt bones close to the seat pan is not a good thing.
Finally, memory foam gets mentioned a lot.  There are, to the best of my knowledge, two generations of this product.  Only the 2nd generation, which (of course) is much more expensive is suitable for use in a motorcycle seat.
As I've mentioned here in the past, seats and screens are very much an individual thing.  What we do is based on experience and customer feedback as well as my working with several well respected aftermarket seat makers on seat covers.  I try to keep the OEM look with some minor shaping changes where needed and then add something that makes it a bit different in the style department.
A guzzi logo, a custom embroidery, a leather insert (or my favorite Alcantra, which is fantastic in the warm weather but needs a bit of care), a tri color flag, that kind of thing.  For the major shaped thing, you can't go wrong with Russell or BMS IMHO.  For more of the OEM look-that's where I focus.
There is quite a bit more but this is an overview.  Am I the greatest thing since sliced bread?  Nope.  Can I make a stock Guzzi seat a lot better?  That's closer to it.  Can I make a 1000 mile a day seat?  Yes, if you have a 1000 mile a day rear end!
Finally, I'm a big fan of having a bit of fore and aft room on a seat.  I believe it's critical to be able to move slightly during a long(ish) ride so as to vary the pressure points created by your "butt bones".  Slight movement changes the angle a small bit with very positive results in term of comfort.
Offline swordds
  • (504)234-9011
« Reply #41 on: February 28, 2016, 06:13:34 AM »
I could go about 250 miles on the stock seat so I  bought an Amphibious Soft Seat from Moto Machines. It is a self inflating adjustable aircell seat pad (like a camping roll-up sleeping pad) that attaches to the top of the seat and that works for me.  I also have an Amphibious dry back pack that I strap to the passenger section of the seat for carrying rain gear. I think it is well made quality gear.
I suspect you no the cold start problem has been fixed with the most recent factory dealer remap?
2016 V7II Stone
2016 Suzuki TU250X (lost in the great flood of ought 16)
In the future I will strive to tolerate everything except intolerance and to hate nothing except hatred.
Offline DaSwami
« Reply #42 on: February 28, 2016, 11:54:21 AM »
Well you answered my first question, but not my second.....or maybe you did....
« Reply #43 on: February 28, 2016, 10:04:04 PM »
Sorry.  I get carried away.  Seats and seat covers are important to me-I have no idea what that says about KoF as a company!
Sure, we do.  Case by case basis.  Nothing off the shelf.  A rebuilt seat can look the same as stock if desired, or not.  Customer call all the way.  To be clear, though, shape change is minor if requested or needed (for instance if the OEM seat is convex).  For many, the shaped seats from BMS and others is the answer.  A lot depends on anatomy.  Or desired look.  And I'm a BMS owner as well as Russell and Seth Laam, among others.  These are all good choices.
As the V7 seat is, in my opinion, short for the driver when stepped, as from the factory.  I recommend that the step be removed so the seat is level front to back.  This allows the rider to move fore and aft as needed.  However, you don't have to have it done that way and if you ride two up it's most likely not the best choice.
The other big decision is top material.  Leather, vinyl, or Alcantra.  Leather looks great and due to the open cell foam under the surface will breath a bit.  Vinyl is "use and abuse".
Top of seat can be smooth, tuck and roll, diamond stitched, and so on.
Offline DaSwami
« Reply #44 on: February 29, 2016, 09:55:33 AM »
KoF,
Sorry my man, you may be the seat guru, but your salesmanship needs work....I still have no idea whether you want to help me or not.
"As the V7 seat is, in my opinion, short for the driver when stepped, as from the factory.  I recommend that the step be removed so the seat is level front to back.  This allows the rider to move fore and aft as needed.  However, you don't have to have it done that way and if you ride two up it's most likely not the best choice."
YES.  So you raise up the front to match the rear?  Perfect.  Do you want an order or not??  Are you a vendor here??  Contact info??  Prices?  Turnaround time???  PM outreach?
« Reply #45 on: February 29, 2016, 11:46:41 AM »
That's funny.  Feel free to email me at info@kingoffleece.com.
I can get a seat done for you but we'll need to chat.
Vendor here?  I missed that section if it exists.  I will, though, and have mentioned this before, donate back to he forum in excess of what I have alreadyy sent in simply as a member if a forum member needs something.
I don't know about "guru" but I have been fortunate enough to work with and learn from some talented people on top of what I have actively searched out.
I'm not much of a Facebook guy (the web site company does most of that badly I'm told) but I did manage to post a picture of my V7 seat and a Norge seat for a customer.  I also made one for Todd at GuzziTech.  He may at some point post up a photo.
Jim
Offline DaSwami
« Reply #46 on: March 24, 2016, 12:20:20 PM »
Tag.  Just received a deluxe padded seat from AF1, it's a 1/4" taller than the stock seat, I will test her out as soon as the weather clears.
If anything, gives me a spare seat to use while my original stock seat is sent out for a real makeover.
Offline DaSwami
« Reply #47 on: April 02, 2016, 08:58:52 AM »
What's even funnier is that I've emailed you twice with no response.  Moving on....
« Reply #48 on: April 02, 2016, 09:20:30 AM »
I never got any e-mail from you.
Offline Toecutter
« Reply #49 on: April 06, 2016, 08:39:30 AM »
The seat on my V7 beat the crap out of me for a few thousand km, but now, at 9000 km it's really comfortable. It just took dedication.
I've put some 800 km days on it, too.
I've made several custom seats for people, usually "cafes" and "choppers", I suggest good foam over gel. Gel sucks. Proper thickness and density of foam is so much more comfortable. I take the bicycle saddle approach. You need *firm* to support your "sit bones". If your tailbone hurts, it's due to either A) crappy posture or B) TOO MUCH padding, allowing you to sink into the seat, which puts weight on your tailbone instead of your sitbones. Padding is great for short distances, that's why you see big puffy seats on bicycles that get ridden for 3 km every month or so. But commuters and riders? They go for firm saddles, like a Brooks.
I plan on building my own V7 seat here shortly, but I want to find an extra seat pan first... someone's take off, or damaged seat.
« Last Edit: April 06, 2016, 08:46:12 AM by Toecutter »
Offline DaSwami
« Reply #50 on: April 06, 2016, 02:24:04 PM »
I understand what you are saying, longterm break-in on a firm seat makes for a comfy saddle.
Still, I want another inch of height on the saddle, and I have no other options other than custom.
My stock seat just got delivered to Sargent Cycle today, specs call for a 1-inch height increase with super cell atomic foam and a more bench-like seat profile.  Can't wait!!
Offline Rox
  • What's a Goozy?
« Reply #51 on: April 08, 2016, 09:09:27 PM »
You can always take it to an upholsterer and have them shave down the cushion and fill it with gel. I had an issue with my v11 seat. After a few hours my ass was numb and lower back hurt. All I did was have it reupholstered in alcantera and slightly shaved the foam and filled it with a gel. Now it's more comfortable than a Corbin. Sorry, Corbin. :whip2:
02 V11 Lemans
02 V11 Scura
14 Honda CTX1300
07 Yamaha R6
Offline V7Sport73
  • Anthony Riselenger in El Paso
  • Anthony In El Paso, TX
« Reply #52 on: April 08, 2016, 10:42:29 PM »
A saddle is something you just have to get used to.  Like riding a horse.  The first few days are miserable.  But you get used to it.  I've owned lots of different seats on lots of different motorcycles.  After about 200 miles they all start to get uncomfortable.  You just have to stop and take a break every once in a while.  The gels by the way become superheated if left out in the sun!
Currently own several Guzzi's.  Been a Guzzi owner since 1988.
« Reply #53 on: April 09, 2016, 05:21:02 AM »
Sargent makes a nice product-you'll like it.  A flat seat is a good thing on the V7.  Like I said, I never received any e-mail from you.  So be it.
As for 200 mile seats-yea, that's typical for stock offerings.  We cover plenty of custom seats for IBA competitors and two of my customers are winners of annual mileage contests for the BMWMOA.  These riders need seats that perform for, at times, 1000 miles a day for 11 days.  Aux fuel  supplies means that they are sometimes in the saddle for 500 miles at a time.
Over the years a lot of knowledge has been learned from folks like this.  That experience gets incorporated into product development.
