Author Topic: Aero engine rescue  (Read 911775 times)
Offline jacksonracingcomau
Re: Aero engine rescue
« Reply #270 on: November 30, 2014, 07:09:57 PM »
Just out of left field
From on here, not my personal experience, Larios did have a cam wear problem (like current 8V but blamed on valve spring pressure)
Just maybe the .021" difference is worn lobe on Lario, aero cam is exactly the same but unworn ?
Would explain the duration figures being the same.
In which case, if as stated here, Lario & V65 were the same, fitting orig V65 cam will not be changing anything.
Lift in book for Lario and V65 cam anyone ?
« Reply #271 on: December 01, 2014, 05:38:59 AM »
That's apparently not for the great unwashed masses to know. I haven't found diddley squat about the cams. Shirley  ;D though, if the Lario cam was worn that much there'd be signs of it? I'll ping Milich one more time. He's probably getting tired of me bugging him.
Offline lucky phil
« Reply #272 on: December 01, 2014, 06:16:02 AM »
You dont measure cam timing at the pushrod you measure it at the valve. Trying to measure cam specs at the pushrod doesnt take into account the rocker ratio and the change of contact point of the rocker foot on the valve tip as the rocker rotates through it travel. So even if the rocker ratio is 1:1 you still wont have exact cam timing figures.
If the rocker ratio is not 1:1 then the lift figures will be wrong as well.
If you measure at the valve you can then compare cam timing from spec sheets.
Ciao
« Last Edit: December 01, 2014, 06:19:09 AM by lucky phil »
« Reply #273 on: December 01, 2014, 06:31:40 AM »
Ciao
Aw.. you're still upset because I put those Gaudy Gaiters on the Lario.  ~; ;D Crane cams info says to it just like I did it. http://www.cranecams.com/bulletins_listview.php?s_id=5
I won't argue total lift at the valve, though.. you're absolutely right. When I get around to it, I'm going to pull a head and check clearances, figure compression ratio, etc. to add to the collective knowledge of this engine.
Offline lucky phil
« Reply #274 on: December 01, 2014, 07:39:36 AM »
Crane make cams, they dont build engines. What engine builders are interested in is what happens at the valve after all the clearances are taken up and the pushrods flex etc etc.
The same reason serious engine builders dont use light dummy valve springs when doing valve timing and working out rocker post heights etc.
Ciao
« Reply #275 on: December 01, 2014, 07:49:41 AM »
Ciao
Certainly, but degreeing a cam is degreeing a cam. We were looking at the differences between the aero cam and a Lario cam.
Offline lucky phil
« Reply #276 on: December 01, 2014, 08:39:56 AM »
Yes I understand Chuck you are doing a comparative exercise using the same methodology and I applaude you for the work you put in to show this stuff but Part of that good stuff is the info thats passed on.
For the purposes of people that are reading this thread and may be thinking of using it as a reference for doing their own cam timing its good to point out that your method isnt exactly the standard procedure.
As for the Lario gators, well we have a saying here in Australia......you cant polish a turd,.....but you can roll it in glitter. Or put gators on it.
Ciao
« Last Edit: December 01, 2014, 08:43:32 AM by lucky phil »
Offline Dick
« Reply #277 on: December 01, 2014, 08:46:27 AM »
Ciao
Your right about the rocker ratio, but I believe it will only have an impact on the lift, no impact on duration. Where you can run into trouble is if your going by a manual that is giving you numbers to use measured at a specific point,(e.g.) valve tip, and you decide to measure at pushrod instead. If you measure the duration of cam off a pushrod or lifter as Chuck has, you can time the cam around the lobe center the cam manufacturer has chosen(which is in the numbers you've been given from cam manufacturer). If you don't have the cam specs.,you can still time the cam using lobe center method as Chuck has. JMO.
« Last Edit: December 01, 2014, 09:09:30 AM by Dick »
Offline Dick
« Reply #278 on: December 01, 2014, 08:49:48 AM »
Ciao
I don't think it would make any difference as valve timing goes. Maybe on rocker post height it would? JMO
Offline kevdog3019
« Reply #279 on: December 01, 2014, 09:11:08 AM »
Ciao
As long as Chuck uses the same measure between any two engines, he can compare apples to apples. There's usually a "best" way in any measurement, but even then they must be done the comparably. I don't trust tape measures for true measurement in my shop, but I would trust comparable measurements using the same tape measure. I don't think Chuck did this to show the world how it's done btw.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline lucky phil
« Reply #280 on: December 01, 2014, 09:14:12 AM »
Whenever you convert the cam information from a linier to a rotary motion you will get a variation it may be small but it will be there. same as the cam timing will be slightly different at the valve if you convert a hard foot tipped rocker to a roller tipped rocker with no other changes.
Ciao
Offline Dick
« Reply #281 on: December 01, 2014, 09:21:52 AM »
Ciao
That is exactly why you should time off a lifter using the chosen lobe center. More accurate, IMO.
father guzzi obrian
« Reply #282 on: December 01, 2014, 09:56:19 AM »
Ok, white Veglia tach and glitter on the gaiters, that about wraps it up, lets roll.... ~;
« Reply #283 on: December 01, 2014, 10:05:05 AM »
To the best of my knowledge (admittedly almost nonexistent)  ;D the numbers on a cam card from the manufacturer are done this way. <shrug>
« Reply #284 on: December 01, 2014, 10:09:09 AM »
;D
Moto
« Reply #285 on: December 01, 2014, 12:42:47 PM »
Central Indiana looks more temperate than I remember! Dang Global Warming.
« Reply #286 on: December 01, 2014, 06:28:24 PM »
Grinder I use gives lobe centres to time it, obviously he knows the duration, he ground it, his lobe centres recommendation always my starting point.
I do this at pushrod, is exactly same crank angle as at valve.
Light springs for checking valve clearances, I don't like leaning on heavy springs, risk of valve damage (yes, I've done that, once)
Plasticence on piston is fine for valve to piston IF you know there is some.
Valve to valve is hard on pushrod engine by definition, using numbers from grinder (ie lift at max overlap) always first step, me, I measure 3 times, cut once
Light springs with dial gauge works for me, after looksee , no springs, just holding valves in head
Solder for squish
Chuck
re orig cam in Lario, measure all 4 lobes peak lift, if one you measured was worn .021" very unlikely all 4 are equally worn
But I'm sure lift on that cam is known by someone on here, especially if as claimed before it is std V65
« Reply #287 on: December 01, 2014, 06:35:36 PM »
For valve to valve I just use a pair of wooden blocks to support the head. Use carb springs to hold the valves. Assemble the rocker gear etc and then turn the cam. Peer up into combustion chamber and see/measure V-T-V.
« Reply #288 on: December 01, 2014, 06:52:10 PM »
I use carb springs too
Wooden blocks in lieu of barrels ?
I get that but dial gauge on valve still needed to measure clearance as far as I can see, very hard to measure v-v with anything else.
Seeing a mile obviously good enough, seeing .030, .040 or .050, beyond these old eyes,
OHC engines totally different just hold head upside down with cam installed
« Reply #289 on: December 01, 2014, 06:53:45 PM »
Chuck
Strangely, enough.. Ed Milich says:
stock v65 cam is .225" cam lift, .285" valve lift. 1.27 rocker ratio
So now we have V65.. Lario.. and Aero, each with different lift. <scratching head>
« Reply #290 on: December 01, 2014, 08:09:04 PM »
I just use feelers between 'em if I'm unsure.
Offline lucky phil
« Reply #291 on: December 01, 2014, 10:08:59 PM »
As I said Chuck, if you measure at the valve you can't go wrong. Rocker ratio is part of the equation as are the other variables.
Ciao
« Reply #292 on: December 02, 2014, 07:04:40 AM »
Ciao
You're preaching to the choir here.  ;D I'll have the head off and have a look no matter what. No need to take a chance on wrecking some unobtainium stuff.. and.. we need  :PICS!:
Offline Unkept
« Reply #293 on: December 02, 2014, 07:47:57 AM »
 :+1
It's all enthralling... Let me know when you plan on starting it up, and I'll try to come down for a first start video.
It's bound to be Guzzi YouTube gold.  ;D
-Joe
« Reply #294 on: December 02, 2014, 08:24:46 AM »
:+1
-Joe
 ;D Riiiiight..
Other stuff going on right now. I'll only get an hour here and there for a while, most likely.
« Reply #295 on: December 04, 2014, 11:10:59 AM »
Well, I have some free time this morning, so time for some more small block porn. Pull the rockers..
Nice casting.
Note to self.. order o rings.
“That gotta Hemi innit?”
Carb springs, huh. Got some. Off to the Ancient Airlines High Tech Head Assembly Bench (tm).. <sweating bullets> Do not damage Mr Unobtainium head..
Torque her down, and have a look at TDC. .160” on the intake, .206 on the exhaust. I’m not sure what that tells us, but thought I oughta do it..  ;D
Now, for the acid test. Since these valves point at each other, they’re bound to hit sooner or later. We need to find where they are both open the farthest during the cycle. Reassembled the valve train. Pulled the intake casting off so I could see a little better. Nice. Don’t know if the later big blocks did away with the gasket or not..
This looks like the spot. 5 degrees after TDC with both valves open. Set the indicator on zero and push the valve open until it hits. Shirley  ;) thery'll be plenty of clearance. Doink doink.. Hmmmm.. can that be right?
Let’s move the setup a little and make absolutely certain that  was correct.
Yep. .065”  :o Probably a good thing I just didn’t drop that cam with 2mm more lift in it.
  Looks like a V65 cam is in our future.
Offline kckershovel
« Reply #296 on: December 04, 2014, 11:25:50 AM »
I am excited about this project.
Offline normzone
« Reply #297 on: December 04, 2014, 11:53:16 AM »
I am also. I have a dumb question...
I think I noted about six or eight pages ago that this device has some provenance with the folks at Sierra Nevada Corporation.
I know they have A LOT of different divisions, and being governmentally inclined they tend to be close mouthed.
And I know that  having empirical data provided to you would take at least half the fun out of this project.
But those folks are one of my customers, and I can't help but wonder - have you considered seeing if you can find a friendly soul somewhere inside the project to share whatever documentation they could legally share with you regarding this engine?
(prepares for NSA to visit me and ask me about my loyalty to the state)   ;)
« Reply #298 on: December 04, 2014, 12:11:20 PM »
Actually, I have a close relationship with Sierra Nevada, and I'm sworn to secrecy, other than they give me empty pushrod boxes.. ;D
Offline kevdog3019
« Reply #299 on: December 04, 2014, 01:41:45 PM »
Those are beautiful heads, pieces and domed pistons. Looks like you found the data you need to move forward. Interesting to say the least. Reminds me of my project last year; the unknown.   :bike
Kevin
'86 V65 Lario
