Author Topic: Aero engine rescue  (Read 909108 times)
Re: Aero engine rescue
« Reply #810 on: March 03, 2015, 07:32:48 PM »
« Last Edit: March 03, 2015, 07:55:59 PM by Triple Jim »
Offline johnr
« Reply #811 on: March 03, 2015, 09:13:22 PM »
Couldn't see much in the way of brakes on that second clip. Scary!
New Zealand
« Reply #812 on: March 03, 2015, 09:16:05 PM »
Yes, I noticed that too!  I didn't see any rear wheel brakes, so it was just a front brake?  There had to be something like a disk on the right side of the front wheel.
Online John A
« Reply #813 on: March 03, 2015, 09:21:08 PM »
The prop is on that thing to pull it in reverse.  That should be fun at high speed.
The big Polish radials on AN2 biplanes rotated opposite western engines so maybe that does also.
« Reply #814 on: March 03, 2015, 10:29:26 PM »
Good information, John.  I was looking at the prop pitch and its foil shape when I said that, but after your post I checked the video:  https://www.youtube.com/watch?v=yGeSIM_8BHY
At the end when the engine stops, it looks pretty clear that it rotates counterclockwise when viewed from the rear, which means the prop is pushing the car forward, but is rotating the opposite direction from what it was designed for!
« Last Edit: March 03, 2015, 10:30:15 PM by Triple Jim »
kirby1923
« Reply #815 on: March 04, 2015, 03:24:23 PM »
The pusher prop on that bug when turning creates a large low pressure area just in front of the engine,(behind the prop) which will draw air. thru cylinders.
Those engines were designed to cool low speed aircraft at 60% power or more. Probably no cooling problems with that installation.
« Last Edit: March 04, 2015, 03:26:09 PM by kirby1923 »
« Reply #816 on: March 11, 2015, 04:24:36 PM »
Sunny and 51 today.  ;-T Took it for a putt, now that the glow has had a little time to marinate.
It's freakin awesome.. ;D What a sweet runner. What was Guzzi thinking, not putting this sucker in the small block line???
Offline Mark West
« Reply #817 on: March 11, 2015, 05:32:32 PM »
I thought this bike was totally cool. Why didn't they make this? Was that when they were going broke or something?
Mark West
Hollister, CA
MGNOC L-752
« Reply #818 on: March 11, 2015, 05:58:37 PM »
The admin boys must have had something bigger in mind.
 ;D
She had told them size matters.
« Last Edit: March 11, 2015, 06:10:54 PM by Penderic »
Offline zedXmick
« Reply #819 on: March 11, 2015, 08:41:59 PM »
+ a zillion   ;D
2010 VFR1200F  DCT
Offline tiger_one
  • Learning about Guzzi
  • Push Mountain
    • justjean
« Reply #820 on: March 12, 2015, 08:08:37 AM »
That is beyond me, like a huge step backward to not hit the ground running with those heads on the V7s.  Had to be a bean counter decision back in the day.
14 KTM 1190 Adv
« Reply #821 on: March 12, 2015, 10:10:35 AM »
Moto Guzzi S.p.A. under Trident Rowan Group probably didn't want to spend money a small block variant, what with lots of money being spent on the Califorina EV makeover of the Tonti California line and the upcoming V11 Sport makeover of the spine frame line.
Probably just not enough money to go around.  It does make one wonder why so much money and resources were spent developing the prototype, though.
The bike was in the 1997 product brochure as "coming soon", Aprilia took the reins in April 2000 and probably permanently shelved the idea.
« Last Edit: March 12, 2015, 10:18:11 AM by rocker59 »
« Reply #822 on: March 19, 2015, 03:11:40 PM »
Well, this was a good news and bad news day. A couple of days ago I took the Lario for it's first "long"  ;D ride. Filled up with gas, and came back to the same station after 114.3 miles, and put in 2.3 gallons. That makes me think the needle jet and needle are about right. Did a WFO plug chop when I came home..that was interesting on our chip and seal road..had a hard time keeping it going straight, and by the time I got it under control I saw the tach needle going past the red line.  :o Gotta get a rev limiter. Shut it down and coasted to the Guzzi Garage. Today, I had a look at the plugs to see if the main jet is too lean. *I don't know anything about performance tuning* but they look ok to me..
That's the good news.
Decided since that was the 6th heat cycle, I'd torque the heads and adjust the valves. Did the left cylinder, and when I went to the right, the M8 stud seemed too loose. Started to bring it up, and at 20 ft lbs, it just kept turning.  ::) That's just freakin great.. >:( Now, is it the stud or is it the nut?
 I don't have a good feeling about it just being the nut, but dunno. It looks like my options are either cutting off the nut some way, or welding the nut to the (no doubt unobtainium) stud and see if it will torque down.  ::) I've heard of nut splitters, is this a viable way to do it? I'd hate to get a grinding wheel in there and go at it, but I suppose I could if need be.
Offline tiger_one
  • Push Mountain
    • justjean
« Reply #823 on: March 19, 2015, 03:27:28 PM »
Couple of hot tacks from a mig would do it.  Plenty of bolt to weld to.
Or you could start another nut, and weld up the middle to the bolt.
14 KTM 1190 Adv
Offline Xlratr
« Reply #824 on: March 19, 2015, 03:51:10 PM »
Just checking if I understood that right. The stud kept turning?? :-o
Offline kevdog3019
« Reply #825 on: March 19, 2015, 03:53:11 PM »
So you're saying you can't back the nut out?  Is the stud turning when you are backing it out?  ???
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
« Reply #826 on: March 19, 2015, 04:04:46 PM »
Turn the nut with a wrench, watch to see if the stud turns. <shrug>  ;)
« Reply #827 on: March 19, 2015, 04:45:29 PM »
No, the stud isn't turning.. yet.
Offline Xlratr
« Reply #828 on: March 19, 2015, 05:23:30 PM »
That sounds good.
Far be it for me to give you advice on any engine build matters, but if I couldn't unscrew the nut, I'd probably want to weld another on the top bit of the stud and remove the whole thing.
Offline kevdog3019
« Reply #829 on: March 19, 2015, 05:30:42 PM »
If the nut won't back out why do anything to keep it on?  Did you torque it down the first time?  Leave it be and ride the thing gets my vote.  Look for weeps along the head gasket along the way.  What's the worst that can happen?
'86 V65 Lario
« Reply #830 on: March 19, 2015, 06:31:41 PM »
[/b]
Yeah, but it started feeling a little weird at around 25, and I quit. <hanging head in shame>
I'd say the head could warp. I'm dealing with unobtainium stuff here.. that's the *last* thing I'd want to happen. I'd weld the nut to the stud first and see if I could torque it down.
So. Cut the nut off? Weld it on and see if the stud is stripped, too?
I'm not doing anything without sleeping on it (I do my best work in bed)  :o and listening to advise from this list.
« Reply #831 on: March 19, 2015, 06:44:48 PM »
Since the stud isn't turning, this gets my vote.
« Reply #832 on: March 19, 2015, 06:51:18 PM »
What with? Do I have to get a little grinding wheel in there?  :o
Offline Xlratr
« Reply #833 on: March 19, 2015, 06:53:18 PM »
And if it's the threads on the stud that are stripping? Cutting off the nut might damage something and you still end up with a stud that needs removing. As it is, there's a lot of stud poking out above the nut to weld something to and then just turn the whole thing out.
« Reply #834 on: March 19, 2015, 07:05:57 PM »
My limited experience with a nut splitter says that's a decent option.  The nut should split before you contact the stud threads with the splitter chisel.
biking sailor
« Reply #835 on: March 19, 2015, 07:08:05 PM »
Sleeping on it is never a bad idea.   ;)
Since the nut is turning on the stud, we can assume both the nut and stud threads are damaged.  Welding the nut on might allow you to get the proper torque on the stud, then remove the stud and replace it later at your convenience.
Whatever you decide, just make sure it is repaired properly at some point.
Good luck, and I've enjoyed following build thread and am pulling for ya!   ;-T
Online John A
« Reply #836 on: March 19, 2015, 07:23:58 PM »
Decent quality nut splitters work well. I'd look for a Snap on or OTC. The Chinese ones may or may not work once.
Offline SED
« Reply #837 on: March 19, 2015, 09:26:36 PM »
What makes you think it is not the stud pulling out of the block?
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Offline mwrenn
« Reply #838 on: March 20, 2015, 12:36:18 AM »
I'm surprised that is an M8 stud.  Figured it would be a 10 MM.  I have some spare 4130 chromemoly cold rolled m8 and m10 studs, in various lengths.  Might just have what you need.  Let me know if you need one.
Offline tiger_one
  • Push Mountain
    • justjean
« Reply #839 on: March 20, 2015, 06:08:01 AM »
I have some high strength bolts/studs from a ducati in various lengths, but think they are M10.
14 KTM 1190 Adv
