Author Topic: Tonti Tool Tray Rubber Strap Attachment?  (Read 3829 times)
Offline Dimples
« on: February 08, 2014, 03:58:56 PM »
How is this strap supposed to hold the tool tray within the Tonti frame? I assumed that the larger end (left) hooks to the front edge of the tray and the shorter end (right) connects to the wire bracket attached to the rear fender bolts. But that doesn't work very well. It slips off the front edge of the tray. Do I have it wrong? Can someone post a photo?
Thanks!
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'04 V11 Le Mans Nero Corsa
'77 850 T3
Re: Tonti Tool Tray Rubber Strap Attachment?
« Reply #1 on: February 08, 2014, 04:28:25 PM »
If I remember , big IF--     The left side of that strap gets slipped through the gas tank strap. That may not be right either cause I also remember one going to the batt tray in front of the rubber mat. That may be how I fixed the garbage that they designed, it rattles no matter what.
Offline jazzamoto
« Reply #2 on: February 08, 2014, 04:31:38 PM »
Dimples,
Yep, I'll send you a couple of pics to your AOL address since I don't have time to study up on posting pics here.
Richmond, CA
'78 Le Mans I
2021 Honda NC 750x DCT
"JAZZAMOTO  predicted it!"
« Reply #3 on: February 08, 2014, 04:31:45 PM »
That's 1/2 of the battery holder downer. the tool tray is held by gravity
 only.
Offline Dimples
« Reply #4 on: February 08, 2014, 04:54:04 PM »
Mystery solved!
John sent these photos to me showing the battery strap passes through the tray strap metal end.
'96 Sport 1100
'71 Ambassador
'81 V50 Monza
'83 850 Le Mans III
'85 Le Mans 1000
'77 850 T3
« Reply #5 on: February 08, 2014, 07:29:33 PM »
Well, IB never had that on either LeMans?? Learn something everyday here!
Rob Morton
« Reply #6 on: February 09, 2014, 01:01:36 AM »
You're not the only one John.
Don't even use a battery strap, not sure it would fit my little Red Top anyway.
Just use polystyrene wedges to hold against side boxes, soft insulation.
Rob
Offline Bobbilljim
  • Eternal Student
« Reply #7 on: December 09, 2015, 04:33:31 PM »
Can you email these pics? i cannot see them. I sure would appreciate it.
Mystery solved!
Rob
"There's Guzzi Cheap, then there's Stupid cheap" - Fotoguzzi
1984 California II
