Author Topic: V7C rear cush rubbers  (Read 11619 times)
Offline Cal3Me
« on: February 08, 2014, 06:22:22 PM »
Since the snow is falling time to do some project's. The V7C is getting new black mags and black V7 Special side panels and those fancy fork adjusters. But I ran into a snag with the rear wheel exchange.
Question,,,,,has anyone done this swap yet? I find that the spoke wheel has a set of cush rubbers behind the brake mounting plate. Do I need those rubbers with the mag wheel ? I ask because they are too big for the slots on the mag wheel. Mag wheel owners please check for me and see if you have them on your bike. Or if someone has a parts manual can you see if they are listed for the mag wheel and if there is different part numbers.
Tim
TMS
Online Aldo
Re: V7C rear cush rubbers
« Reply #1 on: February 09, 2014, 03:15:49 AM »
I have the cush drive rubbers on my V7 Stone. You can see them on this diagram...number 9...harper's has them listed as part# 32632510.
http://www.harpermoto.com/parts-by-motorcycle/2010-2020-moto-guzzis/v7-special-stone-750-2012-2013/rear-wheel-ii-en-v7-special-stone-750-2012-2013.html
Seems to be the same part number as models with spoked rims, number 17 below...harper's also has it listed as part# 32632510
http://www.harpermoto.com/parts-by-motorcycle/2010-2020-moto-guzzis/v7-special-stone-750-2012-2013/rear-wheel-i-en-v7-special-stone-750-2012-2013.html
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Offline malik
« Reply #2 on: February 09, 2014, 06:13:16 PM »
Each rubber is split, with a smaller & larger section. Only fit in one way - the smaller section facing the direction of spin. (And fall out all too easily). Try with the wheel off the bike and laid flat first. That should help you get it right.
Next time I have the wheel off, I'll take a photo for the archive. Shouldn't be too long now - have 11,000k on the current rear tyre.
Mal
Offline Cal3Me
Re: V7C rear cush rubbers.....not
« Reply #3 on: February 10, 2014, 12:30:12 PM »
You guys have missed my point....It's not the cush drive rubbers. I found out from my dealer that the early spoke wheel bikes had a bad brake squeal so the factory included these rubber blocks behind the brake disc carrier to deaden the harmonic vibration causing the squeal. Not needed on the mag wheels.
Tim
TMS
Offline mgfan
  • Escaping the "home"
« Reply #4 on: February 10, 2014, 12:51:23 PM »
Or perhaps, I didn't make myself clear.   :BEER:
Offline Cal3Me
« Reply #5 on: February 12, 2014, 12:54:48 AM »
no problemo .....after looking at the parts diagram number #21 is the "support rubber" in question. Now we both know ;D  ;-T
,,,,Tim
TMS
Offline sib
« Reply #6 on: February 21, 2015, 05:20:36 PM »
Tim
But the mag wheels also have a "rubber support part", part #7 in the mag wheel diagram, part #21 in the spoke wheel diagram, but it's the same Guzzi part number, GU32636160, so apparently these wheels also need the squeal damper, if that's really what it's for.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Moto Fugazzi
    • Griso
« Reply #7 on: February 21, 2015, 05:38:11 PM »
Tim,
While I do enjoy a good support rubber, my 2009 V7C never had that rubber, nor did I add it to the Breva wheels I put on last year. Are you putting on the Stone mag wheels?
Which V7 Special side panels are you putting on?
Ken
« Last Edit: February 21, 2015, 05:40:33 PM by Moto Fugazzi »
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
