Whats the old Quota V2.28 XDF entail?
I am currently trying to modify my engine Temp Trim but it will not let me save the values I entered. Does this have something to do with them being a Linked Scale?
And why does it say "nicht korreckt" on my Scale Engine Temp (8bit) table?
... I started wondering why a 230kg, 80PS, 1liter V11-engine consumes more fuel than a 1400kg, 80PS, 1liter car during a comparable driving situation. The bike having the advantage of better aerodynamics also.
Hi,as to the first question, not really. I am measuring injection signal duration with a scope at whatever settings the MAP and sensors have, but have found discrepancies between the times shown by GuzziDiag and the measured ones. I need to validate this on the motorcycle itself. The actual injectors may well have different times than the load resistors I am using on the testbed.And yes, the idea is to use the testbed to fill in the blank areas in the understanding of how everything interacts. And be sure of one thing, everything is interacting :-)CheersMeinolf
I expect if you still have the test bed, you will see the duration change with supply voltage.Did you ever discover how the acceleration enrichment map worked? I know it is a map of TP vs RPM, but there must be something that looks at the rate of change of RPM over time and/or rate of change of TP and RPM over time.
