Author Topic: Whirlpool front-loader  (Read 27355 times)
Offline Testarossa
    • Skiing History
« on: February 14, 2014, 10:24:51 AM »
I've always just bought used washing machines off Craigslist -- $25 and it slides into the back of the Subaru. They last two to five years and repeat. This time I wanted to build a workbench over the washer-dryer pair, so I went to an "Appliance Factory" outlet and spent $250 on a front-loader.  Too heavy to load and unload myself so I paid $90 for delivery.
The washer wouldn't start -- showed a fault code instead. 30 day warranty, so they brought out another one. Bearings shot -- the tumbler sefl-destructed after two loads. They brought out a third machine. This one ran well, twice, then showed an F22 fault code, which means a bad door latch switch. So I bought a door latch switch and installed it. The machine started, began filling with water -- then stopped and showed code F29 -- which is also the door latch switch. Before I start replacing one component after another, anyone on this board have experience with the electrics in these things? All the connections, components and wiring look clean, tight and undamaged.
Offline skromfols
Re: Whirlpool front-loader
« Reply #1 on: February 14, 2014, 10:42:39 AM »
This is probably not the best forum for asking washing machine questions.  I've found that most appliances have forums where you can find answers to questions like this.
 http://forum.appliancepartspros.com/washer-repair/520963-whirlpool-washing-machine.html,
 http://www.diyforums.net/my-whirlpool-top-loader-washing-machine-sometimes-does-spin....-7898720.html
I've found that going to equipment specific chat forums can be very helpful in troubleshooting.
Stan
98 Valkyrie
08 Triumph America
05 Moto Guzzi Nevada
« Reply #2 on: February 14, 2014, 10:49:50 AM »
Umm, disagree, this is the best place to go with any question... your answer will be along shortly..
is the 30 day coverage run out? maybe you should just get money back and go to CL?
« Reply #3 on: February 14, 2014, 11:07:27 AM »
There are many things that can cause fault codes on these darn things and they are different depending on where in the cycle it is when if fails.
First thing I do with a fault is clean out the filter.  It collects stuff and when it clogs generates a fault code.
Then there is the little plastic doohickey on the soap dispenser.  It is fragile and if it breaks or slips it screws up the whole sequence.
Other than that we call a technician.  He knows what the problem is based on model and code due to his experience in working on these things, not what's in the book.
Offline Mike Tashjian
« Reply #4 on: February 14, 2014, 11:40:43 AM »
Front loaders have a big problem with stuff growing in around the drum.  We have to use special low suds soap(HE) labeled and then have to keep the door propped open to help slow the growth in there.  Once a month or so we have to run a empty load with a special(two dollars a pop) cleaner.  Then there is the problem most have with the spider on the back of the drum that corrodes and breaks just after the warranty is up.  When it goes it can take out other parts which will render the whole unit scrap.  We have a Bosch unit which on the plus side is very good about water conservation and uses very little soap.  Not cheap though and with water prices in Upstate NY ridiculously cheap, I just threw that in for other places in the country.  It seems the trend will be back to top loaders. They don't tend to be afflicted with the drum spider issue and the odor issue that the front loaders have.   And the new ones seem to have solved some of the water efficiency issues too.  Mike
Gary
« Reply #5 on: February 14, 2014, 11:43:53 AM »
"Appliance Factory Outlets" generally have either items that have been returned for reason, sat for months on a showroom floor or were poor sellers, again for reason. Can't fault the price though. You may have to go through a few to find a good one though. Even if they were just sitting on the showroom floor it is amazing how much damage lookers and their kids can do. Doors are slammed. Kids swing on them. The soap dispenser is taken out put back in wrong and slammed shut. It gets worse wear than if a family used it for a year. Whirlpool is generally a quality laundry product and depending upon the date of manufacture, probably made in the US. Whirlpool is the largest manufacturer of appliances in the world and owns Kitchenaid, Maytag, Jennair, Admiral, (and maybe others). Their major appliances as well as those by GE are now being made in US factories.
If is was sold as a new appliance, you should have a 1 year manufacturers warranty. This may be helpful in getting it right.
Generally front loaders are superior to top loaders in all respects. They use less water, clean better and are gentler on clothes. They require a bit of preventive maintenance however. Most have a drain and filter at the front bottom. Follow mfg recommendations closely. Detergent door and washer door should remain open when not in use. If moisture is not allowed dissipate, mildew may form on the outer drum or the door gasket. Same with a top loader, but most people leave them open when not in use and they do have vents in the door anyway.
It is important to use the right detergent, labeled HE (high efficiency) and use as little as possible. Never use more than 2 tablespoons, less if possible and if the load is small. Could use packets instead.
Offline Testarossa
    • Skiing History
« Reply #6 on: February 14, 2014, 12:11:31 PM »
Thanks, guys. I did clean out the filter and fixed the busted lever arm on top of the soap dispenser. Everything else looks kosher so I may just ask them to apply the price toward a new one. I have enough on my hands with the T and Triumph rebuild, the flood damage, the trial and, oh yeah, the job.
Online PeteS
« Reply #7 on: February 14, 2014, 12:43:12 PM »
Old Maytags are like Guzzis. Last nearly forever and you can still get parts for them. We bought our washer and dryer in 1972 and they get used a couple of times a week. My folks had a similar vintage set that ran three years go when we sold their house.
Wouldn't buy a new Maytag though.
LaMojo
« Reply #8 on: February 14, 2014, 12:56:26 PM »
The belt less Whirlpool top loading washer is about as simple and trouble free washer you can buy.  The front loaders have a history of tub bearing assemblies having to be replaced early in their design life. Very expensive!
Andrew Thomas Evans
« Reply #9 on: February 14, 2014, 01:42:13 PM »
+1
I'll ask some people I know who sell appliances, but I haven't heard any horror stories like the OP's in a while, but then again I thought front loads would be a bit more expensive than they paid...
fwiw, you don't want to know what goes on in appliance warehouses.
Offline twhitaker
« Reply #10 on: February 14, 2014, 01:45:49 PM »
That's just great. I didn't but now I do. ???
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Andrew Thomas Evans
« Reply #11 on: February 14, 2014, 01:52:39 PM »
So appliance boxes have a lip on them that let's a special forklift move them around and place them on top of one another. As far as I know there really isn't any racking or pallets, they are just stacked - or maybe some auto racks with rollers, but I still bet a lot of them are stacked on top of each other 2-3-4-5 high. So if one makes it to a scratch and dent or discount place with damange, you really don't know if it was due to a minor fall, or something 10+ feet up.
As another example, at the window warehouse I worked at 10 years ago we stacked some normal sized windows flat one on top of another in groups of 8 or 10, then added some boards, and would stack 4 or 5 groups together and they went up 20 feet or so. It wasn't all that much fun to stack them high, we had some piles that leaned a little, and sometimes one would fall.
Offline eldoroddo
« Reply #12 on: February 14, 2014, 02:03:02 PM »
Another front loader horror story.
You can't beat an older model top loader with a normal agitator (on the non water saving type of machine) and old school timer, if you can find one.
Something in Avocado Green or Harvest Gold would be groovy.
Offline Pfaff!
  • "Lasciate ogni speranza voi ch'entrate"
« Reply #13 on: February 14, 2014, 02:08:00 PM »
Go for a Miehle.
Bulletproof German panzer.
Anders Holt
Breva V 750 ie "Rossinante" '03. Running fine ever since. Sold.
Pushing bikes these days.
"El camino amigo, el camino y nada mas"
Offline roofus
« Reply #14 on: February 14, 2014, 04:00:36 PM »
Go for a Miehle.
Miele!!!! no "H"
http://www.miele.com/international/enint/home.htm
I have A Miele vacuum, dishwasher, laundry washer, clothes dryer and espresso machine. They are the best appliances out there!
« Reply #15 on: February 14, 2014, 05:54:59 PM »
Go for a Miehle.
We have a Miele washer and dryer. The washing machine water pump went bad after eight years if ownership(now in the 12th) and I blame it on screws,pennies etc. left in my pockets ending up in pump screw but that is speculation. Easy to replace pump but it wasn't cheap. Dryer is ventless which is nice.
Offline RayB
« Reply #16 on: February 14, 2014, 06:28:16 PM »
We had a Maytag toploader that was around 10 years old and came withthe house when we bought it. It lasted another 20 years and my wife used it everyday. Maytag had a good reputation for reliability so we replaced it with a new one. Piece of crap. It shredded our clothes on a regular basis, I did all kinds of repairs and gave up on it after the last gearbox fix.
Apparently Maytag tried to emulate Harley-Davidson after the AMF boondoggle
Replaced that Maytag POS with a Fischer-Paykill toploader....that was 5 years ago. Had zero problems with it and is used everyday.
Wife loves that machine.
01 EV
82 BMW R100
« Reply #17 on: February 14, 2014, 07:11:42 PM »
Good Kiwi product, 1 moving part ;-T
« Reply #18 on: February 14, 2014, 07:22:17 PM »
we have a Kenmore 12 years old..
we also have Service plus contract thru local Nat. gas utility that covers furnace and our choice of about 5 other appliances, what a life saver that contract is...
Last month we had them over to fix the washer that was making a knocking and dimming the lights in the spin cycle.. first guy put in a new agitator and called it fixed, NOT.. asked for a different guy who came and replaced the motor.. still not fixed and it shorted something out.. so he orders a new capacitor and when it comes by fedex he's back to fix it with a second tech/adviser. they put it in and find the short killed the switches and timer dial so they got replaced too.. saw this box full of old parts when I got home.. told wife, Wow, you got a whole new machine under the hood, should we paint it?
I said metal flake flames but she didn't go for it..
same washing machine has been sending pocket lint and other shmutz down the drain forever and it eventually clogs the pipes, the SERVICE contract covers drain pipe to street.. So, once a year we have them ream out the drain pipes from the laundry room out to the street.. Roto Rooter would charge about 3 bills for that..
ANd we got a new igniter in the furnace this winter, free..
 I'm not one to buy extra warranty on much but this service contract really pays if you have old appliances.. when they finally die I head over to Craigs list!
Online Wayne Orwig
« Reply #19 on: February 14, 2014, 07:32:54 PM »
Kenmore top loader.
22 years old.
I replaced the lid switch a couple of years back.
Offline Pfaff!
« Reply #20 on: February 15, 2014, 04:37:08 AM »
Miele!!!! no "H"
We have a few too, but as their lives are so unspectular you never have to give them a look, just load and forget. So, forgive me the misspelling.  ;D
When I sold my parents house some 10 years ago the Miele (please note: no H!) washing machine bought in the early 60s was still there, working. Think they changed the programming-watch once.
« Last Edit: February 15, 2014, 04:39:18 AM by Pfaff! »
Anders Holt
Offline Pfaff!
« Reply #21 on: February 15, 2014, 08:11:13 AM »
WOW ! Miele (look no H) might be a brilliant machine , but you can buy a nice used MC for the same price .
Sent from a submarine in Oklahoma .
How will your old used MC do your laundry?  :BEER:
Anders Holt
Rough Edge racing
« Reply #22 on: February 15, 2014, 08:12:17 AM »
 You must see this, be sure to use the skip feature in the advertisement
        http://www.youtube.com/watch?v=dq6T5BojXc8
Offline Pfaff!
« Reply #23 on: February 15, 2014, 08:30:45 AM »
Good one . I suppose one could just ride in the rain ,
With a detergent dispenser in front of you ???
Anders Holt
Offline Pfaff!
« Reply #24 on: February 15, 2014, 09:30:13 AM »
You must be pickier than me . Ha!
Nooo, I'm the kindest ever found. 8)
Anders Holt
Orange Guzzi
« Reply #25 on: February 15, 2014, 09:59:08 AM »
I own a coin laundry and do all my own tricks ( repairs ).  Washers and dyers do not last forever, just ask my customers.  I have many that come to my store because theirs is broke.  The equipment used in a coin laundry is no different than what is used in a home with the exception of the coin box or card reader.
Top load washers of the old style are being forced out of the market by our wonderful government.  They use to much water.  A top loader can use 55 gallons, a front loader 12.5 gallons.
Front loaders can get mold in them.  Leave the door open between uses to air out.  Front loader will not spin out because the drum shocks blow there seals.  This causes excessive shaking and the out of balance switches shut the unit down.  Replace the shock.  The door lock switch fails because the rubber gasket leaks and moisture gets in the switch.  Replace the switch and the seal.  Fill valves get a speck of dirt in them.  Pumps get something in them and stop spinning.  Remove the bottom of the washer and clean out the pump, easy to do.  Belts seldom brake, but do.  Motor seldom fail. Control boards seldom fail.
There is a reason the used washer was for sale, most likely the previous owner go rid of it because it was broke and tired of messing with it.
You can't put 20 pound of dirt in a 10 pound machine and expect it to last forever.  Hot water is useless in a washer.  Within 2 minutes of filling it is cold.
Part prices are all over the board.  I do not buy all my parts from one supplier.
As far as quality, I have got the longest life out of the Matag units.  Also the actual manufacturer may be different than what is on the label.
« Reply #26 on: February 15, 2014, 10:30:36 AM »
1. buy an old Harley dresser, before they rubber mounted engines
2. fill saddlebags and trunk with water and detergent, add clothes
3. ride around to wash the clothes
 ;D ;D
Offline Dilliw
« Reply #27 on: February 15, 2014, 10:37:07 AM »
When we bought the house last year we needed a new washer and dryer.  Kim wanted an "old school" agitator but they are almost extinct now unless you buy new.  We ended up with the Kenmore Elite (LG) top loader/electric dryer and I must say they do the intended jobs (cleaning and drying clothes) better than the old style models they replaced.  Time will tell if they last as long though.
George Westbury
Austin, TX
« Reply #28 on: February 15, 2014, 10:37:32 AM »
Fay has a Miele vacuum cleaner that's a good one.
And warning to you folks getting ready to buy a dishwasher - I wouldn't buy another KitchenAid!    Ours is 3 years old and I've already spent $100 in parts fixing things.   The appliance SEEMS well made and is expensive, but the plastic bits on the inside that hold the racks in place are just junky little bits not suited for their job that actually wear out in addition to cracking and breaking.   When I started searching for advice and parts, I found I wasn't the ONLY one having the problems!
Should have gotten the Bosch!
Offline bobdar
« Reply #29 on: February 15, 2014, 10:54:36 AM »
My ex wanted a Maytag Neptune front loader about 15 or 20 years ago--she's gone but the washer is still here.  Have replaced the wax motor (not really a motor but something that latches the door), a resister and a diode in the circuit board and the two bearings that support the drum.  The same ethic that keeps me fixing old motorcycles and race cars seems to extend to appliances as well.  Some call me "stingy" but I prefeer "frugal".  I hate disposable stuff.
bob darcey
lakewood, colorado
'75 850T
'56 Matchless G80
