So far Mark hasn't had a Norge to log develop a map for. That means that what you are riding on is based on comparative speculation and feedback. As soon as I can convince someone local to allow me to keep a Norge 8V for a couple of weeks that are convenient for Mark, (Remember, he has a real job too!) I can set up the tune, take it to Wagga and he can really crunch the numbers.I'm hoping soon to be au-fait with the logging process myself and have the tooling. Once I'm up to speed it will make it a lot easier as I'll be able to do a lot of the 'Donkey Work'. Once again though I also have a job, (Two if you consider the Midget Porn Empire a job?) so this stuff all has to 'Fit in' as it were. My guess is that this midrange 'roughness' will be addressable but it needs concrete data and first hand examination to get things spot on. There are no 'Magic Wands' here. It's all done the hard way without fairy dust or magic boxes.Pete
Not to log build a map. There are certain things we have learnt and *Know* about the 8V engine that mean Mark can take a pretty good stab at a map. We have had test bikes but not so far one Mark can log build a map on.Pete
Hi ... now been over a month with new map ... now that I am 'used to' the new operation of the bike my thoughts are:Great enjoyment in engine below 4000 rpmNot quite as smooth from 3000 to 5000 rpm as original (TBS set at 4000 with Morgan Carbtune)Much improved fuel consumption.Between 3000 and 4500 rpm:The original map gave the engine an 'elastic' feel that was very relaxed.The new map gives the engine an 'urgent' feel more like a big bore non balance shaft inline 4(think Waltr said this before)the trade-off is worthwhile ... far better throttle response with new map.None of the CO2 changes made any difference to this 'feel' with new map.The TBS fine tune at 4000 has not altered this 'feel' with new map.
Just before Xmas I checked TBS again- made sure 'both' air bleeds were snug then redid TBS at 4000rpm - reset TPS (4.6 I think)After this the smoothness was little improved - throttle response 'feel' better (my imagination? -no matter, feelings of joy!)I did find the throttle cables required loosening as idle was hanging at 1800 or so - once cables were loose idle was fine.Fuel cons has gone up a little ... (guilty smile) frustrated cagers with bike in crosshairs find themselves sitting in exhaust fumes....(better for them than that ciggie maybe??)Observations:Original map 0 to 3000 rpm was a little smoother BUT had slow throttle response, less eagerness to rev than Marks map. Also engine stalled easily at idle with a little load.New map: 0 to 3000rpm - eager to rev, takes load in stride, does not stall easily at idle. Smoothness similar to original but with more 'Thump' Hah! Now THAT's why I bought a Guzzi!original map 3000 to 5000 revs engine pulled well (expect more for 1200cc by this stage) -smoothness increases with rising torque so that by 4000 there was strong pull - elastic in feel in that as revs got past 3000 so did eagerness to rev increase.New map 3000 to 5000 strong thumping pull, smoothness slowly decreased with revs so that by 4000 a 'tingle' in bars is evident along with light 'rumbling vibration' in chassis - not unpleasant at all.original map 5000 to 8000rpm - VERY smooth and quick to rev ... like power is ramping up with each 100rpmnew map 5000 to 8000rpm not quite as eager to rev as original - not quite as smooth, more rumble evident, power builds with revs but 'FEEL' is different------example: with original map you have to twist throttle (many millimeters) below 5000 to get bike really moving BUT once close to 5000 a little movement of throttle gives a lot of urge,------more throttle sensitive 5000rpm up.=====New map throttle sensitive right from idle to 4500 or so then sensitivity drops off and you have to twist throttle .. almost like its a reverse of original?MUCH PREFER NEW MAP - 90% of my riding is below 5000rpm.Norge is a beast of beauty to ride AND look at!Thanks MG -thanks forum members - my riding enjoyment is increasing with each day.Been riding near on 40 years - NOW I get the bike I always needed while I enjoyed all my past bike except for 1 - my fault for choosing someone else's restoration project. Next bike will be a MG.
GuzziPilot, you might want to make another copy of that original map and put it on something else like a CD or thumb drive in case your netbook takes a dump and you need the original.Netbooks can fail just like laptops with spinning drives. It never happens until you need it.
Most 'Surging' problems are the result of incorrect tuning. I fear that there is this belief that remapping is a panacea for all ills. Nothing could be further from the truth. If the bike isn't serviced and tuned properly with the beat developed map in the world it will still run like a hairy wombat with a burning branch up its date!
Pete, that's the kind of hints I was hoping for. I have experienced much of what you're talking about working as a service writer in a scooter shop. I have made no mods to the drive train except removing the carbon cannister to make room for a better tool kit. Aside from checking the balance and TPS, I will double-check the cap on the intake where I removed the hose from the carbon can. An air leak there might cause issues.
