Author Topic: GuzziDiag HowTo - A tutorial for beginners  (Read 887023 times)
Offline roadventure
  • There is no try; There is only do.
« Reply #1410 on: July 05, 2018, 11:07:41 AM »
*Very* nice.  ;-T Thanks for taking the time to do this..
Is this to say that Moto Guzzi motorcycles are THAT simple to troubleshoot?  Nothing more than a ".".
dave
Millville, DE
"Moto Guzzi....you're never more than 500 miles from your nearest dealer"
« Reply #1411 on: July 05, 2018, 11:09:42 AM »
I got my cables here in the States in a few days.
Offline TimmyTheHog
« Reply #1412 on: July 05, 2018, 11:19:46 AM »
I just started week 4 of my wait...
To Toe, as you are "sort of" near my location, I waited about a month before I got my. Keep your eye in the mail...should be there soon.
Currently Bikeless...*cry*
Offline malik
« Reply #1413 on: July 05, 2018, 02:25:49 PM »
So, for what it's worth, the chugging problems I was having on my Breva 750 between 3500 and 4500 RPMs disappeared when I replaced my mufflers (with used stock Franconis), the insides of which were worn out and rattling around. I had been convinced that it was a fueling issue, and thought it could be solved by tweaking maps, etc. Swapping mufflers was much easier.
Let us know if the misbehaviour turns up again, please. I have done several things to the V7C which I thought fixed it, only to have it turn up again later, sometimes much later.
Offline nyITguy
« Reply #1414 on: July 05, 2018, 02:31:08 PM »
I suppose if I wait for the replacement mufflers to wear out, it'll reappear... :grin:
Seriously, though, you can be sure this group will be the first to know if it does happen again.
« Reply #1415 on: July 05, 2018, 03:21:00 PM »
Do I need GuzziDiag to do my own service on the V7III, or is this just for those who want to play with different fueling maps?
Offline Toecutter
« Reply #1416 on: July 05, 2018, 03:25:44 PM »
I believe you need it to adjust your TPS.
Offline malik
« Reply #1417 on: July 06, 2018, 06:10:52 PM »
You don't usually NEED it to do a service. Many of us managed quite happily before it became available (blissful ignorance ?). Many owners seem to run & service quite happily without it,  or are content to use the dealers. If you are tech savvy, or wish to become so, it's a neat tool to have access to, and cheap. There are applications for it other than re-mapping, although that it is often the main excuse for initial acquisition. But it's a tool, and most of us get tools when we think they might come in handy sometime.
beetle
« Reply #1418 on: July 06, 2018, 06:44:13 PM »
As Mal says, it's not required for routine maintenance. Should you ever need to reset or check the error codes, or reset the autolearning parameters (fuel trims), relearn the throttle, or simply test or check sensors, it's an invaluable tool for the small cost of the cables, and even a donation to the developer. The map Reader & Writer are separate programs, and the usefulness of the main GuzziDiag program is not limited to "those who want to play with different fueling maps".
« Reply #1419 on: July 06, 2018, 10:47:09 PM »
Thanks.
« Reply #1420 on: July 06, 2018, 10:49:01 PM »
I have an OBD connector to my computer that I used with my triumph.  Can I buy just the cable that connects to the Bike?
beetle
« Reply #1421 on: July 06, 2018, 11:37:03 PM »
If you used TuneECU with that OBD connector, or you know it has the FTDI chip in it, you can use it.
Offline Bill Dee
  • Cautious Expert Rider
« Reply #1422 on: July 11, 2018, 01:48:53 AM »
I have NOT found an OBDII connector on my 2008 1200 Sport.  Where on the bike do I connect to use the program ?
If We Don't Have Jobs Making It ...... How Will We Have The Money To Buy It ?
beetle
« Reply #1423 on: July 11, 2018, 02:39:04 AM »
It's there. Probably tucked down beside the airbox or relays. Looks like this.
Offline Bill Dee
« Reply #1424 on: July 11, 2018, 03:00:04 AM »
OK I have seen that. Thanks.  What cable do I need to get then ? I have an OBDII to USB I use for my Triumph Rocket III with my computer and TuneECU.
beetle
« Reply #1425 on: July 11, 2018, 03:28:01 AM »
You need the Fiat 3 pin to 16 pin adapter.
« Reply #1426 on: July 11, 2018, 05:14:26 AM »
On Breva, Sport and Norge the connector sits way up the back under the seat in the little 'Tray'.
Offline swooshdave
« Reply #1427 on: July 30, 2018, 03:36:38 PM »
I'm looking for a map for my V11 Sport with Mistrals. Where is a good place to look?
2001 V11 Sport
« Reply #1428 on: July 30, 2018, 04:52:25 PM »
V11 LeMans.com
Offline swooshdave
« Reply #1429 on: July 31, 2018, 01:51:22 PM »
V11 LeMans.com
They sent me here.  :undecided:
2001 V11 Sport
Offline RinkRat II
  • Lake Powell AZ
« Reply #1430 on: July 31, 2018, 01:55:52 PM »
 Best bet is to PM Beetle.
      Paul B :boozing:
« Reply #1431 on: July 31, 2018, 03:29:31 PM »
I don't believe Mark has done much map work for the 15M/RC as used on the V11's. I might be wrong but that.'s why I suggested V11.Com as I know there are several folks who have built their own maps over there.
Offline nealwp
« Reply #1432 on: January 15, 2019, 04:25:19 AM »
I'm not able to connect Guzzidiag on my laptop. It's not finding a port. Can I use another app for diagnostics? I'm new to this. Can I use Tunerpro for this?
beetle
« Reply #1433 on: January 15, 2019, 04:28:50 AM »
No. TunerPro can't be used for diagnostic purposes.
Did you install the correct drivers? What operating system are you using?
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #1434 on: January 15, 2019, 08:18:39 AM »
And where do your cables com from?
Paul
Daytona 1225, Stelvio 1151
« Reply #1435 on: January 15, 2019, 08:52:30 AM »
Don't know what laptop you have but the very 1st time I had software (Technoresearch VDSTS) I had to go into Device Manager and find the usb port cables were plugged into.
« Reply #1436 on: January 15, 2019, 10:21:58 AM »
This guy has a Bassa, so maybe Beetle could modify the map he made for Dan in NC and his Calvin.
Offline christof
« Reply #1437 on: April 16, 2019, 05:12:59 PM »
I am trying to use GuzziDiag on a 2010 V7 classic. I have a Linux laptop and have downloaded the appropriate files, and procured the cables from lonelec. The programs all open but I am stopped by the Reader, which does not present any choices in the COM area, and returns a "file could not be opened" message when I try to save the stock map. I need ideas - please help!
beetle
« Reply #1438 on: April 16, 2019, 06:11:09 PM »
I've already responded to you in the New Improved GuzziDiag thread.
https://wildguzzi.com/forum/index.php?topic=96957.msg1589613#msg1589613
Offline jvandrade81
« Reply #1439 on: March 01, 2020, 09:20:50 AM »
Hi, i'm new here and i just installed the beetle map on my v7ii using linux.
The issue you're having is about permissions. Since linux already has it's usb and serial drivers, you don't need to install them but you need to give permissions for them to be used.
do this:
1 - plug the usb cable to the computer (have the usb cable connected to the serial diagnostic cable too)
2 - open the terminal window and check if the cable is detected by typing usb-devices this will give you the list of all your usb ports and whats connected to them
2 - list your usb tty by typing dmesg | grep tty so you know the number of the port on which you plugged in the cable
3 - add permissions for your usb port to be used as a serial port by typing sudo chown :yourusername /dev/ttyUSB0 replace the 0 for the port number you have the cable plugged in to (in my case was USB0 because i connected to what is considered to be the 1st usb port of the computer, when you have more than one of course)
4 - now if you open the guzzidiag or the reader or writer map apps you'll see your usb port listed in the COM port field.
I hope it helped!
