Author Topic: GuzziDiag HowTo - A tutorial for beginners  (Read 908949 times)
Claesson
« Reply #240 on: August 20, 2014, 08:46:51 AM »
No i cant browse the file system just see it but cant get nowhere.i have tried to open macintosh hd but nothing happens.
Claesson
« Reply #241 on: August 20, 2014, 08:54:50 AM »
Solved it had to push some more buttons aint much of a hacker. :)
Offline Stormtruck2
  • AKA Scotch and Cigars
  • Geese Fly in a Proper V
« Reply #242 on: August 20, 2014, 10:25:53 AM »
Don't feel bad.  I had several operator interface failures myself. ::) ;)  It is great software when the operator uses it properly. ;D :D
μολὼν λαβέ-molṑn labé
czakky82
« Reply #243 on: August 25, 2014, 08:04:47 PM »
Hey guys, i must've had a wee gaff on my guzzidiag and am having major cold start issues. Anyway i am wondering if anybody out there could let me peep at there somewhat stock map?...
My bike is an 02 v11 LeMans. Thanks guys.
Offline Moto Fugazzi
    • Griso
« Reply #244 on: August 25, 2014, 10:40:39 PM »
I'm also having cold start issues with my 2001 V11S (15M). I've reflashed it a few times with the stock map (and even slightly modified) with the same results. If I put in my spare ECU, it fires up within 1 second and idles perfectly.
Anybody else having issues with their 15M ECU?
Ken
p.s. I sent a BIN file to czakky82 that I pulled of off my spared stock ECU.
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #245 on: August 26, 2014, 05:16:25 PM »
SO you have two ecu with same map and they behave different? Same Co trim setting?
Paul
Daytona 1225, Stelvio 1151
    • Griso
« Reply #246 on: August 26, 2014, 06:40:17 PM »
Yes, same CO trim setting. I've tried maps from each ECU with the same results. The only difference I've noticed between the two ECU's is cold starting issue which have been going on since last year when I first used GD.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
Offline Waltr
    • Europa Macchina
« Reply #247 on: August 26, 2014, 07:15:31 PM »
   I loaded guzzdiag after I did my first throttle body balance and removed the canister at 3,500 miles.  My bike suffered with cold start issues before and after loading Guzzidiag.  At around 7,500 miles I revisited the throttle body balance and being more familiar with the carbtech balancer I really dialed it in closer.  I was surprised how much adjustment was needed to get the left cyl in line with the right.  I have no cold start problems ever since.  Even have a nice high idle until engine starts to warm up.
www.motoguzzipa.com
2012 Norge
    • Griso
« Reply #248 on: September 15, 2014, 10:13:58 AM »
Ken
After downloading the newest XDF and Tunerpro (looks like earlier versions had bugs), the latest map on my V11 works flawlessly. It's also a good idea to have a fully charged battery when uploading new maps.
Ken
2004 V11 Cafe Sport
2009 V7C White
    • Griso
« Reply #249 on: September 15, 2014, 10:22:08 AM »
Now, the issue with my 2009 V7C. As stated above, I have the newest XDF and Tunerpro, but my V7C won't start or run properly with a modified map. On my last attempt, I just changed cold start time to 2000 instead of 4000, and it wouldn't start. When I load the original map back on, it starts right up.
When I load the 15RC XDF into Tunerpro, I also get settings for my V11. I don't know why it's doing this, but that may be the issue. I deleted all of the V11 settings from the XDF, but that didn't work either.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
« Reply #250 on: September 15, 2014, 01:59:25 PM »
I can send you my modified map for my 09 V7c - the starting fuel map is slightly increased, the lamba is switched off and nothing else is changed.
My bike runs very well now even during the cold start timed period.
    • Griso
« Reply #251 on: September 15, 2014, 03:06:06 PM »
I'll install it tomorrow and report back. Thanks!
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
    • Griso
« Reply #252 on: September 16, 2014, 11:36:44 AM »
Ken
The map worked like a charm! No hesitation during cold startup at all.
Thanks again!
Ken
Now, why can't I create my own maps for this in Tunerpro? I can do it perfectly with the V11S 15M XDF and BIN map.
Ken
2004 V11 Cafe Sport
2009 V7C White
Offline Stormtruck2
« Reply #253 on: September 17, 2014, 10:50:49 PM »
The Centauro ECU has to have the EPROM changed correct?  Guzzidiag  doesn't work for the Centy correct?
beetle
« Reply #254 on: September 18, 2014, 12:35:03 AM »
Yeah. Centauro is a 16M right? Reader and Writer won't work.
Offline Bisbonian
  • Living the Dream
« Reply #255 on: September 26, 2014, 12:01:30 PM »
Is there a depository of maps around there somewhere that I'm missing?
Phil_P
« Reply #256 on: September 26, 2014, 12:07:19 PM »
Yes, although when you pull the eprom, the guzzidiag people have some software I believe that will help you tweek it if you use an eprom reader/writer to access it.
Phil
Offline pauldaytona
« Reply #257 on: September 26, 2014, 01:29:16 PM »
for tunerpro we have the xdf for 16m ready to download, you only need an eprom burner and a handful of eproms. I have the maps from the guzzi stock eproms here. But not ready to go tuned.
Paul
Offline toma nova
« Reply #258 on: September 28, 2014, 02:36:32 PM »
I continue to have problems with my MacBook.
GD v43 works fine now, but I had to download it several times - I was getting different sized downloads and ended up using the largest file.  Worked fine to reset the TPS on my 2008 12S and my 2014 Stelvio.
Now that I'm ready to take the next step of adjusting maps, lambdas, etc., I'm trying to download Reader and Writer.  Writer appears to work OK but I haven't written anything to the ECU because I can't get Reader to open.  From the GD site, I can only download V22 (not 23 as indicated) and as soon as Reader tries to open, it shuts down and won't open.  OS and Safari stay running but Reader just won't open.  I had the same issue with GD early on but kept trying more downloads until it finally worked.
I've tried to download Reader 20+ times and every instance crashes.  Anyone else having issues with OS or have any suggestions?
Thanks,
2014 Stelvio NTX
2008 1200 Sport - sold
Offline pauldaytona
« Reply #259 on: September 28, 2014, 04:39:44 PM »
For the mac, I see the download links to 0.22, I suppose that isn't updated yet. In the past people with mac having this sort of problems had a wrong program to extract the zip file I think.
difference betwen 22 and 23 is added 59m, only usefull for ducati.
Paul
    • Griso
« Reply #260 on: September 28, 2014, 05:34:50 PM »
I have mountain lion on my mac, and had to go into the security portion of it to enable downloads for untrusted sites. You should be able to go into your downloads folder and save it to your desktop. My mac screen flashes all kinds of crazy when I use guzzidiag and sometimes crashes, but I can get it to work with some patience.
Downside is that they don't have tunerpro for Mac yet. I got an old windows laptop from a buddy that I normally use.
Hope this helps.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
Offline toma nova
« Reply #261 on: September 30, 2014, 07:52:29 PM »
Tried again tonight, I see that Reader for Mac OS has been updated to V23.  It worked perfectly!  I now have the stock map saved to my MacBook.
Thanks so much Paul / Bernd, donation sent!
2014 Stelvio NTX
    • Griso
« Reply #262 on: October 10, 2014, 06:38:52 PM »
Does the CO adjustment affect the Lambda? I turned off the lambda on my V7C, and MPG dropped to low 40's (used to be around 50MPG). I reinstalled the lambda, now I'm getting pinging again under hard acceleration, and I'm wondering if increasing CO a bit will take care of that, or if it will auto correct back to what it was originally. FWIW, the CO setting is at 21 on my 2009 V7C.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
beetle
« Reply #263 on: October 10, 2014, 07:55:00 PM »
Ken, CO trim is not active when lambda is 'on'.
Did you reset the learned parameters when you flashed the non-lambda map? Or maybe pulled the main fuses? If yes, then the now that lambda is active again, the ECU will re-trim and you should get back to where you were.
    • Griso
« Reply #264 on: October 10, 2014, 09:43:09 PM »
Thanks for the info! No, I didn't reset the learned parameters then. I think I'll remove the lambda again and do that. If MPG drops, I'll probably reduce the CO and go from there.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
beetle
« Reply #265 on: October 10, 2014, 10:55:17 PM »
When you turn lambda off and reset the learned parameters, set the CO trim at zero to begin. At 21, it'll be too rich, hence the increased fuel use.
    • Griso
« Reply #266 on: October 11, 2014, 12:49:53 PM »
Thanks! Runs like a champ now.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
Offline sknapp351
« Reply #267 on: October 11, 2014, 02:24:54 PM »
I hope I can get some advice. I have a 2000 Jackal, and I am trying to connect GuzziDiag to check my TPS and CO trim. I purchased the cable combo from Lonetec linked to on the first page, and downloaded the GuzziDiag software and the only drivers Lonetec offered, which were for Windows. I originally tried connecting to my MacBook Pro, I didn't install drivers, as I didn't see any, and the program always said it couldn't connect. I had an old laptop with Windows for testing, so I dug that out, installed the cable drivers, connected everything in the exact steps on the first page, and it still says the Ignition is off.
I must be doing something wrong, but I'm getting a bit frustrated. I connected the two cables together, then connected to the three pin plug, then the red clip to the battery, at this point the red light on the cable came on. Then I plugged into the usb on the laptop. I then opened GuzziDiag, went to file, then connect. I turned on the ignition and watched the timer run out. Here are some photos.
Thanks for any help!
Sam
Offline smdl
« Reply #268 on: October 11, 2014, 02:36:41 PM »
Make sure it's in neutral or that the side stand is up.
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
    • Griso
« Reply #269 on: October 11, 2014, 02:39:34 PM »
Use the cable drivers from Guzzidiag, and not the drivers that came with the cable. http://www.von-der-salierburg.de/download/GuzziDiag/
Also, under the File menu, you'll need to click on Preferences and select the proper Language, COM port and Motorcycle. For the first time selecting COM port, have everything connected, and you may have to select the highest # com port. IIRC, it's COM 6 on my PC, and Com 4 on my mac.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
