Grisos, Shorty Clutch Levers, Those Pushrod Adjuster Thingos and Micro Switch...
Topic: Grisos, Shorty Clutch Levers, Those Pushrod Adjuster Thingos and Micro Switch... (Read 11754 times)
Tazturtle
Moto Guzzi - La moto la piu bella del mondo
December 21, 2014, 08:45:46 PM »
Dear Wild Guzzi Doctor.
On the clutch levers fitted to Grisos, 1200 Sports etc there is the notorious (allegedly "removable") pushrod that operates the hydraulic clutch cylinder.
I have bought a new set of shorty levers for my 1200 Sport, but despite applying lots of WD40, heat and using a brand new quality 1.5mm allen key, I'll be damned if I can get the grub screw loosened that will allow me to swap the pushrod onto my new levers. I note a lot of people have the same problem, while others breeze through it. Luigi!!!
I know that I can buy a brand new pushrod for the new lever from AF1:
http://www.af1racing.com/store/Scripts/prodView.asp?idproduct=7756
but the standard one has a small tab that operates a microswitch below the lever, that the new one lacks.
What is this microswitch for? Would it matter if I installed the AF1 pushrod that effectively stops the microswitch being activated?
Yours sincerely
Confused!
2022 V85TT Evocative
2012 1200 Sport 8V Corsa SE
2011 V7 Racer #749
"The Guzzi 750 is what BMW airheads used to be. Simple, direct machines for riders who enjoy the Zen of engines
guzzisteve
"Just Ride It"
Re: Grisos, Shorty Clutch Levers, Those Pushrod Adjuster Thingos and Micro Switch...
Reply #1 on:
December 21, 2014, 09:14:29 PM »
The micro-switch is part of the IDIOT system, it prevents you from being embarrassingly stupid in front of others.
It is connected to the Stupid Logic Relay along w/neutral, sidestand, and other crap for your own safety.
Last Edit: December 21, 2014, 09:25:59 PM by guzzisteve
Tazturtle
Reply #2 on:
December 21, 2014, 11:05:18 PM »
Aah OK. Thanks Steve.
I'll happily bypass it and take my chances then!
The Sport starts without the clutch lever being pulled (unlike the V7) so I assume it's to cut the engine if it is out and in gear with the sidestand down.
2011 V7 Racer #749
hhkiwi
Reply #3 on:
December 21, 2014, 11:10:51 PM »
I may be wrong but I think if the switch is no longer active you won't be able start the engine with a gear engaged. In other words, when you pull the clutch lever, the switch tells the bike's brain that it's OK to start the engine even with a gear engaged, i.e. not in neutral.
The set screw is usually secured with blue Loctite. I managed to get mine out by heating it up with a cigarette lighter. It does need to get really hot for the Loctite to break down.
Last Edit: December 21, 2014, 11:12:25 PM by hhkiwi
Tazturtle
Reply #4 on:
December 21, 2014, 11:13:10 PM »
I'll give it another try with an open flame instead of a heat gun then - thanks.
Kurt
2011 V7 Racer #749
Mayor_of_BBQ
Instagram: @Mayor_of_BBQ
'Ever thus to deadbeats, Lebowski'
Reply #5 on:
December 21, 2014, 11:57:18 PM »
I laid mine on the electric stove eye.. Just propped it so just the plunger was touching got it real hot.
Reply #6 on:
December 22, 2014, 05:01:39 AM »
Heat and
very
good, ie accurately measured, Allen keys are the trick.
Obviously the ability of the key to deliver the required torque is dependent on it being a very close fit in the screw and the proportional inhibiting of the locking medium will increase the smaller the thread.
Using a propane torch will get the locking medium to melt but in a case like this it is far better to not pussy-foot around! Propane heat won't melt the screw or barrel. It might, if you held the torch on it for hours on a really hot day, weaken the alloy of the lever, but I doubt it. What you do have to do is make sure it's as hot as buggery
before
you try and turn the key and heat the key in-situ in the screw. Yes, this means you'll have to use a rag to hold the key and don't try holding the lever in a vice. All a vice is in this instance is a very big heat sink! You'll waste a LOT of gas getting it really hot! Using rags to hold stuff will, if you're careful, revent you from burning yourself. Thing is with heat sometimes shit happens and you'll burn yourself. Oddly enough this will always be your own fault so take a lot of care and if you do get a blister? HTFU and get over it. Pain is nature's way of telling you you've done something dumb!
Tazturtle
Reply #7 on:
December 26, 2014, 04:57:04 AM »
Good advice Pete.
Heated the pushrod grub screw over a gas hotplate till it was smoking and it came loose beautifully.
The new third degree burns to 70% of my body will serve as a reminder of my mechanical limitations! ;p
Kurt
2011 V7 Racer #749
Perazzimx14
Reply #8 on:
December 26, 2014, 05:04:35 AM »
For anyone else attempting this replacements are readily available if you can't get or botch up the stocker.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0CC4QFjAE&url=http%3A%2F%2Fwww.af1racing.com%2Fstore%2FScripts%2FprodView.asp%3Fidproduct%3D7756&ei=L0CdVO7kOcSrgwTWy4HYBQ&usg=AFQjCNESHnqzyQ1ce_lBr48XXK0rYHwIrQ
Tazturtle
Reply #9 on:
December 26, 2014, 04:04:50 PM »
Yeah they are the ones I linked to in my original post - they don't have the actuator tab on the bottom of the barrel that operates the microswitch. (linking clutch, gearbox and possibly sidestand)
Kurt
2011 V7 Racer #749
organfixsing
Gosling
Reply #10 on:
February 07, 2015, 06:24:04 AM »
I hadn't researched this blog about softening the blue Loctite unfortunately and drilled out the grub screw with a 2.5mm drill. The remaining threads I removed using a spare 3mm screw with a slot cut into the end with a needle file (junior hacksaw?). I turned down the outside if a countersunk screwhead so that it was still usable and used that. I didn't measure the length of the screw but probably about 6mm. The pushrod thread was a little damaged by the drilling exercise, but not too badly. I now have a little free play in the clutch lever where before there was none.
Cheers
Brian ROMA QLD ::) ::)
If you remove the wings of a fly, does that make it a walk?
Waterbottle
Reply #11 on:
February 07, 2015, 04:26:07 PM »
Good Work Taz
Hey Brian from Roma, PM sent
2015 Griso SE Rosso
2012 Stelvio 8V
2009 Griso R Track only
76 GT 750 Suzuki
dguzzi
Reply #12 on:
February 10, 2015, 07:25:04 PM »
Ah Grasshopper, we will learn coefficient of friction as well.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
boatdetective
Reply #13 on:
February 12, 2015, 06:23:37 AM »
Just a mention that Pete's recommentation that you have good allen keys is something to remember. I bought a bunch from Bondhus. They really do seem to fit better. Quality product and well worth the investment.
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
"Who's the cat who won't cop out, when there's danger all about?" -Isaac Hayes
