Author Topic: Will this modification work?  (Read 17718 times)
Offline Yeahoo Whoyah
« on: December 28, 2014, 10:36:07 PM »
Some interesting angles for single shock rear swing arm, do you think it will work? http://www.ebay.com/itm/181625913804?_trksid=p2060778.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
Greg Tillitson
El Dorado Hills Calif.
Re: Will this modification work?
« Reply #1 on: December 29, 2014, 03:32:19 AM »
To me it looks like it's well thought out, triangle bracing and designed to hide behind the frame tubes  ;-T
The bike has great lines
Very clever.
« Last Edit: December 29, 2014, 03:35:54 AM by Kiwi_Roy »
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #2 on: December 29, 2014, 03:49:28 AM »
The bracing is not what I would do, maybe the pipe is strong enough, the setup is a cantilever. As on the daytona/ v11. The dimensions make that the wheeltravel is transferred smaller to the shock. With the Daytona it is 2:1, so when wheel goes one inch up, the shock gets 1/2 inch, so for 4 inches travel the shock should do 2 inches. This is not progressive, so the shock should be made for that. Using a shock that was made for a link system what is progressive won't work.
How the dimensions works out on this one, you need to measure.
I see they cut the tonti too, to lift the rear?
Paul
Daytona 1225, Stelvio 1151
Online jcctx
« Reply #3 on: December 29, 2014, 09:54:19 AM »
Looks like a $1500 parts bike to me!!!
Online LowRyter
« Reply #4 on: December 29, 2014, 10:09:39 AM »
looks pretty trick to me.  I don't know anything about shock and rear wheel movement geometries and ratios but it look like whoever did it, knew what they were doing.
Offline Kent in Upstate NY
« Reply #5 on: December 29, 2014, 10:22:40 AM »
He needs to work on his grammar.
Offline ken farr
« Reply #6 on: December 29, 2014, 11:37:01 AM »
engine position seems elevated.....
However, it does make a nice presentation.
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline Steph
  • Cali Stone/ LM3
« Reply #7 on: December 29, 2014, 11:57:04 AM »
Don't know how it rides but the guy has taste and building skills
« Reply #8 on: December 29, 2014, 12:23:58 PM »
It's been done.  Very famously on the Zagato bike, which was featured in a Davida advertisment:  http://www.bikeexif.com/zagato-guzzi
Ed@Guzzipower has the swingarms available:
http://guzzipower.com/store/SAbrace.html
Offline Idontwantapickle
« Reply #9 on: December 29, 2014, 12:48:54 PM »
I don't think I'd ride that ebay bike. Look at the difference between Ed's swingarm and that one. It is just not braced properly.
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #10 on: December 29, 2014, 01:24:05 PM »
Ed's looks over-braced to me but I'm no mechanical engineer  ???
« Last Edit: December 30, 2014, 02:01:30 AM by Kiwi_Roy »
dilligaf
« Reply #11 on: December 29, 2014, 03:07:39 PM »
YW posted: Some interesting angles for single shock rear swing arm, do you think it will work?   ::)
Who cares? It's all about looking cool, doesn't have to work.
 :+1  About all that SP is good for now.  ::(  :BEER:
Matt
« Reply #12 on: December 29, 2014, 03:47:42 PM »
I thought Ed is an engineer.
Online LowRyter
« Reply #13 on: December 29, 2014, 03:59:39 PM »
Hunter
You're right,  there's no zip tie of the other one.
 :D
Offline NCAmother
« Reply #14 on: December 29, 2014, 04:54:30 PM »
if you google "guzzi mono shock conversion" you'll find plenty of other examples.  Ed's swingarm would save a lot of headaches, there around $800.  I've talked to him on messages, he seems like a pretty good guy with a good track record for performance.  I think there is one on eBay right now.
Howdy
Offline Turin
« Reply #15 on: December 29, 2014, 07:21:31 PM »
I'd be a little bit more nervous about the geometry of the chassis and how it effects the steering/handling.
1985 Sidlow Guzzi
Offline Shorty
« Reply #16 on: December 30, 2014, 10:30:08 AM »
Why include the artsy phartsy "photo shoot" picture?   :D
Offline Steph
  • Cali Stone/ LM3
« Reply #17 on: December 30, 2014, 10:40:33 AM »
Marketing, marketing.
I'm afraid the the days of red suspenders targeting are over ;D
andrewdonald1
« Reply #18 on: December 30, 2014, 06:52:05 PM »
I think it look great!  If it rides great.. perfect.
Offline nc43bsa
« Reply #19 on: February 24, 2015, 07:38:20 PM »
He lost me when he described the Guzzi engine as transverse.
1990 MilleGT
« Reply #20 on: February 25, 2015, 05:05:47 AM »
Yeah, he's an ME.
Offline lucky phil
« Reply #21 on: February 25, 2015, 05:31:22 AM »
God I love these kind of posts.......it basically reads, I have no idea about the engineering but I can tell the builder really knows what he's doing.
If you don't know about the engineering then you aren't in a position to judge the competence of the builder.
That and the fact that the engineering devil is in the detail and there isn't enought detail to take a definitive position.
I can however say that the rear suspension design seems on the face of it to be weighed more towards the look than the dynamics. Not saying it would structurally fail but good engineering wasn't the prime consideration here.
Form has also won out over function in the exhaust department as well I fear and if good engineering is aligned with good grammar then it's going to be dangerous.
Ciao
Offline lucky phil
« Reply #22 on: February 25, 2015, 05:42:45 AM »
It probably is considering it only has wheezy old 2 valve Guzzi power and a 140 section rear tyre to contend with.
You could probably brace it with saucepan handless and it would be fine.
Ciao
« Reply #23 on: February 25, 2015, 06:03:21 AM »
True.
 ;D I know you're being facetious, but the old 2 valve "can" make some pretty serious power. If you look at the spineys, Guzzi used some pretty heavy tubing on the monoshock. There's a fair amount of stress there.
Offline pressureangle
« Reply #24 on: February 25, 2015, 08:06:37 AM »
It's pretty unless your eye includes good engineering. The rear shock mount will inevitably fail if this thing is rode hard for a while. It's not braced near enough to the top. Ed's swingarm shows how it needs to be. The ratio of the shock or progressive qualities aren't significant, as long as the shock is built by a competent manufacturer that can model the suspension correctly.
Maybe the high rear end takes into consideration that the shock mount will migrate back as the tower bends over.
Offline kevdog3019
« Reply #25 on: February 25, 2015, 08:16:57 AM »
Looks strange to me but since I'm no ME I can't venture a guess on how effectively it works.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline lucky phil
« Reply #26 on: February 26, 2015, 05:43:27 AM »
True.
Chuck, I also spend a fair amount of time in the "latest and greatest"world of motorcycles and here 200+ hp from a V twin is "serious" power. The bar just keeps rising I'm afraid and in this world an air cooled 1100cc V twin that makes somewhere around 85hp is sedate. Hell it was pretty sedate when it was new.
As for the heavy tubing on the rear arm, well that's more to do with Guzzi making everything massively overweight and not about any high stresses there.
Even comparing my Ducati ST2 with the V11 sport of the same era you can easily see how fat and overweight the Guzzi is and the only reasons there are for that is the design is crude and it's just in Guzzi DNA to build things with little regard to keepng the weight down.
Massive cranks, massive flywheels, heavy bevel box, none of it is necessary. Guzzi just don't have any regard for saving weight.
The ST2 is a scalpel compaired to the V11, so you can imagine what it's like compaired to an 1198.
Strangely the V11 is still my favourite out of all my bikes, but then again I'm a bit strange as well.
Ciao
« Reply #27 on: February 26, 2015, 07:22:02 AM »
Ciao
You see, we're more alike then different.  ;D My last duck was an ST2, and my favorite bike is the Mighty Scura. Go figure..
Strange? Yeah. Make that Hell yeah.. ;)
