Author Topic: 1987 le mans 1000  (Read 19431 times)
slosled
1987 le mans 1000
« on: January 08, 2015, 07:57:42 PM »
I have a 1987 le mans 1000 that has a bad transmission (broken gears)I would like  advise as to what other year /model transmissions I could replace it with that would be a good choice  for this model
Offline JoeW
    • The Guzzi Doctor
Re: 1987 le mans 1000
« Reply #1 on: January 08, 2015, 08:24:40 PM »
I think any five speed would be a suitable replacement. I'd stay away from the early ones because of the inverted shift pattern and the thrust washers on the counter shaft. The later five speeds, late 90s and up have the plastic main bearing cages that have given some trouble. I have a five speed from an 89 mille that would work fine. Let me know if you're interested.
Joe Walano
dilligaf
« Reply #2 on: January 08, 2015, 09:11:35 PM »
Do you have a standard MK IV or do you have a MK IVSE?  The gearing is not the same on the MK IVSE. These motorcycles had the engine cases and transmission painted black.  The SE's were painted red and white. In this photo the MK IV is on the right.
 :BEER:
Matt
Offline ccoli
  • What? Me Worry?
« Reply #3 on: January 08, 2015, 10:41:19 PM »
Matt is correct in that the SE has a unique transmission. From what I've heard parts are generally not available but Charlie Cole is the expert. Also correct is that any 5 speed will bolt right in. Newer ones do shift better I think. A couple of them on ebay now or that Mille one would be good.
Wisconsin MGNOC Rep
03 EVT/EML hack, 99 Bassa, 2-78 Robins, 32 Sport15, Ambo/EV custom.
Offline Seagondollar
  • Wake Forest, NC
« Reply #4 on: January 09, 2015, 08:25:26 AM »
Also, the V7 Sport tranny had a shifter return spring that only had two loops and was prone to breaking.  (They're probably all gone by now)  And the Le Mans and all later 5 speeds had 3 loops.  File away under Guzzi trivia.  It may be in Guzziology.
2002 BMW 330i
1988 Toyota MR2
1974 V7 Sport
« Reply #5 on: January 09, 2015, 08:45:40 AM »
I have a 5 speed froM A 98 EV. 40,000 MILES. make offer..
