Author Topic: Can anyone recommend a way to remove the bearing races pressed on (transmission)  (Read 21773 times)
Offline NCAmother
Can anyone recommend a way to remove the bearing races pressed on the mainshaft and clutchshaft.  Thanks,
Nate
Howdy
dilligaf
Nate,
If it what I think you are talking about I think you are going to need a press however, some bearing are held in place with a lock pin.  If you do not find a pin you will need a press.  :BEER:
Matt
Offline NCAmother
Thanks Matt  ;) I was thinking about welding a bead around the race, but I was concerned with damaging the actual shaft with heat.
Howdy
Offline JoeW
    • The Guzzi Doctor
I use a bearing splitter and a puller. A little heat helps but, I don't think I'd weld them.
http://www.amazon.com/OTC-1122-Bearing-Splitter/dp/B000O866WE/ref=sr_1_1?ie=UTF8&s=automotive&qid=1260858021&sr=8-1
Joe Walano
300 degrees in the oven for 20 minutes and they should fall right out. To install heat the case again to 300 degrees then drop in cold bearings.
It would help if we knew what model you are talking about? If you are talking big block five speed there are no bearings pressed onto shafts? There are the inner races of needle rollers. Is this what you mean?
Offline Mike Tashjian
The bearing splitter and puller is my first choice and in a pinch I will use a small cutoff wheel in a die grinder and go mostly through and then split with a chisel. Cooling the shaft in the freezer and heating the new race or bearing in the 300 degree range will let it drop right on.  Otherwise you will need a press to install the new ones. Do not push in the wrong areas of new bearings or they will be damaged.  Mike
I think he is referring to the inner races . What Pete stated is relevant , what model ?
dilligaf
Heat is your friend and what JoeW said.  I always had a press but that was back in the day.  :BEER:
Matt
Offline NCAmother
Yes, the inner races.  850T/5speed.  Thanks guys :)
Howdy
Offline Hahnda
    • Scrambler Cycle
Heat and most will fall right out, some might need a little persuasion with a blind bearing puller.
« Last Edit: January 11, 2015, 08:24:24 PM by Hahnda »
1949 GTV - 1948 Airone
www.scramblercycle. com
Offline jacksonracingcomau
One is easy, 2 legged puller on "nut" spacer behind it, not threaded, just pull both off together
the other either factory type tool, bearing separator puller if you have one or just grind it through & chisel it off
As above. I have also cut slots in the surface and used knife edges in them with the press on the end of the shaft.
oops
I should have read in detail before I posted
Offline NCAmother
oops
No worries old boy!  I should have wrote more detailed when I posted  :BEER:   I'm just really grateful for the wealth of info you all are willing to share
Howdy
