Author Topic: Griso ABS  (Read 28723 times)
Offline kirb
Re: Griso ABS
« Reply #30 on: March 09, 2015, 08:12:18 AM »
Piaggio has some 'interesting' ways of complying with regs...
The location of the carbon can on some models (like Griso) for one.
The horrible Stelvio USA mirrors for another.
It is possible to outfit a Griso with ABS, but they are going to have tweak a lot of things to get it to fit somewhere. I'm sure it can be done. Griso fills a large gap in the line for it to 'go away' without a replacement.
Offline molly
Re: Griso ABS
« Reply #31 on: March 09, 2015, 08:28:52 AM »
I'm sure the Griso name isn't dead yet. I would welcome a slightly larger version with optional cast wheels and nose fairing. The 1200 Sport is finished so a ABS Griso with a bit more long distance potentional wouldn't go a miss.
« Last Edit: March 09, 2015, 08:29:37 AM by molly »
Dave
Lincolnshire, U.K.
Griso 1100
Re: Griso ABS
« Reply #32 on: March 09, 2015, 09:07:54 AM »
What would you like to have "larger" in a Griso?  Other than fuel tank capacity, my wish would be for things to be "smaller".
Mainly smaller wheelbase and smaller weight.
As for "optional cast wheels", you have the option of sourcing cast wheels from the Norge/Breva/early Griso and bolting them right on.
« Last Edit: March 09, 2015, 09:20:49 AM by rocker59 »
Offline rboe
Re: Griso ABS
« Reply #33 on: March 09, 2015, 12:43:14 PM »
A strong argument could be made that the Griso is due, if not over due, for a make over. Taking that opportunity to add ABS to a next generation Griso makes sense (or making ABS mandatory a good excuse to come out with the next major redo for the Griso).
I guess it will be up to the market if that second generation Griso fills the shoes of the first. Or would this be the third generation? I guess that depends on how radical the redo is. If it is really different; drop the Griso name and come up with a new model.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline not-fishing
Re: Griso ABS
« Reply #34 on: March 09, 2015, 01:09:00 PM »
I'm just a simple construction worker but the thought hit me;  Where does the Stelvio NTX have the ABS pump?
Couldn't a little redesign of the airbox provide the room in the Griso?
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Offline twhitaker
Re: Griso ABS
« Reply #35 on: March 09, 2015, 02:17:55 PM »
Not sure which generation it would be but I believe there is a Centauro in the first generation.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline kirb
Re: Griso ABS
« Reply #36 on: March 09, 2015, 03:39:47 PM »
The pump is under the fuel tank on the Stelvio. The tank design is slightly different on the Griso and there isn't much room under there. The frames of both bikes are very similar, but the tank is not.
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: Griso ABS
« Reply #37 on: March 09, 2015, 04:21:14 PM »
Sure you can mount an abs somewhere but not invisible without redesign.
The Stelvio has ecu and electrics tucked in the fairing. These parts have found a place somewhere else in the griso.  Where the griso has the ecu, is the stelvio ABS.  The ABS unit is about 3 inches square.
Paul
Daytona 1225, Stelvio 1151
beetle
Re: Griso ABS
« Reply #38 on: March 09, 2015, 04:42:40 PM »
Put the pump where the alternator is and add a wet alternator. Tee hee. :D
Offline guzziownr
Re: Griso ABS
« Reply #39 on: March 09, 2015, 04:43:32 PM »
Here is my design brief:
Stick the horns out in the breeze and reshape the wings to accommodate the ABS.
Piaggio can send me a check at the usual address or Paypal is fine...
Offline pauldaytona
Re: Griso ABS
« Reply #40 on: March 09, 2015, 04:44:48 PM »
 yes that cn, but now they have same engine for norge/stelvio/griso thats to easy in factory.
Paul
Re: Griso ABS
« Reply #41 on: March 09, 2015, 05:25:04 PM »
And then the red Suspender brigade will piss and moan because it doesn't have enough current to run a cardio thoracic emergency ward!
Offline rboe
Re: Griso ABS
« Reply #42 on: March 09, 2015, 06:35:08 PM »
They could put it where the Stelvio has it and redesign the tank. This could be good or bad.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
