Author Topic: Brembo F09 calipers  (Read 13868 times)
Offline Allflatblack
Brembo F09 calipers
« on: January 15, 2015, 01:07:04 PM »
I know I have seen a lot of people looking for Brembo F09 48mm calipers for rear delinked brakes on old Moto Guzzis. I just received some parts from Stein Dinse, in the box was a flyer advertising new F09's. $160.
Online Perazzimx14
Re: Brembo F09 calipers
« Reply #1 on: January 15, 2015, 03:39:38 PM »
MG Cycle right side of the home page under "New Products" right side only.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110&products_id=4602
Offline Late to the party
  • 1987 1000 SP2
« Reply #2 on: January 15, 2015, 04:58:40 PM »
Gentlemen,
Please allow me a dumbass question:
How does one distinguish an F08 caliper from an F09?
Lateness.
Online Perazzimx14
« Reply #3 on: January 15, 2015, 06:00:48 PM »
Gentlemen,
Lateness.
An F09 is a F08 :+1
Morizzi
« Reply #4 on: January 15, 2015, 06:15:45 PM »
An F09 is a F08 :+1
No its not. An F08 uses 38mm pistons and a F09 uses 48. Hard to tell from a distance but the casting in the caliper for the piston is naturally bigger on the F09. Pads are different too.
Rod in Oz.
« Reply #5 on: January 15, 2015, 06:24:17 PM »
An F09 is an F08 turned up to 11 he means.
Online Perazzimx14
« Reply #6 on: January 15, 2015, 06:51:48 PM »
Rod in Oz.
So what you are saying is 38mm  :+1 :+1 :+1 :+1 :+1 :+1 :+1 :+1 :+1 :+1 :mm's
F09's are a nice replacement for the 850T's front caliper if you want to retain the stock MC. If not the stock F08 and a not stock 10mm MC are what you need.
« Last Edit: January 15, 2015, 06:55:50 PM by Perazzimx14 »
Morizzi
« Reply #7 on: January 15, 2015, 06:54:17 PM »
So what you are saying is 38mm  :+1 :+1 :+1 :+1 :+1 :+1 :+1 :+1 :+1 :+1 :+1
You can't count.
Online Perazzimx14
« Reply #8 on: January 15, 2015, 06:57:13 PM »
You can't count.
Oh yeah....your toilets flush the wrong way.
  • 1987 1000 SP2
« Reply #9 on: January 16, 2015, 08:20:56 AM »
I see someone left the key to the special needs room lying around again.
redrider
« Reply #10 on: January 16, 2015, 09:46:16 AM »
Oh, You Guys!!!!! That was almost a coffee event.
dilligaf
« Reply #11 on: January 16, 2015, 10:47:17 AM »
Da!  That one took me  awhile.  ;D  Just a little slow at times.  :pop  :BEER:
Matt
Offline mtiberio
    • TiberioRacing
« Reply #12 on: January 16, 2015, 01:04:53 PM »
F09's are not worth it as there is a limited selection of pad compounds. better to stick with the cheaper f08, and use a sticker pad. I'd also bet rebuild kits are NLA for F09's...
That plus F09's hit the bolts that hold composite rotors together on and the buttons on certain floaters
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #13 on: January 16, 2015, 02:05:24 PM »
I have a G5 project with delinked brakes and therefore a 15mm front master cylinder for ideal operation of two F08 calipers up front. The stock 15mm rear master will be too big for good action on the stock rear F08 caliper. Theoretically an F09 will work well with the stock master as a 48mm caliper with a 15mm master is a good ratio. That is my plan, does it make sense? Does it require surgery to mount it?
« Reply #14 on: January 16, 2015, 04:28:08 PM »
MG Cycle has F09 rebuild kits and pistons.
AFAIK, no surgery will be necessary. Mounts to the same carrier used on the SP, LeMans, etc.
Offline redrider90
« Reply #15 on: January 16, 2015, 05:25:16 PM »
Rod in Oz.
Agreed F09 is a much larger large caliper than the F08. It is all the difference in the world depending on what size your master cylinder is.
When I put the F09 on my 90 Mille the difference in how much effort and feedback I received from the brake handle was dramatically improved. I am 6'5" and hated the F08. It seemed to take my whole fist to slow it down. The F09 is a 2 finger stopper. I still use my whole hand but I know I can stop it with two fingers and have a good feel for what the brake is doing. I am glad to see them back. The big drawback to the F09 is it has 2  6 mm bleeder valves. You need to break them loose 1 or 2 a year hence the lock up and you break the nipple of both of them like I have done.
Red 90 Mille GT
Offline redrider90
« Reply #16 on: January 16, 2015, 05:29:17 PM »
F08 and F09 use same mounting pattern. It is a turn key operation.
Red 90 Mille GT
Offline redrider90
« Reply #17 on: January 16, 2015, 05:31:23 PM »
I haven't looked for pads lately for my F09 but Moto International had "sticky" pads for he F09 when they carried the item years ago.
Red 90 Mille GT
« Reply #18 on: January 16, 2015, 06:28:42 PM »
EBC Kevlar organic pads are available. They should provide good braking.
« Reply #19 on: January 16, 2015, 06:38:21 PM »
Very cool guys! Thanks
Offline Bobbilljim
  • Eternal Student
« Reply #20 on: November 13, 2015, 12:35:28 AM »
This seemed like a good place to drudge this up. I have Linked brakes, an F08 on the right and rear and an F09 on the Left front. I'm not sure how or why, thats just how I got the bike. For $200 you don't ask questions. Anyways, I want to actually drop the F09 down to an 8 so I'm matching. Any thoughts?
Rob
"There's Guzzi Cheap, then there's Stupid cheap" - Fotoguzzi
1984 California II
Online Perazzimx14
« Reply #21 on: November 13, 2015, 05:03:45 AM »
Should be as simple as unbolting the F09 and replacing with the F08.
redrider
« Reply #22 on: November 13, 2015, 06:58:28 AM »
Guzziology has a section on the 08-09 interchangeability. Going back to the 08 should be easy. Remove and replace.
Offline redrider90
« Reply #23 on: November 14, 2015, 10:32:41 AM »
Seems to me that the linked system is calibrated for F08 on front left. So I would expect that to change the characteristics???? I believe that some early linked Tonti's used F09 on the rear. Anybody want to clarify that as I am not sure.
Red 90 Mille GT
« Reply #24 on: November 14, 2015, 10:39:06 AM »
The 1000SP was the only one with an F09 on the rear, IIRC.
Offline zenand
« Reply #25 on: November 16, 2015, 06:02:09 PM »
I've got a spare f08 caliper if you're interested in a staight up swap ?
Offline leafman60
« Reply #26 on: November 16, 2015, 08:09:03 PM »
The F09 is a seriously big, mean-stopping hunk of a caliper.
About 30 years ago, I bought one from Roger Slater (Mr. Laverda) and adapted it to my '78 H-D Low Rider to replace the woefully inadequate rear banana caliper they used back then.
The Brembo is still going strong and hauling the FXS down smartly (helped by dual PM 4-pistons up front).
Offline Bobbilljim
  • Eternal Student
« Reply #27 on: December 11, 2015, 02:06:05 AM »
That sounds very interesting. Is it dual bleed or single? I will say to everyone that I had to shim the crap out of the F09 to get it to fit right on the fork. The F08 on the right side didn't require any shimming at all. Contact me via email for particulars.
Rob
1984 California II
Offline jim mac
  • TOO OLD TO DIE YOUNG www.guzzriders.org
« Reply #28 on: December 14, 2015, 07:21:28 AM »
i recently put one on my T5 for front brake as the fluid reservoir  (trapezoid ) was 'too big' for the F8 fitted.  change was immediate and fantastic, at last - a front brake that actually worked.
