Author Topic: Distributor felt? V7 Sport  (Read 11378 times)
Offline earemike
  • Lurker
« on: January 18, 2015, 06:03:47 AM »
I hope someone with experience can help me with a quick question.
Did the V7 Sport distributors contain felt in the centre (or center if you prefer)?
As a pre-electronic ignition kid you'd always check the felt, if it was dry you'd add a little oil for lubrication. Given my dizzy doesn't have a felt it either doesn't need it or at some stage went missing.
If I need felt, any suggestions? If not does the centre need any lube?
Thanks in advance,
Mike
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
Re: Distributor felt? V7 Sport
« Reply #1 on: January 18, 2015, 06:28:16 AM »
Yes, it originally would of had a felt pad. I just use a dab of grease on the points heels.
Offline Dick
« Reply #2 on: January 18, 2015, 09:04:58 AM »
Yes, a drop or two of oil keeps the mechanical advance lubed. Having the felt in place is probably a good idea. You can probably purchase it from any reputable Guzzi parts dealer, or try an auto parts store. Lots of points distributors used it (felt) when mechanical advance was commonplace.
You could also try your favorite felt store. :)
« Last Edit: January 18, 2015, 09:08:39 AM by Dick »
« Reply #3 on: January 18, 2015, 10:45:16 AM »
For replacing the lost felt, go to hardware store or Home Depot and get the polishing pad,s for a dremel tool, not the cloth ones but the felt ones. Trim w/razor blade to fit.
Offline jacksonracingcomau
« Reply #4 on: January 18, 2015, 06:59:30 PM »
I use a piece of absorbent foam, actually not for the advance spring mech (I spray chain wax in there for that)
The idea is to keep the heels of points lubricated without getting oil or grease on faces themselves.
Anything that holds some oil should work fine, centrifugal force gets it out, Steve's dremel pad sounds easy to get, thin oil is good.
Annual attention, clean fuel tap filters while tank is off, world is good
Offline earemike
  • Lurker
« Reply #5 on: January 20, 2015, 08:44:47 PM »
Thanks all, much appreciated.  :BEER:
850 T3
850 LeMans
SP1000 Stucchi
V11 Ballabio
