Author Topic: Cal II wheel spacers  (Read 9682 times)
Offline Bobbilljim
  • Eternal Student
« on: January 19, 2015, 10:55:49 PM »
 ??? So, I am rebuilding a cal II and had to piece the front end back together. My parts breakdown doesn't show a spacer on the LH side of the wheel between the wheel bearing and the fork. Does anyone else have a spacer herein a cal 2?
Rob
"There's Guzzi Cheap, then there's Stupid cheap" - Fotoguzzi
1984 California II
Re: Cal II wheel spacers
« Reply #1 on: January 19, 2015, 11:45:16 PM »
I just looked, the spacers a simple piece of pipe 28mm long
it fits over the treaded end of the bolt a bit over 15.5mm.
the OD is about 26mm
If you have a mate with a lathe get him to chew you one out of a length of 1" aluminuim rod
Actually the diameter's not critical 1-1/4 would be ok too but the ends should be square,
Offline travelingbyguzzi
  • God hates a coward
« Reply #2 on: January 20, 2015, 08:45:35 AM »
There shouldn't be a spacer on the left end. The left end of the axle is fatter, slides thru the left fork and seats against the left wheel bearing.
73 Eldorado
80 Sp
85 Cal II
97 1100Sport
08 1200 Sport AKA:Sweet Leaf
Offline Bobbilljim
  • Eternal Student
« Reply #3 on: January 20, 2015, 10:43:27 PM »
I think you are talking about the right side Kiwi. I appreciate you taking the time to look. That's awesome. So no spacer on the left means that the placement of the left strut on the axle is determined by the tree clamps? Makes sense that it all ties together. Thank guys!
Rob
1984 California II
« Reply #4 on: January 21, 2015, 12:53:13 AM »
Yes, the right side, as Bill says there's no spacer on the left.
I couldn't get my digital caliper on it without pulling the wheel but I eyeballed the length fairly carefully
Actually when you put it back together there should be about 1 thread poking out the nut.
Offline Bobbilljim
  • Eternal Student
« Reply #5 on: January 21, 2015, 10:04:03 PM »
Thats what i ended up with so that works out good.
Rob
1984 California II
