Author Topic: Rocker cover gaskets CalVin  (Read 9579 times)
Offline Richard Tasmania
  • Tasmania, Australia
« on: January 21, 2015, 11:10:22 PM »
The new rocker cover gaskets supplied by my dealer are different colour and material, metallic. They supplied four. Surely they made a mistake with quantity, it seems absurd to put two on each side. The gaskets appear to fit. Are they an improved part?
The inlet valves were set tighter than 0.004" and exhaust tighter than 0.006".  Do you think the last service set them too tight? I would assume with wear they would get looser.
Thanks.
Richard.
V50III gone but not forgotton
V7C 2012
California Vintage 2007
V50 Monza 1984
V7 Special 2022
Re: Rocker cover gaskets CalVin
« Reply #1 on: January 22, 2015, 04:32:23 AM »
Part number?
« Reply #2 on: January 22, 2015, 05:18:42 AM »
Thanks Pete, the part number is MGHEAD-6139
« Last Edit: January 22, 2015, 05:50:52 AM by Richard Tasmania »
V7C 2012
V50 Monza 1984
V7 Special 2022
makarushka
« Reply #3 on: January 22, 2015, 08:47:25 AM »
Seems like a truncated MG part number 976139, which is the correct OEM gasket for the Calvin. I stopped using these on my bike for two reasons: leaks within 4K miles each side, and the fact that they stick to both the valve cover and the head like glue regardless of whether you grease them prior to the installation or not.
I use part number 14023760, the same thick green gasket that's used on square fins prior to the Vintage.
« Last Edit: January 22, 2015, 08:49:59 AM by makarushka »
« Reply #4 on: January 22, 2015, 09:37:11 AM »
I don't know the part numbers, but......
Years ago they used to use a gasket that was thicker and had a 'silver' coating. You could reuse that gasket and never give it another thought.
Then they switched to a thin brittle material, sometimes green and sometimes blue in color. You had to have a replacement handy if you do a valve adjustment they are so fragile.
« Reply #5 on: January 22, 2015, 05:04:35 PM »
I've given up with paper valve cover gaskets and gone with reusable silicone gaskets.  Just tired of the mess and bother and the familiar oil all over my boot.
Offline Sheepdog
« Reply #6 on: January 22, 2015, 06:26:26 PM »
I use the green gaskets and keep a few around...
Online Cam3512
« Reply #7 on: January 22, 2015, 07:40:53 PM »
I used the thicker green ones from MG Cycle for 5 years on my Calvin.
Never a drop.
