Author Topic: Titanium engine stumble and cough  (Read 14417 times)
Offline TrogloBiker
« on: January 22, 2015, 02:05:07 PM »
Hey. My 2004 titanium has developed a cough. It occurs only when I'm cruising through town with a steady throttle between 2,000 and 2,800 rpm. It started a few months ago and has gotten a little worse. I looked for obvious signs and saw some extra soot around the right throttle body intake boot. I tightened the screws down and put new spark plugs (BPR6ES). Still does it. Runs down the highway perfectly, and pulls real strong, but as soon as I come down into town and run a steady speed it starts again. The cough is coming through the air cleaner. Are there any other obvious things to look for? Throttle position sensor? The air cleaner is KNN with some holes drilled in the plastic cover. Put 20,000 on the KNN with no trouble until recently. Fuel filter is fairly new, and I stay away from ethanol. (learned the hard way at about 10,000 miles) Any ideas would be appreciated.
2004 Titanium
1974 LAPD (retired at present time)
Offline bigbikerrick
Re: Titanium engine stumble and cough
« Reply #1 on: January 22, 2015, 02:19:49 PM »
 My Aluminum does the same thing, I have suspected the TPS, but have not done anything about it yet.  Rick
        :pop
« Reply #2 on: January 22, 2015, 03:42:36 PM »
Depending on miles, clean throttle bodies, set TPS base, sync throttle bodies & set air screw, set idle mixture.
« Reply #3 on: January 22, 2015, 06:09:19 PM »
can you get software on it ? might be a trim adjustment is in order..
« Reply #4 on: January 22, 2015, 07:14:17 PM »
Just for grins I would check for a vacuum leak around the rubbers that hold the throttle bodies on. They tend to crack where the clamp bites into them.
Offline menzies
« Reply #5 on: January 22, 2015, 07:56:08 PM »
What Chuck said, my 02 Special Sport was presenting the same symptoms, replaced the rubber boots on the injectors and all is good.
2001 Triumph Bonneville
2007 Triumph Bonneville
2006 Triumph Scrambler
« Reply #6 on: January 22, 2015, 08:42:38 PM »
spray something in the area and see if the idle increases?
Orange Guzzi
« Reply #7 on: January 22, 2015, 08:57:08 PM »
Take the tps off and pop the cap to see what is inside. It will pop right apart and go back together with out any issues.  I was surprised to see that mine was bad from the factory.  As you can see in the picture, the contacts are deformed.  This caused the tps to make contact in several locations at the same time.
Offline TrogloBiker
« Reply #8 on: January 23, 2015, 09:27:56 AM »
Thanks, I'll do that today. It's supposed to be almost 50 degrees here today.
2004 Titanium
Offline scra99tch
« Reply #9 on: January 23, 2015, 04:34:35 PM »
Spray a little propane around intake rubbers (less messy than WD-40).  Check for soot around screws on manifold.  Had a casting flaw close to screw head that went straight into cylinder.
Other than that TPS adjustment and CO trim increase.
2007 California Vintage
« Reply #10 on: January 24, 2015, 05:37:13 AM »
Poke a sewing pin through the wire going to pin 11 of the ECU (that is the slider of the TPS)
Measure the Voltage from the pin to chassis, it should ramp up smoothly from about 400 mV to around 4.5 Volts as you slowly open the throttle.
I have a short wire ending with a blue crimp connector tapped into the TPS slider wire, it makes it easier to do a throttle balance, the blue crimp
connector is just the right size for a meter probe.
« Last Edit: January 24, 2015, 05:44:54 AM by Kiwi_Roy »
Offline TrogloBiker
« Reply #11 on: January 25, 2015, 01:11:01 PM »
Thanks for all of the suggestions. I did go out and spray starting fluid all around both throttle body boots while the bike was idling. No difference. When our 50mph winds die down I'll check it further.
2004 Titanium
« Reply #12 on: January 25, 2015, 01:34:09 PM »
Guzzi engines don't "cruise" well.  Raise your rpm's or drop a gear lower.  Usually 1st gear in town.   :+1 on the TPS may need the contacts cleaned.
