Symptoms: when bike is warmed up, after 20 min, it starts to idle poorly, or not at all. At this time a tachometer run off of this coil's signal, will be slightly erratic. The display jumps from 1,900 rpm (normal idle) to almost 4,000 rpm, even then engine rpm hasn't changed at all.
I now see that the Woodruff key is missing. The key that aligns the magnetized flywheel on the crankshaft, to keep timing correct. Without the key, it's possible that as the engine heats up the flywheel shifts and timing drifts. Let me fix this, and see if it's a solution.Now to find an assortment of metric Woodruff keys.
I did. It was the middle of winter, so I had to heat up the crankshaft for the epoxy to stick, when I glued the key into place. In addition replacing the woodruff key, I also rewound the ignition coil. The "exciter" coil at the flywheel. That may have been the real problem, but I'm not sure.After that, it runs very well. Although I'm still sorting out some other issues. I re-cut the spark plug hole, since there was room for an extra length spark plug. With a 1 inch reach spark plug, the bike idles much lower now. Although I had to back off the spark plug by 2 millimeters, to keep them from hitting the top of the piston.The bike starts and idles beautifully, although I still haven't taken it out for a high speed run to check that end of the range.
